Question about E-Machines eMachines Desktop PC
Reads cd but will not write?
I started out ok copying files to cd but out of the blue it will not write saying I do not have a disk in, when there is one that I have been writting too. Even tried new disk same thing?
  • muller1974 May 11, 2010
    Could you give me the exact error....and answer all of these question...1 is the Disk full/ Is it a blank CD or DVD that you are using?. 2When i put in a Audio CD will it play? 3What is your OS system and what program are u using for copying files?4 Did i try a different program, does it work eg NERO? 5Does the system have a problem with the DVD or CD rom drive....go to contorl panel and system/ hardware, check DVD/CDrom in devices...is there a error? If there was a error, did you update the driver?
  • E-Machines Master
  • 13,433 Answers
Hey,
I'm sorry but in most cases when this happens you have a faulty drive, the drives are dirt cheap now a days and you can get a new better, fully working drive with a warranty from newegg.com
have a look here
http://www.newegg.com/Store/SubCategory.aspx?SubCategory=5&name=CD-DVD-Burners
Let me know if you need anything else.
Thanks,
Ekse
Posted on Feb 15, 2009
Cannot install Windows XP Pro using the setup disk. I can delete the old partition and reformat the hard disk using NTFS, but when setup starts copying files it fails to copy a file (never the same file)...
It's possible that your disk-drive is "failing", and it's about to "die".
Buy a new disk-drive, connect it, and try to install to it.
Other possibilities:
* bad RAM in your computer is messing-up the file-copy operations, and the CD-reading operations
* dying motherboard is malfunctioning,
* scratched Windows CD-ROM media
* malfunctioning CD-reader device.
Oct 22, 2010 | Western Digital (WD1500ADFD) 150 GB Hard...
How do i copy a disk
Before you Begin Make sure there is no program runing that has opened any file on the original disk. You cannot run the Disk Copy procedure if any file on the original or destination disks is in use by any program. For example, if you were editing a document in MS Word, saving to the disk in Drive A, and now want to copy it to another disk: FIRST quit the MS Word program, then execute the Disk Copy procedure. Caveat LectorThis Disk Copy procedure will make an exact copy of the original disk on the copy disk. It will completely overwrite the copy disk, replacing anything on it with the contents of the original (source) disk. That means that if there are any files on the copy (destination) disk before you begin, those files will be destroyed. You might want to take a look at the destination disk before beginning to be sure there's nothing on it you want to save. -------- Copying a Disk
  1. Double-Click on the My Computer icon on the Desktop. The My Computer window will open.
  2. In the My Computer Window, click once (not the usual double-click!) to select the icon for 31/2 Floppy A:
  3. Click on the File menu and select Copy Disk. The Copy Disk window will open onscreen.
  4. In the Copy Disk window you will see the option:Copy from 3 1/2 Floppy (A:) to 3 1/2 Floppy (A:)Click on the Start button.
  5. A new window will open prompting you to Insert the disk you want to copy from (source disk). Insert the disk and then click on the OK button. The program will begin "reading" the files from this original (source) disk. You can watch the progress in the little "progress bar" in the Copy Disk window.
  6. Once the original disk has been read into memory you'll be prompted toInsert the disk you want to copy to (destination disk)Now remove the original (source) disk from the drive and insert the copy (destination) disk into the drive. The click the OKbutton. You can watch the progress as the computer "writes" to the copy (destination) disk in the Progress bar in the Copy Disk window.
  7. When the copy is completed you'll see a new, small window popup that will report:The copy completed successfullyNow remove that copy (destination) disk. You are finished!
------- This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
Nov 04, 2009 | Acard Technology (ARS-2030LD) DVD±RW...
Get Error msg - RW CD is Read Only
OK for CD-RW you have to make sure you are using a burning application that allow's CD-RW. This is DIFFERENT to making a MULTISESSION disk whereby you can add file later.
If you use a CD-RW media and just burn normally, the application will finish off the disk as a CD-R media.
Basically, the disk must be 'formatted' correctly for CD-RW which will allow you to add/remove/modify the files on the CD.
Most versions of NERO should have this facility.
Mar 25, 2009 | HP Computers & Internet
Disk data is in read only mode. How change to Read/Write?
If you are referring to files on a CD, they are read only because a CD does not allow you to write on it after it has been created.
You need to copy the file from the CD to your hard drive, edit, and resave it there.
If the file is already on your hard drive and is read only, you can right click on the file name, and select Properties. Clear the "Read Only" check box and choose OK.
Jul 15, 2008 | Microsoft Word 2003 for Students &...
Blue error screen when loading os
ok did u try to instal ur os from a diffenrent cd ? try it , even the problems occurs check ur system with a different RAM ur will find the difference mostly problem gets solved if solved the ultimate sollution is to change ur RAM
Apr 11, 2008 | Computers & Internet
Cd driver will not read copied data disk
Ok,Download software for recover your data from Memory Card, Phone, HDD or any other Storage Device ----
Download from the following link ------
http://www.dasofts.com/software/3675-recover-my-files-3.98-build-6218.html
Note- this software is works only with windows operating system so, connect your Memory Card, Phone, HDD or any other Storage Device to computer to recover data.
For any other help contact me.
Thanks
Mar 22, 2008 | Toshiba Satellite M30 Notebook
Cannot copy files to DVD disks
when i try to copy and paste file to DVD, through windows, a message appear says"windows encountered a problem when trying to copy this file." i dont know why, could someone help?
i'm upset now. :(
Dec 21, 2007 | Gateway GT4022 PC Desktop
Msi 478 socket mother board
to: pubudu,
you said that your ram is ok, but i think it's the ram which is your problem because of memory dumping with color blue. yes your ramis ok but the reason why not ok is because the latency is not compatible with your settings in bios
Dec 01, 2007 | Intel Motherboard
E-Machines eMachines Desktop PC Logo
35 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
