Question about Maytag Atlantis MDE7400AY Electric Dryer
New belt but drum still won't turn
My husband put a new belt on the maytag performa dryer. The drum will turn slowly when there aren't any clothes in it, but when you add clothes it will not turn. When you have the front cover on, the drum looks loose, but if you shake it, it seems snug. I desperately need my dryer! Please, please help us.
    Problem Solver:
  • 4 Answers
Make sure that he put the tensioner on the right way with the spring it will make the belt really tight !This is sometimes hard to do because the spring will bite you if your not careful !!
Posted on Feb 15, 2009
Dryer won't spin
Was the belt shredded ( normal wear & tear ) or burnt through which could be a drum bearing or support problem .What does the drum feel like when you turn it by hand is it grinding & lump ? The fact that the motor runs with no load could by the start device faulty these are reasonably cheap to replace this is the small cylinder attached to the side of the motor with two wire connections . if your motor has not got one of these then its the start windings in the motor
Jan 11, 2013 | Maytag Dryers
Dryer won't spin
If you have kids and they over fill the dryer it strains all systems including the heater because it cannot get rid of excess heat. Solution*** Possibly needs a new belt
Dec 07, 2012 | Maytag Dryers
How to replace an Dryer Drum Belt ?
check youtube for a lot of vids on this subject
Feb 14, 2018 | Maytag Performa PAV2200
Maytag Performa PYE2200AYW drum turns until I put clothes in it, then it slows and stops.
You have the belt on wrong. There is a side with numbers or writing on it and ribbed side like treads. The tread side should be facing down, making contact with the drum. If the other side is touching the drum then whenever clothes are put in the belt will slip causing the drum not to
May 29, 2012 | Maytag Dryers
Maytag Dryer drum not turning properly after cleaning
Make sure the drum belt is positioned properly. You may have disturbed it when you removed the front door panel. It should be a tight fit on the drum. You should see the wear pattern on the drum where the belt was. Check the condition of the belt and make sure it's not cracked or stretched and slipping. Did you disconnect any wires when you opened it? Double check that you didn't rehook the wires wrong and make sure the door sensor switch is in proper position. Hope that helps.
May 14, 2010 | Maytag Dryers
Maytag Performa PYE G2200 gas dryer, the dryer seems to turn on but the drum will not turn.
Based on the information provided, it sounds like a broken drum belt is at fault. Below is an illustration of the drum belt.
http://www.repairclinic.com/SSPartDetail.aspx?s=t-PYG2200+-%3d%3di529597&PartID=529597
Here is a parts/disassembly diagram:
http://www.repairclinic.com/Dryer-Gas-Maytag-Style-Appliance-Diagram
Here is a belt installation diagram:
Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt, and often the idler pulley, because the pulley tends to wear out at the same time.
Click here for a belt installation diagram.
All links courtesy of www.repairclinic.com
Aug 16, 2009 | Maytag Dryers
Need belt diagram for Performa PDET920AYW dryer
Flat side of the belt goes agaist the drum. The diagram is on the new belt
Aug 08, 2009 | Maytag PYE2300AY Electric Dryer
Dryer belt broke on my dryer.
I use a putty knife to press against the spring clips to pop the top. Then I use a quarter inch nutdriver to remove the screws holding the front panel on. I remove the wires from the door switch and lift out the front panel. I remove the drum and put the dryer on a work bench or a tailgate. I inspect the blower wheel(most of the time they get loose). I get the ball of lint out of the front panel filter housing. I vacuum out the dryer with my shopvac. I oil the rollers and idler and inspect the drum slides for wear. I loop a new belt rib side down to the drum and set it back in the dryer. With my left hand I drop the belt under the motor pulley and raise up the idler looping the belt on it and let the tension hold the idler. I manually slowly turn the drum to make sure the belt is secure and not twisted. I place the front back on. Snap the top down and give her a try. Piece of cake.
Jan 11, 2009 | Maytag PYE3300 Dryer
Dryer leaving black marks on clothes
contact the factory for replacement patrs.richardm69
Dec 14, 2008 | Maytag Performa PAV2200
Maytag Atlantis MDE7400AY Electric Dryer Logo
200 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
