Question about Whirlpool GH7208XR Convection / Microwave Oven
Whirlpool microwave cook light goes on but oven does not work
I have a built-in oven/microwave combo. Number stamped on the back of the microwave is 3183566B. The problem started a while back with the motor shutting off on its own while cooking. Pressing on the door fixed it temporarily, but it got worse and worse. For a while, the oven worked fine with something pushing the door up slightly. However, now nothing works. The cook light lights up properly, but nothing else happens.
  • Whirlpool Master
  • 9,098 Answers
This is usually caused by either a bad door switch or a loose door switch mount, which are pretty simple problems to fix.
Having had to wiggle the door to make it work is the giveaway.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If the switch mount is broken, it's usually more economical and safer to add a dab or two of hot glue to the mount to secure the switch. Let it cool for about 30 minutes before using.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Your model number (since it's a Whirlpool) will be something like MH1150xxx#m, GH6177XXX#, etc.
The model number will be located on a tag either in the cavity or around the door frame if it's an over the range model, or on the back if it's a counter top model.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If yours is a counter top model, you will need to remove the outer cover.
If you don't find yours, or if you want to look at it without disassembling the oven, you can download it here.
If you only need a switch, you can order a universal type here for $5 postpaid.
Posted on Feb 16, 2009
2 Suggested Answers
  • 1214 Answers
SOURCE: Whirlpool microwave cook light turns on but oven does not work
Check and replace the door safety switch.
Posted on Feb 15, 2009
I have a whirlpool Microwave, do not have the model details on me. It goes fine but for some reason if I close the door normally the light goes on & turntable turn but oven is not actually cooking. If...
The door open/close some microswitches. During the cooking process they became greasy and working bad. You must replace them or if you're a skilled man, wash them.
Dec 14, 2017 | Whirlpool MT1135SGB/Q Microwave Oven
My whirlpool gold gt4175sps lights up and the control panel works but the turntable does not spin and it does not cook. No fan or cooking noise
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Troubleshooting Tips
Jan 16, 2011 | Whirlpool GT4175SPS Stainless Steel 1200...
The other day my microwave quit cooking and the turntable stopped turning. The fan still turns on and the light still works as if it is cooking but it doesn't. We shut off the power and tried again but it...
It may just be a bad door switch. See this file.
You can enter your full model number at the Sears parts site to find helpful exploded view diagrams.
A full Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as ###.########.
May 27, 2010 | Kenmore 62622 Microwave Oven
Hinari microwave doesn't cook
hello mam
i am having the solution for this problem check the lock terminals for loose connection and if its working and check the magnetron which produses the heat inside the microwave.
Sep 25, 2009 | Microwave Ovens
F6 appears on my Whirlpool Over Oven Microwave, Model GH7145XFB0. It will not let me perform the self-diagnostic test. When the door is closed, the light goes out and the unit begins the "cooking process"....
If it starts cooking as soon as you close the door,try unplugging it for a minute then try again. If it does the same its probably a defective triac or relay which is inside the microwave.
Aug 29, 2009 | Whirlpool MH7140XF Microwave Oven
Whirlpool microwave only cooks for limited time?
It's possible that the module that produces the microwaves is failing. The parts are cheaper but the labor may not so get an estimate before deciding if it's worth repairing or replacing.
Nov 20, 2017 | Whirlpool GH5184XPQ Microwave Oven
Does stove-top need downdraft if microwave has oven-hood combo?
We have a stove with no downdraft, and a microwave with a hood above it. It works just fine. I expect you could keep your downdraft and put a microwave without a hood above it, and that would also work. I don't think, however, you can buy an above the range mocrowave oven, that slides in on brackets, which will not have a hood.
Jan 08, 2009 | Microwave Ovens
Everything works except the cooking part/no heating/turntable not turning, help!
you may have gotten a power surge and that can cause some funny things to happen, 1st is there power to the oven, 2nd if so there may be an internal fuse protector built in to the oven, check with the manual for anything of that sort listed. if not you may have to take it in and have it repaired by a pro. there is a lot of voltage in these ovens and unless you know what you are doing a person could get hurt
Jan 03, 2009 | Whirlpool GH4155XP Microwave Oven
Whirlpool GH7208XR Convection / Microwave Oven Logo
111 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
