Question about Vivitek Televison & Video
T.V will automatically turn on and off during the first 10 minute
When I initically turn on ht t v it wil fturn off and within a ew minutes continue to do it again. Reccently it has gontten worse. The lamp light and th LED lights fliker back and forth.
I;m not sure if the bulb is on the way out. I pulled the bulb out and it seems to be okay. the buld lens is clear..
    Novelist:
  • 135 Answers
With projection TV's the lamp is usually the cause for cycling issues. The lamp power supply (ballast) monitors the current drawn by the lamp and adjusts voltage to keep the current at a specific value, if the ratings fall outside of spec the TV will cycle power and attempt to correct the anomolie. If this happens too many times within a specific time frame the TV can refuse to turn on and will indicate an error code. Don't put the TV through too many retrys or you could damage the ballast too.
Lamps can cost between $200 and $400. The ballast can cost anywhere from $150 to $250 approximately. Usually the manufacturer of the TV will sell you a new bulb, but electronics suppliers often sell them for less. Most lamps are owner replaceable and easy to do, consult your owners manual.
In-home servicers can base their labor charge on the size of the TV. The larger the TV, the higher the labor cost. Do it yourself and save!
Hope this helps.
Posted on Feb 15, 2009
How do I get the fault codes up on a Panasonic split air conditioning system CUE24FKR
14.2.2 To Make a Diagnosis1 Timer LED starts to blink and the unit automatically stops the operation.
2 Press the CHECK button on the remote control continuously for 5 seconds.
3 "- -" will be displayed on the remote control display.
Note: Display only for "- -" (No signal transmission, no receiving sound and no Power LED blinking)
4 Press the TIMER ? or ? button on the remote control. The code "H00" (no abnormality) will be displayed
and signal will be transmit to the main unit.
5 Each press of the button (? or ?) will increase error code
number and transmit error code signal to the main unit.
6 When the latest abnormality code on the main unit and
code transmitted from the remote control are matched,
Power LED will light up for 30 seconds and a "beep" sound
(continuously for 4 seconds) will be heard. If no codes are
matched, Power LED will light up for 0.5 seconds and no
sound will be heard.
7 The breakdown diagnosis mode will be canceled unless
pressing the CHECK button continuously for 5 seconds or
operating the unit for 30 seconds.
8 The LED will be off if the unit is turned off or the RESET
button on the main unit is pressed.
Diagnosis
display Abnormality / Protection control Abnormality
Judgement Emergency operation Primary location to verify H00 No abnormality detected - Normal operation H11 Indoor / Outdoor abnormal communica
tion > 1 min after starting
operation Indoor fan operation
only • Internal / external cable connections
• Indoor / Outdoor PCB H14 Indoor intake air temperature sensor
abnormality Continue for 5 sec. - • Intake air temperature sensor (detec
tive or disconnected) H15 Outdoor compressor temperature sensor
abnormality Continue for 5 sec. - • Compressor temperature sensor
(detective or disconnected) H16 Outdoor Current Transformer open cir
cuit - - • Outdoor PCB
• IPM (Power transistor) module H19 Indoor fan motor mechanism locked 7 times occurance
continuously - • Indoor PCB
• Fan motor H23 Indoor heat exchanger temperature sen
sor abnormality Continue for 5 sec. O
(Cooling only) • Heat exchanger temperature sensor
(detective or disconnected) H24 Indoor heat exchanger temperature sen
sor 2 abnormality Continue for 5 sec. - • Heat exchanger temperature sensor
(detective or disconnected) H27 Outdoor intake air temperature sensor
abnormality Continue for 5 sec. O • Outdoor temperature sensor (detec
tive or disconnected) H28 Outdoor heat exchanger temperature
sensor abnormality Continue for 5 sec. O • Outdoor heat exchanger temperature
sensor (detective or disconnected) H30 Outdoor discharge air temperature sen
sor abnormality Continue for 5 sec. - • Outdoor temperature sensor (detec
tive or disconnected) H33 Indoor / Outdoor wrong connection - - • Indoor / Outdoor supply voltage H38 Indoor / Outdoor mismatch (brand code) H50 Ventilation motor abnormality 7 times occurance
• Ventilation motor H51 Nozzle lock abnormality 2 times occurance
continuously - • Nozzle H52 Limit switch abnormality - - • Indoor PCB H97 Outdoor fan motor mechanism locked 2 times occurance
within 30 minutes - • Indoor PCB
• Fan motor H98 Indoor high pressure protection - - • Air filter dirty
• Air circulation short circuit H99 Indoor heat exchanger anti-freezing pro
tection - - • Insufficient refrigerant
• Air filter dirty F11 Cooling / Heating cycle changeover
abnormality 4 times occurance
within 30 minutes - • 4-way valve
• V-coil F90 PFC control 4 times occurance
within 10 minutes - • Voltage at PFC F91 Refrigerantion cycle abnormality 2 times occurance
within 20 minutes - • No refrigerant
(3-way valve is closed) F93 Compressor rotation failure 4 times occurance
within 20 minutes - • Compressor F95 Cool high pressure protection 4 times occurance
within 20 minutes - • Outdoor refrigerant circuit F96 IPM (power transistor) overheating pro
within 30 minutes - • Excess refrigerant
• Improper heat radiation
• IPM (Power transistor) F97 Outdoor compressor overheating protec
within 10 minutes - • Insufficient refrigerant
• Compressor F98 Total running current protection 3 times occurance
within 20 minutes - • Excess refrigerant
• Improper heat radiation F99 Outdoor Direct Current (DC) peak detec
tion 7 times occurance
continuously - • Outdoor PCB
• Compressor
Note:
"O" - Frequency measured and fan speed fixed.
