Question about Hitachi Televison & Video
Turn on tv speakers in unit
For years routed through receiver which died. How do I get the tv to use it's own speakers. Rear projection large older model.
thanks
trudi
  • Mark Egan May 11, 2010
    There is often a menu in the TV which allows you to turn the internal speakers on. You access by pressing the menu button on the remote, or through the menu button on the TV.
    Please reply what make and model of TV and we can possibly help you more.
  • Hitachi Master
  • 5,138 Answers
If what MrMark52 says, does not work replace Audio output IC.
Posted on Feb 16, 2009
Color looks white washed!!!
there are in the older rear projection sets lens for those that do not use a lamp for a light source.
In the older sets there are three large black lens that can be seen and reached with the rear cover off---if there clean them as they are the light source in those sets and if dusty picture will look dull and darker than it once did.
If in doubt shoot me a model number.
Dec 05, 2012 | Toshiba Televison & Video
Tip
Instead of resetting rear speakers each time.....
I have found a similar problem with the rear speakers on this unit (needing to be reset each time the unit was turned off), but found a quicker way around it.....with both the main unit off and the rear receiver off: turn on the rear speaker receiver, then the main unit. If the blue light on the rear receiver does not come on, turn off the main unit, and turn it back on again. This has worked for me ~50 times or so and has worked repeatedly. It's faster than going through the reset phase each time. Also when turning off the system, turn off the main unit first, and then the rear receiver. Sometimes I also simply leave the rear receiver on since it pulls only 4 Watts. Hope this helps any users.....(it also works on my boyfriends older generation model).
on Dec 28, 2008 | Samsung HT-WX70 Theater System
The question is not about the TV...which by the way is not the one listed. The one I have is over 10 yr old...I didn't see a listing for the one I have. My question is more general...what is the
A few answers: A home receiver can be a unit the signal and speakers and other units are all centrally connected to and the unit routes them to the set.
A strictly audio receiver processes sound and many of them have a amplifier either built in or external to boost audio to external speakers----Stereo units are one type and home receivers are another type.
Oct 21, 2012 | Panasonic PT-52LCX66 Projection Television
1 have a 6 year-old Mitsubishi model WS-48511 series 1080 rear projection TV that now won't turn on. A few days ago we shut the TV off, and now when i plug it in the blinking green power light...
This is called the blinking green light of death-----only one of two things can cause this problem.
First: remove front speaker grill (IT PULLS OFF) AND remove inspection plate behind it; look for the two bundles of wires coming down and to the right from the front keyboard of the set.
Unplug both plugs you find (different and marked so you cannot mix them up-----the idea is to take the front keyboard out of circuit-----set will still function with remote as receiver is behind front screen)
Try (after 70 seconds) to turn on with remote
If it comes on---defective reset button on front keyboard----use set only with remote or remove and remove actual reset switch---it is located behind and part of frame for screen----entire front screen would have to be removed to get at it.
Second: if disconnection of the front keyboard does not help, the DM unit is bad.
As you look from back of set it is large metal box at extreme left side.
The blinking light is the unit trying to "Boot" up-----these have a problem where caps and a few other parts in that unit fail-----kits on the net are available----Mitsubishi no longer sells or services these units but PTS Electronics does repair them.
Let me know if you have questions and try disconnection of the front keyboard FIRST.
REGARDS, SD TECH
Jan 20, 2012 | Mitsubishi WS-55613 55" Rear Projection...
When I connect the tv to the stereo receiver the sound still comes through the tv in addition to the stereo speakers.
This condition sounds normal, often you need to turn off the speakers in the TV, via menu options on the TV.
Aug 17, 2011 | Hitachi 53UWX10B 53" Rear Projection...
Have an older model philips(1995)rear projection.the power light comes on green,i hear sound from the speakers,but the screen does absolutely nothing.i took the cover off and can see the lamps...
Ur tv projection lamp,when was the last time you replaced the projection lamp?Tv projection lamp was replaced last 1 1/2 or 2 years ago.The tv been on and used 4 or 5 hours a day.The tv projection lamp life it over.Require a new projection lamp.
Aug 18, 2010 | Philips Magnavox 9P6034C 60" Rear...
I have a Samsung HCN5529W projection tv. The
yeah plenty, on older rear projection t.v.'s the circuit boards tend to over heat as they get older. keep the t.v. off and unplugged. contact a local repair shop.
Feb 20, 2009 | Samsung HCN5529W 55" Rear Projection...
Phillips 42" Rear Projection
I would strongly suggest to use the funds towards a new TV. It's most of the time a domino effect between service of your set and the next issue. Generally, once there is a problem sometimes it can set off a ray of other problems. I'd suggest to go with a newer technology. Invest in something current like DLP or even LCD flat panels are great due to no burn in, and much more affordable then they used to be. Another thing to be aware of is that by febuary 2009 everything is going to be all digital. What does that mean to you? Or your current rear projection set? It means that you would have to invest in an expensive converter box that would switch the signal from analog to digital in order to get any signal. That is why you see an enormous drop in digital display prices within the past years or so, plus lots of online companies going out of business because they cant afford to compete with electronics anymore. I hope this helps. After seeing plenty of TV issues within my 7yrs of experience in selling digital displays online...I think this is a much better route to go! Take care and good luck!
Sep 13, 2007 | RCA P46924 46" Rear Projection Television
SAMSUNG PICTURE FREEZE (LOOKS BLACK&WHITE)
I have the same problem... It turns B&W
I can still hear the sound... however I can still turn the tv off when that happens
Aug 28, 2007 | Samsung HLN617W 61" Rear Projection HDTV
Televison & Video Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
