Question about Kenmore HE2 Plus Front Load Washer
He2 plus washer shuts off and flashes f 21 or ends and shows 5d
I shop vac'd through the drain line and got wrappers and dirt out and it appears the drain pump is now working
    Scholar:
  • 87 Answers
I'm not by my work computer right now but take off the bottom of the washer (3screws) there should be a tech sheet in there somewhere (usually back of the panel you took off) that will tell you what that code means. I'm not sure if that's a slow drain code or not. Behind that panel is also the drain clean out. It simply screws out like a house one. See if there is anything stuck in there also.
Posted on Feb 16, 2009
5d error code kenmore he2plus
Here's a video prem mathew suggested as a solution to your problem from YouTube:
Kenmore He2 washing machine washer drain problem fixed
Apr 26, 2013 | Kenmore Washing Machines
The f 21 code comes on and we have checked the hose and the drain to the house. I don't know who to check the washer itself but can drain with a shop vac. after you drain the s5 code comes back on when you...
There are 3 screws at the bottom of the cabinet, remove the bottom panel. There is a screwtop cylinder right in the middle. Unscrew it. Problem solved! Give me a rating if I am right. Good luck. Make sure you have a towel!
Aug 22, 2010 | Kenmore HE2 Plus Front Load Washer
Ran Cleaning Cycle, lights blinking w/ F- 21min alternating
f-21 is a blocked drain pump.remove the bottom panel,if you have a shop vac get all the water out,you'll see the pump and in the middle there's a piece that you can turn and pull out,first put towels under and around the pump to catch any water that leaks out,turn the part slowly and with your shop vac catch the water with the vac,take your time and open it little by little catching the water with the vac,when you get all the water out twist the middle part out and clean the catch and feel around in the boot and the pump and make sure you have it cleaned out.stick the middle piece back in and start the washer or you can fill it with a gallon of water and put it into a drain cycle and make sure it drains,if it doesn't you cooked the pump and have to replace it,let me know what you find and next time send the model number.
Jul 25, 2010 | Kenmore HE2 Plus Front Load Washer
F-21 error means What?
F-21=LONG DRAIN If the drain time exceeds 8 minutes the water valves shut down. After 4 mins the Sd(slow drain) error will be displayed, 4 mins later the F/21 error code will be displayed.
Press PAUSE/CANCEL 2 times to clear display
Probable cause/Proceedure
Drain hose plugged/kinked
unplug washer/disconnect power
check electrical connections to pump
and make sure pump runs
check drain pump filter for strings,sand etc
plug in washer If this dont work
replace pump.
Dec 31, 2009 | Kenmore HE2 Plus Front Load Washer
What does code F21 mean on a Kenmore HE2 plus washer 11047532602?
it stands for longer than normal drain interval,press "pause/cancel" twice to clear, if it returns then look for obstructions in the water drain from the basket all the way to the drain in the house,or possibly it could be a bad washer drain pump
Nov 19, 2009 | Kenmore HE2 Plus Front Load Washer
My Kenmore He2 Plus has fault code 33, this is after fault code 21 which I cleared by using a wet vac to drain the machine through the drain hose .
The F33 error code indicates a pump drive system error. If the pump ohms out correctly & the harness is secure I recommend replacing the CCU (central control unit).
Please see the following image provided for instructions.
http://media.fotki.com/1_p,stwwfrggtqfbrbbxgtqsskgwtqkq,vi/wgtbwqwssxsbwkbdtfwxrbfbddwwf/1/1303472/5961857/image9159087223444281043img-or.jpg
Remember to disconnect power to the washer before attempting access.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 30, 2009 | Kenmore HE2 Plus Front Load Washer
My machine won't drain
Click on the following link and follow the steps provided:
http://www.fixya.com/support/r1484065-f21_error_code_whirlpool_duet_kenmore
Pouring water down the drain probably isn't enough to rule out the possibility of a clogged drain pump. You will need to open the bottom panel of the washer and remove the drain pump reservoir to be sure.
If you require additional assistance, please let me know before rating the solution. I hope you find this information helpful.
Jan 26, 2009 | Kenmore HE2 Plus Front Load Washer
My kenmore he2 plus washer is showing f21
"F21" is a Long Drain error. This occurs when the drain time exceeds 8 minutes. You will need to remove the bottom panel under the door by removing the two screws at the bottom edge of the panel. First, check the electrical connections to the drain pump and make sure the pump is running. Check the drain pump filter to make sure it is not clogged with debris. This is a very common problem. HINT: Before removing the drain pump filter, pull the drain hoses from the standpipe at the wall and use a shop vac to pull a vacuum on the drain hose to get rid of all residual water from the pump and drain lines. This is also a good way to get rid of minor clogs. If you do not own a shop vac, be prepared to lay down some old towels and soak up some water. There's quite a bit of residual water in the wash tub and lines (this is normal). In addition, check your drain hoses to make sure they are not clogged or kinked. If you check everything and still have the error code, replace the drain pump. Replacement parts can be found at searspartsdirect.com and repairclinic.com. Just type in your model number in the search menu. I hope this helps you. If you require further assistance, please let me know.
Aug 16, 2008 | Washing Machines
Kenmore HE2 Plus Front Load Washer Logo
240 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