The memory data of error code is erased when the power supply is cut off, or press the Auto Switch until "beep" sound heard following by pressing the "CHECK" button at remote controller.
Although operation forced to stop when abnormality detected, emergency operation is possible for certain errors (refer to Error Codes Table) by using remote controller or Auto Switch at indoor unit. However, the remote controller signal receiving sound is changed from one "beep" to four "beep" sounds.
Oct 13, 2017 | Panasonic Heating & Cooling
Coolant fan continues to run while van is off......
most modern vehicles have fans that can run for 5-10 minutes after the ignition has been turned off if the engine is hot.
if the fan runs for more than 15-20 minutes there may be a problem with the temperature sensor for the fan.
this would normally be located on the side of the radiator and is fairly easy to change.
if you need more detailed instructions on changing this then please feel free to ask, but if the fan turns itself off within 10-15 minutes then there is probably nothing to worry about.
Mar 30, 2011 | Chrysler Town & Country Cars & Trucks
I need to program a new fob. am reusing the old key! can you help?
  1. Turn the ignition to ON, then wait 10 minutes for the next step in the programming sequence.
  2. After the 10 minutes has elapsed, the car horn will chirp once. Turn the ignition switch to the OFF position within 5 minutes after the horn has sounded, then to the ON position within 5 seconds after switching it OFF.
  3. Leave the key to the ON position for 10 minutes . After the 10 minutes has elapsed, the car horn will chirp twice. Turn the ignition switch to the OFF position within 5 minutes after the horn has sounded, then to the ON position within 5 seconds after switching it OFF.
  4. Leave the key to the ON position for 10 minutes . After the 10 minutes has elapsed, the car horn will chirp 3 times.
  5. Verify that the security indicator in the instrument cluster has stopped flashing and attempt to start the vehicle.
  6. Turn the ignition to OFF and remove the key from the ignition switch.
  7. Move approximately 3 meters (10 ft) away from the vehicle and test the transmitter functions to validate that the transmitter has been programmed successfully.
Mar 30, 2011 | 2006 Pontiac GTO
It seems that the temp more often goes up to 20-30's and that food is not as frozen when I check it. When temp goes up I check it for next couple of minutes and usually within 10 min the temp is back down...
This is normal. All commercfial freezers must defrost 3 to 5 times a day, or they will freeze over at the coil and then stop freezing. A timer in your freezer turns off the compressor and turns a heating element on for 10 to 15 minutes. During that time the coil heats and melts frost from the coil. Usually within 30 minutes the temperature will briefly rise to 20 t0 25 degrees F and then quickly drop down to 0 degrees F. The food rarely defrosts in this short period of time..
Sep 01, 2010 | Turbo Air 23 cu. ft. / 651 liter...
I have a samsung HT-Q100 and its plays well but it will turn off itself after 45 minutes of playing time. I've check the back of the player and it heats up really hot( on the right of the fan at the back)...
If the fan is not providing sufficient cooling (it could be that the fan needs replacement), try placing a portable fan where it blows on the back of the unit. If the unit continues to work, you'll know you need to replace the fan within the unit.
Mar 07, 2010 | Samsung HT-Q100 System
My LC-26sh12u takes 10 minutes to
I had a similar problem where it displays "PLEASE WAIT" for several seconds alternating with blocky colors for several seconds and continuing anywhere from 5 to 30 minutes.
I inferred from a couple of sources that the TV is booting up when it says "please wait" by reading data from flash memory. I was able to fix my problem by resetting the data in memory to factory default values using this procedure from the service manual (wait until the TV is working before trying this):
Turn on the POWER.
Set the VOLUME to minimum.
Press both VOL. DOWN button on the set and Channel button (1) on the remote control for more than 2 seconds.
After the finishing of the initializing of shipping, the unit will turn off automatically
Nov 21, 2009 | Sharp Televison & Video
Trans shifts very hard after 5 minutes of stop and go traffic
A reason for hard shifting could be a problem with many things with various degrees of seriousness. It could be your ATF( automatic transmission fluid) is low or broken down and old. This would cause the hardness and the reason for stop and go traffic effecting it. Another possibility is your transmission is just shot, and the timing gears inside are worn and not properly shifting at the correct RPM causing a **** during shifting.
Some possibilties, not all!
~Lucas
Mar 27, 2009 | 2003 Buick LeSabre
TO noggin
remove all pwoer connector from motherboard and short green and black wire in supply shocket.If supply is run then it is the problem of motherboard.
Feb 28, 2008 | Dell - NPS-200PB-73M (NPS200PB73M) Power...
Err Err err err err pau
Press "stop" & "cancel" together for over 10 seconds to clear the display; and continue your..........
And rate me pl.......
Nov 15, 2007 | Frigidaire Affinity ATF7000E Front Load...
Self diagnostic will complete automatically in 10 minutes
Problem for Brother MFC-7420 All-In-One Laser Printer Self diagnostic will complete automatically in 10 minutes
Aug 01, 2007 | Brother MFC 7420 All-In-One Laser Printer
Televison & Video Logo
103 people viewed this question
Top Vivitek Televison & Video Experts
Jim Goldsmith
Jim Goldsmith
matt martin
matt martin
Are you a Vivitek Televison and Video Expert? Answer questions, earn points and help others
