Back to:
Tags:
Shuttle AK31 V3.1  Motherboard
AK31 v3.1 and Athlon XP1800 Which Heat Sink???
By herself - usenet poster
I just purchased the AK31 with the Athlon XP1800. The shop where I
purchased this installed a Volcano II heatsink saying the Volcano 6
would not fit. I am not really happy with the Volcano II. Seems to be
running hot. 50 degrees celcius with no real load. And i have great
flow through my SupeoMicro 750-A case. Which heatsink is the best, but
one that will fit with the chipset fan sitting so close to the cpu? My
old Slot A Athlon ran a cool 29 degrees celcius in the same setup.
Thanks for any suggestions.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 01, 2007
Not Rated (0)
Lizzy
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
I went back to the shop yesterday and explained that I was not
satisfied with the cooling of my processor. Of course they insisted
that the Volcano 6 would not fit, so I took one out of the box and
tried it on the motherboard on display in the store. The only problem
I saw was the fact that it sat really close to the chipset fan,
although I could slightly push the fan mount out of the way and it
worked fine. I had one of the techs come out and we looked at it
together and he seemed to think the same thing. It should be no
problem. Brought it home, installed it and it is cooling better but I
think I am going to get a bigger fan to help bring the temps down some
more before I try any overclocking. My board temps are 27 degrees
celcius and the processor is running around 42 degrees celcius. I
think a little stronger fan will help this even more. I am not really
worried about noise since my box is already noisy as it is! I have
installed some pretty serious case cooling fans to help keep the
internal temps down. Having 2 ATA100 drives, 3 SCSI drives, a DVD
drive and a CD burner my box gets pretty warm. That and a GeForce 3
and you can see where my concerns about heat come in to play. Thanks
everyone for the replies. By the way check out the Alpha cooler here.
I may get a wild hair and try on. Looks pretty massive!
On 3 Nov 2001 09:52:01 -0800, B_ (Ben Davis) wrote:
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on AK31 v3.1 and Athlon XP1800 Which Heat Sink???:
I don't want to Accept this solution
Solution #2
Not Rated (0)
pawa
Rating: 0%, 0 votes
I have the shuttle AK31 KT266A mobo and the athlon XP 1800 with the
Volcano 6cu heatsink/fan... whoever told you it doesn't fit has no
clue what they're doing! I also have the coolermaster ATC200
all-aluminum case which has 4 fans built in. this cools about the same
as StaticFingers' results
Thank You!
Solution #3
Not Rated (0)
Reynolds
Rating: 0%, 0 votes
The Volcano 6 Cu fits, I use one with the same cpu/motherboard combo as you.
I may add that of all recommended heatsinks for that CPU on the AMD site,
the Volcano 6 Cu is rated the quietest. [The Volcano 6 Cu+ has a faster fan
but produces much more noise.] However, if you do not find it quiet enough,
there are other solutions out there, and while they may not be listed on the
AMD site, they do work nonetheless. One solution is to replace the 60mm
Volcano 6 fan by a 60 to 80mm fan adapter + (of course) an 80mm fan. That
displaces the same volume of air per unit of time, with less RPMs (and less
noise). Others have simply slowed down their fans (usually by converting
their 12v input to 7v, or with a rheostat) while still having a reasonable
cpu temperature.
When my case temp is at 25'C, my cpu with the Volcano 6 Cu runs at 43'C.
That's under unstressful situations. If it gets more intense as I wear Max
Payne's shoes or join a Counter-Strike team, I go up to 54'C with my Radeon
8500.
For good cooling, a holistic approach is necessary: have a good case with a
good fan or two blowing the hot air out of the back. I also have frontal
fans, but my system's temperature only raises by one or two degrees when I
turn them off. Their real advantage is to push "clean" air into the box,
since I have a filter in front of them. Without the frontal fans, the air
penetrates inside the box from all holes and cracks without filtering.
I will probably not overclock my cpu, as stability and quietness are more
important to me. Besides, the 1800+ provides more power than I would have
wished for 6 months ago. :)
Ok. Good luck. And use your common sense. If you are planning of changing
the fan on your heatsink, you will have to remove the whole block from your
cpu, otherwise you could break the latter. I use Artic Silver II thermal
compound between my cpu and the heatsink, so it's easy to remove. You may
have some sticky stuff in your case, so others will have to help you here on
how to remove that safely.
Static Fingers
Thank You!
Solution #4
Not Rated (0)
Janice
Rating: 0%, 0 votes
Thermalright SK6. They're usually bundled with either Delta (best, if
you're very noise tolerant) or Sunon (slower but quiet) fans. See
#, etc. Heavy but fairly low profile for a
high-performence kit.
Brian Stretch # Cert. Technojunkie
"I fear all we have done is awaken a sleeping giant and fill him with a
terrible resolve"--Admiral Isoruku Yamamoto, after bombing Pearl Harbor
To our men in uniform and our allies: Good hunting. rm -rf /bin/laden
Thank You!
Solution #5
Not Rated (0)
Riddle
Rating: 0%, 0 votes
Volcano 6Cu fits just fine on mine. My case temp is 36C and my CPU temp is
50C on an XP 1800+
Thank You!
Solution #6
Not Rated (0)
Horner
Rating: 0%, 0 votes
I got a Swiftech MC462 to fit.
Elmo
Thank You!
Can you Help with these Motherboards problems?
Motherboards
I setup windows srever2008 but i can't find defintions for...
Motherboards
I took apart my sister's computer an XP and I'm having a...
Motherboards
hey i need help with my problem that im haveing with my...
Loading problems.
Repair Service
Find Motherboard Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
