Question about RCA D52W19 52" Rear Projection Television
My tv has a dinosaur in it.
When first plugged in and power button hit, the tv will chirp 3 times approx 10 seconds apart then will do nothing until unplugged and back in. it sounds like the chirpping is comming from the horz trans but not sure. it is a low pitch to high sounds like a cap charging and it reminds me of the small dinosaurs in jurasic park.
    Novelist:
  • 184 Answers
Its a raptor most likely. But seriously, when these RCA TVs go into shutdown or fail to power up, they will try 3 times to re-establish operation. Your problem can be caused by a number of circuits. The power supply itself may be bad or the high voltage/ deflection circuit. You can visually inspect the circuit board. Some failures in these TVs will cause obviously damaged components like burned resistors and the like. The problem here is that most anything that will fail will cost some serious money. Expect to spend $300-500 to repair it or consider replacing it.
michtech
Posted on Feb 16, 2009
Change language on WMAOD 743
Try this:
1) plug into the power supply and turn on at the socket.
2) do not press the on/off button on the machine at all.
3) press the 3 buttons marked "reduced creases+mini load+time saver" and hold down together until a beep is heard. approx 5 to 10 seconds.
4) leave for 10 seconds.
5) turn on with the on/off button.
6) you are ready to run through the language menu again.
7) select required language by pressing the "child lock" button once.
Nov 16, 2017 | Computers & Internet
Tablet wont turn on
If the tablet battery was left to drain completely, it may not turn on at first. Here is what to do. Plug in the charger and charge for 5-10 minutes. Then try again. If nothing, then press the power on button for approx. 10 seconds, and that should reset the circuits. Then try powering on again. Continuing charging the battery until full.
Jul 06, 2014 | Lenovo Computers & Internet
My galaxy tablet will not turn on and or charge
hold the power button down for 10-15 seconds to force a power off. When turning back on, hold the power button down until you either feel it vibrate or something comes up on the screen.
Jan 13, 2014 | Samsung 7 in. Galaxy Tab 3, 8GB...
I need to reset my lamp counter on my projector pt-lc56e but i dont know how please help me
After changing the lamp you should be able to turn on the projector and it should run for approx. 10 minutes, allowing enough time to reset the lamp counter. Hit "Menu", select "Option 2", hit enter, which will bring up "Lamp Runtime", press and hold enter button approx. 3 seconds. The selection will change to "Time Reset (Power Off)". Turn off the power and it will reset.
Jan 26, 2011 | Panasonic PT-LB10VU Multimedia Projector
Dead, power light flashes 10 times then nothing for 4 seconds then flashes 10 times then repeat. This is after I inserted an SD stick.
Unplug,replug the tv about hour later.Tv will,reset itself,back to factory setting.Should have power now.Still have the same problems.The power supply board is dead.That the board,where the power a/c plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Aug 07, 2010 | Panasonic Viera TH-42PZ80U Plasma TV
I bought a new Keyless remote for a 2007 Forester from a Subaru Dealer to replace an original one that went bad after 2 years. I have followed the directions in the owner's manual to program it, but can't...
IMPREZA: 2005, 2006, 2007 and
FORESTER: 2005, 2006, 2007, 2008
Check for Immobilizer key on Forester XT models only.
information is always subject to change and correction imp05keylessremote1.jpg
new remote for 2005 Imprezas.
This is not the same remote as the 05 Legacy/Outback remote which also has truck/gate release on the front and a red panic button on the back.
Lock: press Lock button for 2 seconds or so to lock car, and arm optional security system. The car with chirp once and turn signals flash for locked, 5 short chirps and signal flashes if any door is not fully closed. The dome light goes on for 15 seconds and ignition key ring (if present) will light for 30 seconds when unlocked.
Unlock: press unlock one time for driver's door, press again within 5 seconds to unlock all doors inkling rear gate (wagon). The system does not open the trunk.
