Question about Astro Pneumatic 7846 Harmonic Balancer Puller Set
Harmonic Balancer how do you remove the Harmonic Balancer on a 1999 buick regal
  • 142 Answers
Need a harmonic balancer puller.. Can be rented at some auto parts stores. Some will sell them.
It threads into the hub of the balancer and has a bolt in the center that is rotated to exert pressure on the crankshaft.
Each rotation of the bolt will create more force and move the balancer a little at a time until it is clear of the end of the crankshaft.
Posted on Jun 03, 2009
How to remove a harmonic balancer
You have to use a harmonic balancer puller you can get one at auto zone
Feb 22, 2012 | 1992 Buick Regal
The biggest wheel under the belt is vibrating ad making alot of noise. How long do i have before i break down? and is it the harmonic balancer?
by biggest wheel under the belt are you talking about the lowest wheel on the motor at the bottom of the motor then it is the harmonic balancer the rubber dampener material between the outer and inner metal balancer is coming apart.you should get this replaced as soon as possible.if it separates completely it can cause alot of damage to other components and cost more money to repair the damage
Mar 04, 2011 | 1995 Buick Regal
How to replace a crank positioning sensor on a 1994 buick regal gs with a 3.8l
you will need a puller to take off the harmonic balancer, then you will see it. it has to line up perfectly with the balancer.
Dec 11, 2010 | 1994 Buick Regal Gran Sport
Changing a harmonic balancer on a buick regal 3800
you will need to remove the crankshaft bolt with an air impact wrench. Then you will need to get a balancer puller to get the pulley off.
Nov 18, 2009 | 1995 Buick Regal
What tool do i need to take off the vibration dampener
Tool is called a harmonic balancer puller. If you use anything else on it you can do damage.
Oct 07, 2009 | 1992 Buick Regal
1999 Buick Regal LS, 170,000 km (~105,000 miles). Stalls at random city speeds, usually when decelerating or at a stop. It's OK on the highway. I don't think it's the ignition because it usually takes a...
Check the crankshaft position sensor.It is located forward of the harmonic balancer.Quite often the bracket that holds it gets broke or loosens up allowing sensor to rub on balancer.
Aug 03, 2009 | 1999 Buick Regal
Removing the Damper/Hormonic Balancer
go get a harmonic balancer puller from parts store and follow instructions on box. will come of a seconds
Jun 05, 2009 | 1991 Buick Regal
Crankshaft Position Sensor and Camshaft Position Sensor
REMOVE OR DISCONNECT
  1. Serpentine belt from the crankshaft pulley.
  2. Raise the vehicle on a hoist.
  3. Right front tire and wheel assembly.
  4. Right inner fender access cover.
  5. Using a 28 mm socket, remove the crankshaft harmonic balancer retaining bolt.
  6. Crankshaft harmonic balancer using tool J 38192 or equivalent.
  7. Sensor electrical connector.
  8. Foreign object deflector.
  9. Sensor and pedestal from block face.
  10. Sensor from pedestal.
INSTALL OR CONNECT:
  1. Loosely install the crankshaft sensor on the pedestal.
  2. Position the sensor with pedestal attached on special Tool J 37089.
  3. Position the special tool on the crankshaft.
  4. Bolts to hold the pedestal to the block face, torque to 20-40 Nm (14-28 lb.ft).
  5. Torque the pedestal pinch bolt to 3-4 Nm (38-40 lb.in).
  6. Remove special tool J 37089.
  7. Place the special tool 37089 on the harmonic balancer and turn. If any vane of the harmonic balancer touches the tool, replace the balancer assembly.
  8. Balancer on the crankshaft.
    • Apply thread sealer (GM 1052080) or equivalent to the threads of the balancer bolt.
  1. Torque the crankshaft bolt to 140 Nm + 56°(104 lb.ft + 56°).
  2. Foreign object deflector.
  3. Electrical connector.
  4. Inner fender shield.
  5. Tire and wheel assembly, torque to 140 Nm (104 lb.ft).
  6. Lower the vehicle.
  7. Serpentine belt.
Jun 02, 2009 | 1994 Buick Regal Gran Sport
Balancer pulley turns 1/8 turn before crank
Remove yonder pulley and you will find the bolt holes are elongated. get another from a scrapyard (take the bolts too.) replace and you should be fine.
Apr 07, 2009 | 1994 Buick Regal Gran Sport
Astro Pneumatic 7846 Harmonic Balancer Puller Set Logo
233 people viewed this question
Top Astro Pneumatic Air Tools & Compressors Experts
Trippy Tripp
Tom Chichester
Are you an Astro Pneumatic Air Tool and Compressor Expert? Answer questions, earn points and help others
