Question about Toshiba CF32H40 32" TV
Horizontal line May 03, 2007 Toshiba manufacturer; Good day, my problem is a black screen with one horizontal line at the center of the screen. the power supply is good and the horizontal ic is also good sincerely yours; olao My Toshiba CF32H40 was working perfectly fine this morning, but having just turned it on (from stand-by) I now get a black screen with an extremely bright horizontal line in the center of the TV. My TV is 12 years old.
techman
  • 3130 Answers
SOURCE: No picture...Sound is fine.
There are no tubes, except the picture tube, to replace.. itys a solid state set. your problem is most likly thefiliment circuiut on the crt board, or maybe a verticle problem. I would say with A set of this ventage, will most likly cost to repair more then the sets worth.
Posted on Aug 28, 2006
  • 81 Answers
SOURCE: black screen in middle of picture
go tothe menu, caption, take it off the text mode. this should solve your problem
Posted on Apr 07, 2007
premtech
  • 934 Answers
SOURCE: a bright line on the screen
A line running across the screen like that and then returning to a picture I would guess is the vertical IC has some poor solder joints. The vertical IC in that unit IC401 is an LA78041 a seven pin IC that is mounted to a metal heat sink. On the foil or under side of the board take a careful look at the pins of that IC and any that look suspicious carefully re-flow some solder over.. Careful not to keep your iron on the pin too long.. And if have to re-solder several take some time between them to allow the IC to cool so you don't damage it.. Good Luck Bill
Posted on Jun 10, 2007
premtech
  • 934 Answers
SOURCE: horizontal line
Olao,
Your symptoms suggest that your vertical Ic401 has failed. In your Tv that Ic is a LA78040N-E Toshiba p/n# AE002783. Also it would be wise to test the feeder caps in that circuit, especially anything in the 100uf range.
This is not an expensive repair for a qualified shop. The Ic is under $20.00 dollars and caps are a buck or two - the labor will be your most expensive element of the repair and it shouldn't take an hour start to finish..
Hope this helps!
Bill
Posted on Dec 01, 2007
SOURCE: Toshiba 27D46 Black Screen - White Horizontal Line
I fixed the problem by taking it to a repair shop
Posted on Apr 26, 2008
2 days ago, a narrow black horizontal line appeared in the middle of the screen.
Samsung LN46B650 Thin Black Horizontal Lines - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - I'm experiencing thin black lines from the top of the screen to the bottom. ... my lcd tv has multiple lines are horizontal it starts from the right and fades too the left, ... Samsung LN55a950 - Horizontal lines on right side - Forums - CNET
Jun 11, 2015
Samsung 52" LCD TV black lines - Forums - CNET - CNET.com
Jun 10, 2015
More results from www.cnet.com
Plasma TV Repair Horizontal Lines - How to Diagnose ...
? 2:49
https://www.youtube.com/watch?v=h4XWCxUsSVU
Sep 2, 2014 - Uploaded by ShopJimmy.com
I have thin horizontal black lines on the top and bottom areas of my TV. .... Hi, I have a 2011 64-inch 3D Samsung PN64D8000 Plasma TV.
how to fix horizontal or vertical lines on lcd tv - YouTube
? 4:52
https://www.youtube.com/watch?v=k2QpYJp6MU8
Apr 12, 2014 - Uploaded by cr4zyw3ld3r
Hi my LG 47ln5700 tv set has thin greyish black horizontal lineson one side of the .... I hope this works good with Samsung LCD as well....
Dec 19, 2015 | Samsung HP-R5072 50 in. Plasma HDTV
Black screen with bright horizontal line through center
Your vertical IC may need resolder. You may have a bad capacitor or two that created an extra warm IC and create bad grounds. So resolder and check those caps near and around your vertical IC. If you continue to see this horizontal line you may have to replace the vertical IC. And you may as well check all grounds as well. Good Luck and be careful!
Jun 18, 2010 | Broksonic TV
Horizontal line in toshiba TVs
its the horizontal output IC
Feb 14, 2010 | Toshiba 28N33 28" TV
White, horizontal line in center with vertical striations.
55hdm71 plasma hitachi vertical lins 3 red on right side what do i do?
Oct 04, 2009 | Toshiba 42HP84 42 in. Plasma HDTV
The screen gets lines in it and then goes black, now it is just all black
sounds like a start up reley
or it could be a flyback
call the tech
Jul 30, 2009 | Televison & Video
5-inch black horizontal line across screen
Unplug the tv wait a minute .Plug it in turn it on see if that fix the problem. these tv are computers and can go hay wire.just like a computer ,some times a reboot will fix things for a while.make sure you have a good clean source of power at the receptical and your not having power spikes or drops . Good Luck!
Jul 28, 2008 | Toshiba 42HPX95 42 in. Plasma Television
Apr 24, 2008 | Toshiba 27D46 27" TV
Horizontal lines on Screen
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Feb 14, 2008 | Gateway FPD2275W LCD Monitor
Horizontal line May 03, 2007 Toshiba manufacturer; Good day, my problem is a black screen with one horizontal line at the center of the screen. the power supply is good and the horizontal ic is...
Olao,
Hope this helps!
Bill
May 03, 2007 | Toshiba MD20F51 20 in. TV/DVD Combo
Center screen convergence problem
The convergence adjustment on the TV set are for the center adjustments ONLY. if you cannot get them in or they are way out, then you have a convergence IC problem. Dont feel bad though as it happens to every rear projection set ever made. Good Luck
Dec 30, 2006 | Toshiba 53AX62 53 in. Rear Projection...
Televison & Video Logo
98 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