Panic mode: press and hold lock button for approx. 3-4 seconds to activate Panic mode. I panic model the horn honks and turn signals flash until either the lock or unlock button is pushed again.
Finder mode: Press lock button 3 times within 5 seconds to activate Vehicle Finder mode. The horn will honk once and the turn signals will flash 3 times
Distance: works within approx. 30 feet depending on battery strength, nearby concrete walls and etc.
Audible Chirp On-Off: the system will chirp when locked or unlocked. To turn OFF the chirps, unlock the door and then push both lock and unlock buttons at the exact same time for 2+ seconds. There will be 2 chirps indicating the the audible is off. To turn the chirp back on, repeat the process and the system will chirp one time when it is back on.
Battery: as the battery ages it will only work as you get closer to the car. When a battery is replaced, the transmitter must be re-synchronized with the Keyless control unit. To synchronize, press the lock or unlock button 6 times.
Programming: 4 codes may be programmed.
Sit in driver's seat and unlock all doors. Open and close the driver's door
Turn the ignition key from LOCK to ON position 10 times within 15 seconds. Be sure to stop at both lock and on. The horn will HONK once to indicate transmitter programming mode is activated. Leave key in LOCK position and don't remove it from ignition.
You now have 45 seconds to complete the programming as below.
Open and close driver's door again.
Push either lock or unlock button on the remote you want to program. The horn will honk 2 times when successful.
To continue and program other remotes at the same time: open and close the driver's door and push lock or unlock on the remote. The driver's door must be opened and closed between each remote you want to program.
Done programming? remove the key from the ignition and the horn will honk 3 times.
DELETE old codes? Reprogram 4 times, it will overwrite old codes.
Alarm Security System: optional on all models. When locked there is one chirp (can be turned off, see above), the turn signals will flash and the red 'security' light will start to flash once every 2 seconds except for STi which flashes twice every 2 seconds.
There will be 5 chirps if a door, hood, and trunk or gate is not fully closed
You can also arm the system by using the power lock button on the driver or passenger door as you get out of the car and then closing the door behind you.
Disarm the system: push unlock for 2 seconds
Lost remote, alarm activated? When you can't use a remote to turn off the system: open the door with a key or try to start the car and the horn will start to honk. Turn the key on-off 3 times within 5 seconds and the alarm will go off and you can start the car. It's simple!
VALET mode: To set valet mode or just to disable the security alarm system: 1. unlock all doors 2. physically open the driver's door 3. hold the UNLOCK button on remote for 2+ seconds. The red 'security' light will then flash 2 times a second until the car is turned on.
System has been Tripped (except for STi): if you unlock the door with the remote and it chirps the signal light flash 4 times, the system has been triggered;
Identification mode: To find out what happened and why the system was triggered:
Open and drivers door, leave it open. Turn ignition key from LOCK to ON 2 times and then leave in LOCK position.
Tripped code: 1 security light flash: a door has been opened, 3 flashes when the impact sensor was triggered, 4 flashes when the ignition was messed with or battery disconnected
Nov 19, 2009 | 2007 Subaru Forester 2.5X L.L. Bean...
RCA HD52W69D projection tv powers up for second green light
try replacing CP150 on the deflection board
Mar 15, 2009 | Televison & Video
Panasonic PT-53TWD63, TV will not turn on, Red power light blinks
It is most deffinately a convergence chip issue. The die for no reason. They can be bought online for around $10 dollars and anyone with experience with soldering can replace them pretty easily. I have done it.
Feb 03, 2009 | Panasonic PT-53TWD63 53" Rear Projection...
Akai tv
The power supply most likely failed on your LCD.
How old is your LCD?
Jul 26, 2008 | Akai LCT3201TD 32 in. LCD Television
Problems with tv powering up
yea take your tv to a tech its having problem in the power supply or related circuits.good luck.
Apr 13, 2007 | Panasonic PT-47WXC43 47" Rear Projection...
RCA D52W19 52" Rear Projection Television Logo
49 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
