Question about HP PhotoSmart 1115 InkJet Printer
Have black ink but but not color will it work
I put the black ink in but the printer says you need the color catridge how do i fix it
You have to insert color cart or it will not work
Posted on Feb 15, 2009
Printer says cartridge is out of ink but is practically new and hardly been used
Is it the original Hp catridge or you refilled it..???? you've replaced the black... so no problem with black.... color catridge would have dried... so remove th color catridge and wipe thi lower part gently with a wet cloth....!!!
Mar 23, 2012 | HP DeskJet 6988 Printer
Ink cartridge not properly installed
I have gone through all the forums but none of them worked...
The correct solution for the problem is the canon printer needs to have both the color and black catridges present in the printer...
So even if you purchased new black catridge only you need to have the old color catridge to be placed in the place of color catridge....
So it will detect the catridges and if any of the one is empty it asks to select black at the time of printing and simply select it you will get a black print...
So make sure both the catridges either empty or full need to be placed to detect the catridges....
I hope it will be helpful.....
Feb 18, 2011 | Canon PIXMA iP1300 Printer
Replaced the ink. black works colored does not.
Normally, new catridge has a thin layer close the output of the ink. See that thing. If it close, pull it over, Or.
May be the catridge is not suitable with the printer.
May be the the catridge is quite old and the ink is dry, if it is refill catridge, put several drop of hot water in it.
Hope this may help.
Jan 20, 2010 | HP DeskJet F380 All-In-One Printer
Would a CX3810 work with only 1 black ink cartridge?
all epson type need all catridge put in a head, if you want use black only, you can buy ciss sistem
Dec 23, 2009 | Epson Stylus CX3810 All-In-One InkJet...
Prining in colour not working?
because,some of your ink catridge colors are completed with your prior usages,, you have to replace your ink catridge,,..
Sep 27, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Color ink for ip1000 does not flow..??
Now put out u color cartridge and take one tissue paper or toilet paper then put ink color head to paper(soft pressure).after that see u paper are inside show three color appear in paper????(red,yellow and blue).if all have means you cartridge ok if only same or no any coming out means u color ink problem need to replaced new unit.
if got all color out better u open u printer body and check are all cable u plug in back is correct or wrong position??.second u can try go to printer preferences go to find print out in color or in gray-color and change their setting to print out in color
Sep 01, 2009 | Canon PIXMA iP1600 Printer
Can i use my scanner without putting in a new ink catridge in
no,both ink cartridges should be installed into the printer.buy new ink cartridges from kodak online store if u want to buy.
Jul 16, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
I changed my black ink and now i get the message left cartridge incorrect..how do i fix it?
HP PSC 2210 InkJet Printer. The following has to be done for checking the Blank Ink Catridge working : 01. Remove the existing Black catridge and Color Catridges from the Printer carefully. 02. Clean the location with a soft cloth with cleaning liquid to make the place dust free. 03. Put the correct black and colour cartridges recommended by HP and that too genuine one. 04. Do not use any refilled or reinked local catridges that will spoil the HP PSC 2210 printer. 05. Re-install the catridges both Black and Colour properly. 06. Take a test print out - both black and colour print outs. 07. Check the Printer status and there is no warning of Cartridges wrongly inserted. Have a Good day.
Jul 14, 2009 | HP PSC 2210 All-In-One InkJet Printer
My hp 1310 says no colur ink catridge found.
No
some model hp deskjet all in one used duel cartrdge because it is a color popier
Jun 16, 2009 | HP PSC 1315 All-In-One InkJet Printer
HP PhotoSmart 1115 InkJet Printer Logo
100 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
