Question about Samsung HP-R5052 50 in. Plasma HDTV
Samsung PS-50Q7HD Plasma working fine then picture went off.
Picture went off. If I turn TV off then back on picture works fine for a few minutes then goes off again.
Any ideas or help appreciated
  • 20 Answers
SOURCE: Samsung Plasma 42" TV - 2006
Hi, this is quite a common problem for plasma screens and LCD screens. The fluroscent backlight is more than likely faulty and would need replacing. The best thing to do is to take it to a service centre because there are no user servicable parts inside the plasma.
Posted on Nov 01, 2008
  • 1139 Answers
SOURCE: samsung plasma ppm42s3 , picture wobbling,sometimes screen goes blank
Hello arunaik_6,
This looks as if a component has become thermally sensitive. The best way to find this is to use component cooling spray. It looks as if the problem is localized to the tuner section. Take the back off of the TV and turn the TV on, wait until the problem occurs and lightly spray the tuner section with the component cooling spray watch for any reaction, then if this does not work spray the Microprocessor and the LVDS section and watch for a reaction. The set should go back to normal when it does that section is the problem, try to localize the problem to one component. Then replace that component.
I hope this helps,
Thank you,
Posted on Dec 16, 2008
  • 5 Answers
SOURCE: samsung plasma - no picture
check the power supply board for blown/bulging capacitors
you should see 4 bad ones on the top left
Posted on Jun 13, 2009
  • 111 Answers
SOURCE: Samsung 50in Plasma tv picture issues.
buffer board needs replaced need to replace both
Posted on Feb 04, 2010
  • 335 Answers
SOURCE: Please can you help me
If your using cable as your input signal see if the TV also does this when using a DVD player or game device. This way you will know if its the TV doing this or your input signal causing the TV to respond in a faulty way. If it is the input signal causing this then adjust the 1080i settings make sure they match what the TV is set too. If the TV does this on any input signal then there's a problem on the xy-sustain boards. This problem is easy to service at a repair shop and shouldn't cost much at all to replace sustain boards....
Posted on Nov 12, 2010
My Panasonic plasma Tv does not have sound. How do I fixed that
Sound no picture on 50 inch samsung plasma ps51d450a2m - HDTV ...
Jul 1, 2015 - 4 posts - ‎3 authors
There is sound and no picture on plasma tv, remote works at times but ... My pioneer elilte has this mode, and it is pretty easy to completely turn ... When I connect my Laptop to my TV thru HDMI cable I ...
Feb 22, 2015
Problems with blu ray player and plasma tv - HDTV ...
Nov 16, 2014
I do not have audio out on my tv how do i connect so ...
Dec 18, 2013
All channels on my tv have sound except channel 3 ...
Jun 29, 2010
More results from
No picture or sound in my Panasonic TH-P42UT30A plasma ...
Dec 07, 2015 | Panasonic Viera Th-50px60u 50" Plasma...
Red hues all over the images on screen
The TV is a plasma screen. There are several circuit boards that will go bad over time that affects the picture quality. TV Parts Universal TV Stands DLP Chips ShopJimmy You can get the parts here and replace those boards yourself.
Apr 10, 2017 | Panasonic TH-42PZ700U 42 in. Plasma...
Samsung PS-50C91H 50" plasma no picture
If this set has a cable box, satellite box or even a receiver hooked up to it remove power from them and the set for a while and power back to see if a reboot cures this issue.
short of that someone who is willing and knows how to check things is going to have to look inside and test things, repair if not what I have suggested consists of replacing boards which can either fix the set or not and gets expensive.
Dec 06, 2012 | Samsung Televison & Video
This is a Samsung ps-50q7hd tv which all the lights work but no picture has come on any ideas
Make sure the proper input is selected on the TV menu. Try other video inputs with different cables and try another device like a DVD player and see if you get video through that.
Oct 08, 2012 | Televison & Video
Feb 04, 2010 | Samsung PN-50A450P Plasma TV
Samsung plasma - no picture
Jun 12, 2009 | Televison & Video
Sound but no picture
You popped the plasma HV generator. Do you use a UPC all the time, if not then power line surges or brownouts can cause this type of problem. Needs Pro shop repair, expect around 450.00. PS: buy a upc for around 10 minutes run time $80.00 ??
Please rate!
Mar 30, 2009 | LG 42PC3DC 42 in. Plasma HDTV
LG DU-42PX12X Plasma, picture startes flashing then goes black after a few minutes
You need to get this tv service asap.i beleive that the problem is in the inverter board or yb board.
good luck
Oct 25, 2008 | LG 42PX5D 42 in. Plasma HDTV
Plasma tv
have 42in Magnavox plasma just over 1 yr old picture freezes
for about a minute still have sound then flashes off then comes back on does this about every ten minutes after the tv is on for
a while used to take hours before problem occured has always
done this
Jan 06, 2008 | Televison & Video
Samsung HP-R5052 50 in. Plasma HDTV Logo
324 people viewed this question
Jerry Greenberg
Jerry Greenberg
