Question about Toshiba MV13M2 13 in. TV/VCR Combo
Need remote instructions for MV13M2
How do U put upper channels with in MV13M2. I do have a channel selector but no instructions. I do receive 2 thru 12
    President:
  • 846 Answers
I cannot find a manual anywhere online, typically on the remote there is a menu button. In the menu there will be an option to manually or automatically search for available channels. By selecting this it will go threw all channels 0-100 and save all the channels with broadcasts on them to your settings.
Posted on Feb 15, 2009
  • Quickfx PC Repair Feb 15, 2009
    If this helps out, feel free to leave a Fixya rating, and thank you for stopping by.
    Brigadier General:
  • 8,619 Answers
Hi
You need to go into Menu sttings>Channel Tunning then select band(UHF/VHF/VHF1) and then tune the channels
Please revert for further clarifications
  • Rylee Smith
    Rylee Smith Feb 15, 2009
    You can also do AUTOMATIC MEMORY TUNING which will help you save all the channels .Follow these steps :
    Press the MENU button.
    Press the SET/TR + or – button to select the
    CH SETUP mode, then press the ENTER
    Button.
    AUTO CH MEMORY mode, then press the
    ENTER button. The TV/VCR will begin
    Memorizing all the channels available in your area.
    Channel numbers will remain red until auto memorizing
    Is complete.
    Press the MENU button until the MENU
    Screen is cleared.
    Please revert for any clarifications.
    Thanks
    Rylee
How do I put this tv on channel one? The instruction on the new remote I bought says to put tv on 1 and I can't get tv to go to channel 1.
from what I understand all TV's start with #2 channel 1 is reserved for emergency freq. . ur instruction might mean put remote in TV1 mode instead of TV2 mode , incase it is like a dual remote..
Jan 14, 2015 | Televison & Video
Channels
Check your cables and then move the channel selector through all settings a couple of times. This will give some indication of the real problem. If the channel comes back after exercising the channel selector, then you have a "Furred up" selector. If the channel doesn't come back then you may have a failed amplifier in the amp.
Jul 21, 2013 | Panasonic SA-HE7 Receiver
I need to re-program my toshiba tv to get basic channels after i just had th cable box removed. how do i re-program it on the remote?
But u still have and pay for the basic cable service wright?Yes,just used the tv remote and push the remote menu button than go into the tv menu,go into Setup enter and go down and pick CABLE not AIR.Enter for the tv do scanning for cables channels.After finish scanning u will get all the basic cable channels.
Jul 13, 2011 | Toshiba MV13M2 13 in. TV/VCR Combo
My cb cobra 29 ltd problem is channel 1 is ok but channel 2 not receive
Did you have someone get on channel 2 to see??? Maybe channel 2 was quiet and channel one had better receive or noise.. You never know until you check it with another radio. That is NOT a common issue at all on those radios. Better off doing that test.
"WILDCAT" IN LAURELVILLE OHIO
35 YEARS OF CB FUN!!!
Dec 28, 2010 | Cobra 29 LTD CB Radio
Have a722 reciver uhf remote will not change channels onlly have picture from tv 1
kristinjacqu,
Your 722 receiver may be in single mode. This is the case usually when you have the same picture on both TVs and the remote won't function. On the receiver when it's in single mode, you will have a green light for TV 1 and an amber light for mode under the single box.
To put in dual mode, open the door on the right side of the receiver (the door will open to the right). Once open, in the upper left corner of that area you have a mode button (to the right of the power button). Press the mode button and the amber light will now illuminate under the 2 boxes. The blue light for TV 2 should also illuminate indicating the receiver is now in dual mode. This will separate the 2 TVs and you can now watch different channels on both TVS, plus the remotes will now work. I hope this helps.
Ray Calo
DISH Network
Nov 25, 2010 | DISH Network IR Remote Control
I chose the wrong channel on remote it took me to a Dish site whcih I chose to exit - when I did that my picture totally disappeared - could not get it back. It is fine on my other tvs - so I need to get...
Guest
Are you getting a snowy/blue/black screen on your TV? To get your picture back, you need to get the TV back to the correct channel or input. If the receiver is in the same room as this TV, the TV should be on channel 3/4 (normally 3) or an input setting depending on the TV. TV 2 (away from receiver) would be on channel 60/73. If you have the TV remote, put the TV on one of those channels. If you get a picture when the TV is placed on the correct channel, press and release the SAT button. This puts the remote back in SAT mode and will now operate the receiver.
If you don't have a picture, unplug the receiver for 10 seconds from the electrical outlet and plug back in. This will cause the receiver to reboot and re-acquire Satellite signal. i hope this helps.
Ray Calo
DISH Network
Jun 30, 2010 | DISH Network IR Remote Control
Eurovox Max V -codes required for basic channels on Chorus Dublin
Then you don't need codes. It won't amplify the signal and if it's weak it won't receive all the channels.
Sep 15, 2009 | StarTech.com StarView SV211K 2-port KVM...
How do you get to the set up menu w/out a remote
hold down vol down on the remote and push 1 on the universal remote. this should turn your tv off and reset it to factory defaults alowing acess to all cable channels
Jan 08, 2009 | Toshiba MV13M2 13 in. TV/VCR Combo
I have purchased the converter box to receive digital signals and my tv doesn't have the red/yellow/white connections. Is there a model of converter that will work on this tv which is an RCAModel F25423...
THE CONVERTER BOX HAS R.F. OUTPUT. JUST HOOK IT UP AND PUT THE T.V. ON CHANNEL 3.(OR WHAT EVER THE INSTRUCTIONS THAT CAM WITH THE BOX) YOU WILL NEED TO CHANGE THE CHANNELS WITH THE REMOTE THAT CAME WITH THE BOX. YOU MIGHT NEED TO SET UP THE BOX (SCAN FOR CHANNELS) THAT IS ALL IN THE INSTRUCTIONS THAT CAME WITH THE BOX.
DON.
Jun 15, 2008 | RCA Televison & Video
Toshiba MV13M2 13 in. TV/VCR Combo Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
