Question about Connex 3300 240-Channels Base CB Radio
Can not hear people through static from radio.
It is a connex 4600turbo. Transmits fine. It is not engine noise because it's the same with the truck running or not. Have had it at the shop and checked. They say everything fine in radio. It's in a 2008 Kenworth T600. Can it be RF noise off of Truck. Any suggestions!
    Problem Solver:
No,its in the radio.i have had a lot of radios,and i have had several with just too much noise.its in the radio.i would not go by what a trucker cb shop says.contact company,or try and sell it and start over.i have had to do that also.
Posted on Feb 16, 2009
Connex 3400 hp makes static noise when I hit bumps in road.
don't hit any more bumps. The problem could be in several areas. I'm going to say that you may have a loose capacitor inside If I had the radio here I could fix it but because the problem may be so spread it could be a lot of things Are you a truck driver? If you are take it to a CB shop at one of the many truck stops and see if they can fix it for you .
Jan 22, 2016 | Connex CX-3400hp AM/FM 10 Meter Amateur...
Have a Kenwood TK-2200 that transmits just fine but does not receive. When powered up the white noise/static is constant. Any fix for this?
Many times static/white noise is a sign of a bad or low battery. You might try trading the battery with a known good unit to see if the problem goes away. Also, you may want to check your antenna, trade it with a known good antenna and see if it is the issue. Beyond this your radio would need to be looked at by a repair tech.
Best regards.
Jan 06, 2015 | Radio Communications
I have a cobra 29 ltd chrome and it making a lot of static noise while driving or idling. it transmits and recieves fine though
Hi, my name is John. Welcome to FixYa. Try running your power strait from the battery, that will bypass a lot of your noise. RED (+) ground (-) . Thanks for choosing FixYa....John
Nov 30, 2010 | Cobra 29 LTD CB Radio
My connex 3300 hp stopped reciving it transmits people can hear me loud and clear but I cant hear them radio was working fine then one day I turned it on and couldn't hear any thing.
Hi, my name is John. Try a external speaker, plug it in the back of radio, turn the RF GAIN to MAX. Turn the SQUELCH all the way to left, make sure the select knob is on CB, and on AM...try all this and if that's does not do it, let me know, I will post other steps here,.... hope this was very helpful....
Sep 02, 2010 | Connex 3300 240-Channels Base CB Radio
With engine running on boat, radio transmitts with
This is almost always caused by a poor ground. I would suggest you run your ground wire (larger the better) back right to the negative terminal of the battery.
Hope this is helpful.
Jul 14, 2010 | Uniden Solara DSC VHF Marine Radio
Will my connex 4600turbo hook up ok on the factory conection for the cb? The wire size is no12.
This is a 190 watt radio it needs 8 guage wire and ran to battery source.
Apr 23, 2010 | Connex 4600 Base CB Radio
GALAXY 88 HIGHT STATIC IN THE RECEIVE ..
If the antenna for the other properly operating radio is used with the radio with the noise and you are getting the static then we can assume it is the radio. If you hear signals with the static, that is, it does receive communications at the same time, there may be a problem with the noise reduction circuitry, or a defective component(s) in the receiver. Without knowing your experience I would suggest taking to a radio shop.
Oct 10, 2008 | Galaxy Radios DX- 88HL Base CB Radio
Frequencies
i have a 4600 connex and if i turn the mic gain all the way up i get alot of modulation.can someone tell me how to fix that?
Feb 01, 2008 | Connex 4600 Base CB Radio
Connex 3300 240-Channels Base CB Radio Logo
252 people viewed this question
Top Connex Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
Steve
Steve
Are you a Connex Radio Communication Expert? Answer questions, earn points and help others
