Question about Carrier XHB123D X/Y Series Heat/Cool Air Conditioner
Carrier Weathermaker 8000 turns off intermittently
The furnace will shut down intermittently.The unit is 15years old. I have changed the ignitor, gone to cheap filters and about 7 years ago replaced the control board. When I turn off the entire furnace it will reset itself.
The error code that I get is 41.. But when I shutdown the furnace it will reset itself and start working again. I have checked contact from Thermostat and it is working.
  • 56 Answers
You can find what the error code is by looking on the inside of the bloewr panel. If it is still there after all these years there is a code list right around the wiring diagram. If my memory serves me correctly it is a limit problem. But be for sure and check the code sheet.
Posted on Feb 16, 2009
Heat exchanger replacement for carrier weathermaker 8000
After 18 years of service, it is not cost effective to just replace the heat exchanger. Go the complete replacement route. There may be a utility company incentive to do it.
Jun 06, 2016 | Carrier Weathermaker 8000 Gas Furnace 125k...
Weathermaker 8000 58TUA doesn't work
The switch could be defective but more likely the furnace blower is failing.
Dec 17, 2013 | Carrier Weathermaker 8000 Gas Furnace 125k...
Funace keeps shutting down
Restarting after removing the power is how the equipment is designed to operate because removing power temporarily clears the fault code. Not starting could be caused by a number of built in safety devices such as roll out switches or partially blocked flue pipe. I've seen them with bird's nest in it. This should be looked at by a trained professional.
Nov 26, 2013 | Carrier Weathermaker 8000 Gas Furnace 125k...
I have a carrier 58RAV050-12 and my furnace won't turn on. It was working earlier today but it just stopped. Any suggestions as to why?
Check the pilot lt. If its out shutdown your furnace and call a repairman. If the pilot light is on, the flame sensor might have gone out. It's a long silver sensor that sits in the pilot light flame and senses when the flame is present. If it isn't working the furnace will automatically shut down.
Nov 04, 2013 | Carrier Weathermaker 8000 Gas Furnace 125k...
Weathermaker 8000 not enough heat
Are the tips of the flame blue? You might need to adjust the air mixture sleeve on the burner.
Feb 05, 2013 | Carrier Weathermaker 8000 Gas Furnace 125k...
My oil furnace won't fire
Ignitors should last more than 3 years... but it is possible you knocked the electrodes out of alignment when you did the nozzle change.
Also, when you changed the canister filter, did you also change the screen filter in the oil pump? DIYers often forget that, and some service outfits due too... but if your canister filter was dirty, its quite possible you are running into problems with the screen. You can check this somewhat by setting things up as you would to prime the pump, and noting the fuel oil flow... if you aren't getting a nice steady stream, I'd tear down the pump and check the screen... granted, you could have crud in the lines.
Oct 19, 2017 | Heating & Cooling
Carrier XHB123D X/Y Series Heat/Cool Air Conditioner Logo
766 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
