Question about Jacuzzi Pool & Spa
Heater won't go on my jucuzzi model 315
Just refilled it. It's showing code oj5. The jets all work, but the heater won't kick on. Was working fine when I drained it.
  • Mark Egan May 11, 2010
    How long have you allowed for the water to heat up?
    On a cold tub of water, it takes several hours, as much as 4-6 hours, to come near getting warm.
Hey, I am having the same problem... Did u figure out the problem? How did you fixed it??
Thanks
renato_rmj@yahoo.com.br
Posted on Jun 01, 2009
    Problem Solver:
  • 11 Answers
Upper spa side control should have a heat lite, if on then heater is recieving voltage. Sometimes pump can have an air bubble in line.
Make sure water is flowing from jet. Spa will not lite heater without water flow. If no water try loosing union after pump to pull air through, so pump can fill with water, and no longer cavitate. Kirk
Posted on Feb 17, 2009
My Apollo hot tub stopped heating and the first set of jets are not working and both seemed to have gone out at the same time. The second set of jets and the air are fine. Does anyone have any ideas of...
You're pump #1 has failed. Your spa has 2 water pumps and an air pump. Number 1 pump pushes water through the heater. Pump 2 simply supplies the second set of jets with water. The air pump simply pushes air through the air jets.
If pump one fails you will have no heat and the first set of jets will not turn on. Pump 1 is the most prone to failure because it kicks on any time the spa needs to filter or heat. This happens automatically every day so pump 1 works much harder than pump 2. Your heater has a safety mechanism that makes sure that water is flowing through the heater when it kicks on. If there is a problem with pump 1 your heater will not kick on. There are stickers on your #1 pump. Get the model number off of the sticker and order a replacement pump from a web site like www.spapartsdepot.com. If you give them the model number of the pump they can send you a replacement. I'm 100% sure that's the problem. I'm not affiliated in any way with the web site I mentioned but I'm pretty sure they will have the pump you need. Good luck!
Mar 24, 2013 | Apollo Pool & Spa
Samsung clp 315 printer shows "replace/install
Hi there your printer wast toner drum is full. So just remove that and make empty the drum & then refill the toner box. now use. Thanks.
Dec 22, 2010 | Samsung CLP 315 Laser Printer
Jet 1 won't turn on after refilling spa. Everything else works.
try turning by hand while off if turns ok try again see if voltage to motor if so bad capacitor or motor
Aug 13, 2010 | RTO Pump Volute, Acura, Maverick,No IMP
Heaters runs for a few minutes then shuts off.
was working fine refilled it and now it will run 5sec. and kick the breaker on it.It's an old 80's model 35,000 B.T.U. I cleand the photo eye with a cloth no change. Any solution's
Jan 29, 2010 | Reddy Heater-30-55,000 BTU Variable
Toner is exhausted!! insert a new toner; this message appears while printing the page; i m talking about samsung ML1640. i have refilled the toner cartridge; but still that message appears; wat i can do...
We have Zero cost solution for samsung -scx-4300, scx-4824/4828
ml-2240,ML 2245, ml 1640. clp 310/ 315, It is working permenently.
Refill cartridge is working for ever. which is running successfully.
also provide other new model reset solutions.
www.nakshatraworld.com
mob: 9713862555, 9893282285
vivekryp@yahoo.co.in
Nov 04, 2009 | Samsung ML-1640 Monochrome Laser Printer
Samsung CLP-315 eats toner. Cartridges last almost
ean_inkrefills on ebay. Search on the terms "samsung clp 315 toner refill solution". Chip installs on the printer motherboard--installation is not overly difficult, but still not for the faint-hearted. I expect it voids the printer warranty. Ean gives good email support.
Aug 02, 2009 | Samsung CLP 315 Laser Printer
Refill clp-315
No need to drill holes. If you turn the cartridge with the drum facing away from you, on the left hand side, you should see a small block elliptical cover with a couple of divider on it. That is the cover for filling the cartridge. The problem is there is no available reset chip yet for clp-315.
Feb 21, 2009 | Samsung CLP 315 Laser Printer
Cardstock jams in printer clp-315
CONTACT SERVICE CENTRE YOUR STD CODE PLUS 30308282
Nov 15, 2008 | Samsung Office Equipment & Supplies
Pool & Spa Logo
238 people viewed this question
Top Jacuzzi Pool & Spa Experts
Jay Finke
Jay Finke
Mike
john h
Are you a Jacuzzi Pool and Spa Expert? Answer questions, earn points and help others
