Question about Pioneer VSX-D409
Unit won't turn on.
My unit won't even turn on.
  • 4 Answers
Maybe the Power Transformer - see pioneerelectronics.com - replacement parts.
Posted on Oct 28, 2009
FAN WON;T SHUT OFF EVEN WHEN UNIT IS TURN OFF WINDOW UNIT
The switch may have rusted a bit and won't let the switch turn off. Sometimes a whack with the side of your hand might jar it loose and turn off. Or the switch is bad and needs replacement. You probably got it at Lowes. Ask them to suggest a good repairman.
Jun 14, 2014 | Frigidaire 5,000 BTU 9.7 EER 115 Volts...
Simrad Shipmate CP32 Chartplotter won't turn on - any suggestions
bad key pad rick or power on and off switch
Jun 11, 2013 | Boating
My whirlpool cabrio washer #wtw555oxwo won't work. The lid lock light keeps flashing and the washer won't start
Possible that the switch is defective, there is fault in the line to the control unit from the switch of the control unit is faulty.
check these one by one.
Sep 03, 2012 | Whirlpool WTW5550XW Energy Star Qualified...
It won't turn on and even if i plug it into the computer or a ciagrette lighter nothing happens. it was working perfectly fine when i was using it and now i have absolutely nothing. it kept saying low...
Have you tried pressing and holding the power button for about 8 to 10 seconds? It should go on then off. Then wait a few seconds the turn it on normally. This usually resets the unit.
If this does not work try a hard reset.
Press and hold (and continue to hold) the bottom-right corner of the screen while powering the unit on.
Continue to hold the screen until the "Do you want to erase all user data?" prompt appears.
Press "yes" and the unit will reboot. This resets all your location settings and user preferences.
If possible after the hard reset, let the unit sit outdoors in the open for about 30 minutes or so to let the unit re-acquire the satellite data.
Once it gets going update your gps at the Garmin site.
Thanks for using FixYa
Here is a link to the owners manual if needed.
http://www8.garmin.com/manuals/3130_OwnersManual.pdf
Jun 30, 2011 | Garmin nuvi 1450 GPS Receiver
Ps3 blink yellow then red and wont turn on
Yellow Light of Death. Call Sony at 800-645-SONY. My local repair shop won't even touch YLoD. If your unit is out of warranty, Sony will offer to exchange it for a recertified unit for $99.
Jun 17, 2011 | Sony Playstation 3 (PS3) Console
My fridgedaire window unit A/C and heat won't come on. I had replaced an outside light fixture a couple of weeks ago and had turned off the circuit breaker that affected this unit too. Now the unit...
Plug a light into the outlet used for the A/C, if the light does not come on when reset then the circuit breaker that provided the power to the outlet need to be reset or replaced.
May 22, 2011 | Frigidaire FAS257S2A WallWindow Air...
We used the master built turkey fryer just once after we took turkey out it will not turn back on
That is usually a problem with placing the heating unit into the bracket correctly. If is isn't put in properly the unit won't even power on. You may need to take it off and on several times to get it right.
Jan 02, 2011 | Masterbuilt Turk-'N'-Surf's Turkey Fryer
Jensen VM9410 - Stopped Operating All Of A Sudden
Sound like to me you got a problem with the capcitor inside the unit, if its under warrenty it will need to be serviced. If its not I ould be checking capcitors inside to make sure there not bulging leaking or otherwisen ot wroking correctly.
Jun 24, 2009 | Jensen VM9410 Car DVD Player
Fritzed Unit when antenna up
I have a similar problem but I can't turn the GPS off at all, even when the antenna is down. As far as the power on/off cycle, I found another link on this site that said to turn off WAAS while the GPS is off then when you turn it on the unit will not power cycle continuously. You loose the WAAS feature but the GPS and unit still works.
Jan 24, 2008 | Garmin iQue 3600 GPS Receiver
Open Questions:
Pioneer VSX-D409 - Remote Control Problem Hello. I'm from Brazil and I have a 12 years old Pioneer VSX-D409 Receiver. My problem is related to the page 16 and 17 of the Owner's Manual. I'm trying to do the steps to Set up the surround mode, changing some settings and the type of connection I use to delivers sound to receiver, using optical cables. Well... I just cannot enter this mode, the surround setting mode. At this moment I'm hearing the sound from a FM station on the speakers. But just this function works. Tuner, wiht FM station. The remote control works only to: - Turn on or off the receiver. - Change the volume level. - Set the loudness function (on or off). - Change the function of the receiver (to select Tuner, DVD, TV or other device in, but I don't gain access to change some specs like distance, speakers volume levels or type of connection of each device). And nothing more. The remote control has seven buttons on the top: DVD/LD, TV/SAT, VCR/DVR, CD, TUNER, CD-R/TAPE/MD and TV CONT. According to the source device you want to use, you just press the button and the receiver selects the IN connection (coaxial or optical or just the Tuner to listen FM stations) and reproduces the audio. Until last week, anytime I press this button, the source device was selected. But, of course, I didn't use all of them. Just two: TV SAT and DVD. Why? This receiver has two optical IN units on its backside. I have two optical cables connected in the receiver. Optical 1 is connected to a PS3 and Optical 2 is connected to a SmarTV. Before my hollyday's trip, all the connections were allright. But not today!! The problem is: I do not have access to the process to change the type of connection that is assigned to the device I've choosen. I want to do this: TV/SAT --> OPT1 (to the audio from PS3); DVD --> OPT2 (to the audio from Smartv); The process is described at the page 16 to 21 of the owner's manual. But, it doesn't starts. Seems my remote control just forgeted how to do this or is blocked in another function. I don't know how to fix it and need some tip or help. Thank You! :)
Jan 07, 2014 | Pioneer VSX-D409
See all Pioneer VSX-D409 Questions
Pioneer VSX-D409 Logo
67 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
