Question about Thule Atlantis 1200
Can't open one side of our thule luggage rack for top of our van
After several years of ownership, I have developed a problem with getting the key to turn on one side of our rack.  Due to this problem, we almost couldn't secure it to the roof of our van.  I used a little WD40 where the "bolt" sliding mechanism was stuck and finally my husband was able to twist it hard enough to get the bolts to slide open. (I thought the key would break off in the lock!)  It used to be so easy.  It also looks like the long metal gismos that slide the bolts in and out of place are warped toward the inside of the luggage compartment (probably impeding the sliding of the bolts) Can anybody help me with this problem??  Thanks
  • Thule Master
  • 1,176 Answers
The odds of someone here being able to solve your problem is near zero. Why not go to Thule.com or call using this info:
Thule com Phone Number
Posted on Apr 02, 2017
5 Suggested Answers
  • 74 Answers
SOURCE: How do you easily get a bolt into a rusted thread?
new bolt? or remove the rust on both my soaking in vinegar or a commercial solvent.
Posted on Apr 13, 2009
SOURCE: How to change locks?
Just replaced the locks on an Atlantis 200 which should be the same.
Pop off the 3 rubber caps around the lock and drill out the rivets.
Inside the box pull the plastic unit away from you (bending the aluminium strip slightly but this is fine) gaining access to 2 screws. Unscrew these (I used a small ratchet with a pozi bit rather than a screwdriver) and remove the plastic unit.
You'll have to take out the lock cartridge next. Theres various wedges in the plastic which you should try to hold open then a flat screwdriver near the cog should lever the whole thing out.
To get the barrel lock out of it's cartridge you'll have to push the tumblers in from the back with a very small screwdriver and gradually work it out. (the one I did had a snapped key so I'm assuming this part is easier if you are just changing locks for keyed alike purposes)
Fitting the new lock in to it's cartridge should be easy enough. When you reinsert the cartridge in to the housing make sure that the sliding bolt (that your key turns) is fully in the open position, otherwse your key won't do a thing.
Screw the housing back on and re-rivet the points you drilled.
Dan (Rothwell Trailers)
Posted on Sep 07, 2010
Coachphil
  • 347 Answers
SOURCE: I have just bought a thule 91726 pull top carrier
Here is the Thule Manual for your particular model. It's in PDF form so easy to print off and keep with you.
Enjoy the slopes.
Posted on Dec 10, 2010
Coachphil
  • 347 Answers
SOURCE: I have a Thule Adventurer
Thule customer service is excellent and they will be happy to give you the exact answer you are looking for.
www.thule.com
Posted on Jan 05, 2011
My car is overheating. I changed the water pump, changed the thermostat housing, and checked the radiator and hoses, but the car is still overheating. Any suggestions.
I would do a coolant flush. You can get it done or do it your self. They sell kits at auto supply stores reasonably cheap. It involves cutting the heater hose line going into your heater core at the firewall and installing hose fitting. The instructions are fairly easy.
Apr 03, 2016 | Thule 2012 Mini Cooper - Hatchback,...
My 2000 Chevy Astro van steering wheel is locked and my car key wont turn at all what could i do?
Christy, make sure van is all the way up in park, grasp steering wheel and (wiggle) turn back and forth sharply while trying to get key out.
If no success call a locksmith.
Mar 26, 2016 | 2000 Chevy Astro - Passenger van, with...
How do i start a 2002 chevy without keys
call your Chevy dealer they can get new set of keys, by using the VIN # number of the vehicle,,it won't be cheap ,,, you
will have to prove owner ship....the cheaper way will be get a new
cylinder switch,, from you local auto parts,,, the cylinder switch
come with a new set of keys.......good luck.....
Mar 02, 2015 | 2002 Chevy Astro - Passenger van, with...
How to replace the glass on the driver side of 2001 chevy astro van
Pull door panel easily and remove hardware to remove the glass and place the new one gently in place.
Dec 18, 2014 | Vehicle Parts & Accessories
How do I find the starter rely on my 2002 astro van?
Facing the engine it's below the exhaust manifold on the left side of engine in the back
Aug 26, 2014 | 2002 Chevy Astro - Passenger van, with...
How to replace the harmonic balance gasket?
Do you need help with a roof rack or something with the harmonic balancer? If its the latter, there usually is no way to replace the rubber ring in the harmonic balancer. Its a press fit and should be replaced as a unit.
Jun 23, 2014 | Thule 2002 Saturn L-Series - Wagon, with...
Car starts cuts off
This could be caused by a multitude of things. Is the check engine light on? Check the evaporative system for a vacuum leaks, the unit is on the drivers side under the van, to the left of gas tank. These vans also have a lot of problems with the distributor cap. When was the last time it was changed? Is there black smoke when starting the unit? If so it may be your pressure regulator or fuel lines going to the injector, or an injector itself is leaking.
May 29, 2014 | GMC Safari Cars & Trucks
Adamo Oct 18 09:21 am (PDT) I have a 2003
Sound like you either have a universal joint on the way out or a balance issue with the driveshaft. The vibration at idle might be an engine miss or its running lean. With that many miles it could be a simple vacuum leak at the manifold, but that should throw a check engine light. Maybe check compression on each cylinder to make sure they are close to equal. It could be just a worn out engine.
Oct 18, 2013 | 2003 GMC Safari Cargo
Can anyone help me choose the right roof rack for my car?
I recommend that you check out the Thule fit guide for choosing the right roof rack for what you want to carry.
Sep 30, 2013 | Luggage & Travel
Thule Atlantis 1200 Logo
146 people viewed this question
Top Thule Cycling Experts
Michial Gueffroy
tau1618
Are you a Thule Cycling Expert? Answer questions, earn points and help others
