Question about Westinghouse Electric Ceiling Fan 3-way Light Switch By Westinghouse 77052
Westinghouse 3-way fan switch can not be turn off.....
All three speeds work except that it does not turn off unless the wall switch is flip off.
    Problem Solver:
  • 4 Answers
I had a similar problem. A replacement Westinghouse 3-4 wire 3-speed replacement switch from Home Depot, part # 77020, is a multi-pole that did not work with my ceiling fan. There was no "off" position. I found the correct replacement switch, sold under the "Harbor Breeze" name, part # 033905, which is a single pole switch, at Lowe's, at a better price!
Posted on Aug 15, 2009
  • 4 Answers
The Westinghouse 77020 switch functions as follows:
Position ' Connections
1) L+2+3
2) L+1+3
3) L+1+2
4) L+1+2+3
The correct functions of a 3-speed fan switch, or at least in the case of a Hunter
ceiling fan, are as follows:
1) L+1
2) L+2+3
3) L+3
4) L
So either you can buy a different switch from a different manufacturer, or you can do like I did & modify the Westinghouse switch by opening it, removing the #3 connection, & shaving down the plastic housing underneath the metal contacts for the #3 wire. The reason you do this is so you can get that connection to sit as low in the housing as the terminal marked L. Then you must modify the piece in the center. It has 3 long brass terminals & one short one. Now remove the plastic barrel inside the brass terminals. Using a pair of dikes, cut the small tab off. Hold the terminal piece so it looks like a "C" & cut the top & the side terminals down halfway. Now just put it back together wiring it as follows:
L = GREEN
1 = GRAY
2 = BROWN
3 = BLACK
It should now work if done correctly.
Posted on Aug 17, 2012
  • 35 Answers
You can find a switch with an off position and change it out.probably was meant to be controlled from a wall switch,and the off position on the speed selector would be confusing.(When you would turn the wall switch on but no fan).
Posted on May 22, 2009
I have experience a similar problem.Home depot has different kinds of 3 speed fan switches at different locations. I found westinghouse 77020 at one location and a westinghouse 77021 at another. Fortunately the 77020 worked for me. But for a reference Westinghouse has 3 types 77020, 77021 and 77023.
Posted on Sep 15, 2009
I have a harbor breeze ceiling fan on a dimmer
You have 3 options. You can connect the fan blue and the fan black to the red ceiling wire. Then you will need to control the fan and light with the strings. The wall switch will turn off everything. Option 2 is make sure that there is a switch wired to the black ceiling wire. If there is a switch I would check to make sure the switch is working. Option 3 is to purchase a remote control unit for both and leave the wall switch to shutoff the whole unit. Hope this helps.
Oct 11, 2013 | Speed Ceiling Fan 3-speed Switch By...
I have a Hampton Bay ceiling fan. I bought Westinghouse 77021 to replace the fan switch. I have black, white, yellow and blue wires inside the fan's case. Where should I connect these wires? Jane
Hello. Yhe most common combination for this wire combination is: L - White, 1- Black, 2 - Blue, 3 - Yellow . However this is assuming your 77021 (the fan) has three speeds and the pullchain has four wires. Here's a link to some very good troubleshooting advice: http://www.ceiling-fans-n-more.com/ceiling-fan-pullchain-replacement-and-repair.php
and a link to Diagrams: http://www.hurontel.on.ca/~taitg/pages/cfan.html
Hope this helps, and don't forget to rate our help. Thank you.
Mar 07, 2011 | Speed Ceiling Fan 3-speed Switch By...
I have a four-wire, three-way fan switch that I am replacing. I put the wires back in the same order but I am only able to get the fan to turn on to low with the first click and it turns off for the other...
Most likely the color codes are not the same as your original. There should be one wire that is common to each position (except off) If you have a continuity tester or ohm meter, test the new switch before connecting. Start with the black wire and one of the others. Keep pulling the switch until it goes on. Then try the black wire and a different wire. Keep pulling the chain until another goes on. If you can do this for all three, then the black wire should be connected to the black wire in the outlet box to your house wiring. Then connect the remaining three. If your speeds are not in the correct order, you can exchange connections until you have low, med , high. off. The black wire may not be the common wire and if not start over using say the red wire, and test to each of the remaining three.
Dec 10, 2010 | Westinghouse Electric Ceiling Fan 3-way...
Replacing 3-speed fan swith, using westinghouse 77021. Black (hot wire) to L, red to 1 , outer black to 2. What is 3 STRIP for?
the third wire should be for neutral (White) This is an incomplete request,
Is this a three wire pull switch or are you hooking up to a light switch on the wall.
but what I know is Black hot
Red switch
white neutral
If it is NOT WHITE do not attach it untill you have someone over to help you
Jul 22, 2010 | Westinghouse Turbo Swirl 78145 Ceiling Fan
Changing the 3 speed switch on my westinghouse ceiling fan
If you are careful and take the hot coming into the fan from the power source and connect it to the colored wires one at a time, you will be able to find which one is high, med. and low. Then connect them. Hot in is L, 1 is low, 2 is med, 3 is high
Jun 18, 2009 | Speed Ceiling Fan 3-speed Switch By...
Trying to replace 3 speed ceiling fan switch and don't know which wires go where - 3 speed fan switch, 4 wire unit.
Hi
The pull switch has 4 wires, L, 1, 2, 3.
Connect ' L' to the reverse switch red wire or the wire that is free.
Connect ' 3 ' to the main black ( hot ) wire entering the fan.
Connect ' 1 ' to the capacitor's lowest uF eg. ( 1.5 uF )
Connect ' 2 ' to the capacitor's next uF eg. ( 3 uF )
the Capaciotr also has to be connected to the neutral wire entering the fan, usually black attached to another color wire. If you have a VOM tester, veryfy that it is a neutral wire.
Regards
H. Montero
Aug 06, 2008 | Westinghouse Fans Indoor Ceiling Fans
3 speed ceiling fan
I could not understand that "all the three positions are on high speed and off" ? How can be it possible that all the (three) positions give high speed and at the same time no speed (off)? Please explain.
 What I feel that the speed controller be in series with the fan. "in series" mean that the wire should come from phase or line, go to the speed controller , then go to the fan, then finally go to the neutral point. This completes the circuit.
 I will be happy to know more about this if it could not solve your problem.
Nov 28, 2007 | Westinghouse Turbo Swirl 78145 Ceiling Fan
3 speed fan switch
Zing Ear ze208s switches are NOT all the same - the actual switch wafer on the back varies significantly. Some are single-pole making contact with 1, 2, 3 one at a time, others make contact in combinations. Like L123 for high, L1&2 for medium, and L1&3 for low. The number stamped in the center of the back may indicate the difference. I have one with a "4" that is one-pole at a time, and another that is a "21" and makes multiple contacts at a time.
Nov 18, 2007 | Westinghouse Turbo Swirl 78145 Ceiling Fan
Westinghouse Electric Ceiling Fan 3-way Light Switch By Westinghouse 77052 Logo
3,162 people viewed this question
Top Westinghouse Electric Electrical Supplies Experts
Gene Haynes
Terry Weaver
Terry Weaver
Are you a Westinghouse Electric Electrical Supply Expert? Answer questions, earn points and help others
