Question about Dell 5100cn Laser Printer
Laser scanner on dell 5110cn laser printer, prints black smudges
Cleaned Transfer roller, replaced black toner cartridge, and replaced drum.
the problem cleared up a little bit, but there is still a ghosting image.
  • plittle81359
    plittle81359 Feb 16, 2009
    it prints the pager, with a residual image between the letters - horizontally.
  • 85 Answers
Replace fuser. How far apart is the ghost image?
Posted on Feb 16, 2009
  • Paul schanzer Feb 17, 2009
    try printing, then open printer before paper comes out of fuser. Pull paper out and see if problem happens before or after paper went through fuser.. Measure the distance between the ghost images. it provides info on the circumference of roller that is causing the problem
My Dell 5110CN seems like the printer is out of cyan. All the other colors look fine. Cyan is 60% full. I decided to try non OEM toner as the cost of toner has just gotten out of hand. I tried installing...
seems most if not all manufacturers have now made their machines so they only work with NEW OEM cartridges . Once installed they will not work if taken out . there is nothing we (consumers) can do about this .
Sep 13, 2017 | Dell 5110cn Laser Printer
Our Dell 5110cn stopped working and the 'diagnostic' said to replace the transfer roller. I had purchased a Dell Imaging Drum and replaced that. I believe it has a transfer roller as part of the Imaging...
Dell sells the drum & transfer roller a kit, but there are 2 different parts to it, the drum & the transfer roller & they do not look the same. Replacing the drum does NOT replace the transfer roller. We've had a 5110cn for 4 years, I've replace both of these parts & the fuser unit several times.
May 07, 2010 | Dell 5110cn Laser Printer
DELL 5110CN PRINTS PRINTS LIGHT GRAY NOT BLACK!
try to print test page and determinate which or colour is fainting. if it is one colour then you need to replace this colour image drum. If all of colors is fainting then its transfer roller.
Dec 29, 2009 | Dell 5110cn Laser Printer
My Dell 5110CN printer is printing a double image
I am having the same problem, and I am using the original toner cartridges that were supplied with the printer, so yes, they are genuine Dell toner cartridges.
Dec 27, 2009 | Dell 5110cn Laser Printer
Dell 3100cn printer leaves a blank strip
The following table should help
Contamination in the laser path - 1. Clean the laser path. (Remove the laser/scanner assembly and clean the lens.) 2. Replace the laser/scanner assembly
Defective fuser - Replace the fuser assembly.
Lack of toner or faulty toner cartridge - Redistribute the toner in the toner cartridge. If the problem continues, replace the toner cartridge.
Dirty Corona Wire - Clean the Corona Wire.
Defective Drum - Mostly applies to B&W printers. Clean the drum or replace the drum.
Sep 20, 2009 | Dell 3100cn Laser Printer
HP LaserJet 5200tn printer that doesn't print dark enough.
If that's okay, then these are the other possible causes:
Transfer roller is defective or incorrectly installed. If the
transfer roller loses conductivity, it cannot effectively pull toner from
the drum to the paper.Transfer roller is defective or incorrectly installed. If the transfer roller loses conductivity, it cannot
effectively pull toner from the drum to the paper.
Action 5
Inspect the transfer roller for correct installation and contact. If the transfer roller is damaged, replace it.
High-voltage connector springs are dirty or defective.
Action 6
The high-voltage connectors are mounted on and above the dc controller and protrude into the toner cartridge cavity. Check the springs for functionality. Clean if dirty, replace if defective or missing.
Laser/scanner door is not opening correctly.
Action 7
1. Remove and reseat the toner cartridge.
2. Check the laser/scanner shutter door for proper operation. If it is defective, replace the laser/scanner assembly.
The dc controller is defective. The dc controller contains the high-voltage circuitry.
Action 8
Replace the dc controller.
Mar 05, 2009 | HP LaserJet 5200tn Printer
Printing black smudges across the page at 10 cm intervals
Most likely cause by the drum unit. Replace drum or upgrade printer.
Jan 24, 2009 | Brother HL 1030 Laser Printer
Striped line down right hand side of printout
all parts are ok just clean the printer it will work
Dec 02, 2008 | Samsung CLP 300 Laser Printer
Dell 5110cn Laser Printer Problems
Have you replaced the fuser?
Have you replaced the toner?
Have you order a PM KIT? Most of these kits also comes with the fuser , transfer roller. or imager?
These items above should be replaced.
Jul 28, 2008 | Dell 5110cn Laser Printer
Pages full of toner / toner streaking
First off, this is a comment from a random person who may or may not know ALOT about these printers and toner/printer design in general. All toners are not designed to the same specification. Toner is a combination of plastic "pigment" and iron like shavings to make it magentically attracted to the electrical charges within the unit. Different toners conform to different grades and mainly size of the particles within the blend. The manufacturer doesnt only recommend that you use their toner to make them money, yes of course it makes money, but its because when the unit is designed it is designed to use a certain grade of toner, trust me if you put the non-branded toner vs the branded toner under a microscope you would see quite a difference. Often the non-branded toner is much larger in particle size (obviousely because its cheaper to make at this spec). This causes a variety of issues from excess toner not being cleaned off of developer rollers, IDT rollers, or clogging of toner dispenser tubes in the unit and the micro filters contained at the toner dispenser assy and developer assys. Also as for the issue not changing when switching to dell branded toner - the dispenser tubes within this unit contain up to 500-1000 pages worth of toner, making no change in toner you make immediately visible. Also depending on the damage caused by the previous toner, it may not be able to be fixed until all the components in between the toner and final delivery (drum cart) are replaced. In this case more than likely the toner dispenser assy, all developer assy's, and drum cartridge need to be replaced, and than be sure to stick with factory branded toner :)
Apr 26, 2008 | Dell 5110cn Laser Printer
Dell 5100cn Laser Printer Logo
1,086 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
