Question about D-Link 802.11g Wireless Router WBR-1310 (WBR1310)
Getting into wbr dlink1320 router
Just wondering how i get into router to chage settings,thank in advance
  • hoog70 Feb 16, 2009
    thanks for all the help
  • Mark Egan May 11, 2010
    If this is your router and you are attempting to access the setup screens, go to the DLink website and you can download the manual. I just checked, and there are 3 different manuals, depending on the specific version you are working with.
    Scholar:
  • 54 Answers
Ok...
its easy to go to the router screen...
in you computer go ahead and click on start and then click on run,type in cmd and hit enter,
a black box will appear in that box type in ipconfig and hit enter,you will get a list of result,
from those result check the default gateway the default being 192.168.0.1,but it might be different
according to the connection and the setup,once you get this,close the box and double click on the internet explorer,
go ahead and type the default gateway in the address box without http or www,once you hit enter it will tell you to put in the user name and password the generic username is admin and the password blank.
once you hit enter you will be able to login to the router page and change the settings,you will see different tabs
what i can suggest you is before you go ahead and make any changes make sure that you know what you are doing as it might interrupt you internet settings and the internet might be lost...
the screen would look like this here is an attachment below..just check it and also what you can go is go to dlink website and download the manual so that you can get an idea about the different tabs and where you can go to change a particular setting...
http://support.dlink.com/downloads/ = this is the link what you need to do is to put the model number of the dlink router and it will take you to the page where you can go ahead and download the manual..
Posted on Feb 16, 2009
Trying to set up my wireless router
Here is a direct link to show you how to setup your router simply click product manual and it will auto download it for you thank you have a good day.
http://www.dlink.com/products/?tab=3&pid=WBR-2310&rev=WBR-2310
Jan 14, 2011 | D-Link RangeBooster G WBR-2310 Wireless...
How do i change my nat type on the D-LINK WBR 1310
Hi, I just want to know why you want to chnage the NAT type of your router?
My suggestion is instead of changing the NAT type of your router, just open a port. or enable the DMZ on the router.
Aug 13, 2010 | D-Link 802.11g Wireless Router WBR-1310...
Advanced Tab will not load
Try cleaning yours Internet Browser Cache, and also try different internet browser.
Apr 19, 2010 | D-Link RangeBooster G WBR-2310 Wireless...
Problem accessing my D Link WBR2310 Router
Are you trying to connect wirelessly?
You should try connecting your PC to the router directly using a network cable first of all. Then check settings, password protection etc.
Now unplug and try to connect wirelessly.
Mar 15, 2010 | D-Link RangeBooster G WBR-2310 Wireless...
I am having problems with downloads with my WBR-2310 Dlink Router. The downloads are much quicker without it in line. How can I fix this? Do I need to make some type of parameter change within the router...
Yes check this settings in your Router Setup Page.
In your D-Link Setup Page.
Go to Advanced Tab > Advanced Network
Check the following :
Enable UPnP
Enable Wan Ping Respond
( Wan Port Speed - set to Automatic )
Enable Gaming Mode
Enable Multicast Speed
Save the changes.
Jan 24, 2010 | Computers & Internet
Dlink wbr-2310 router no wireless working
you have to change your channelk type in your wi fi router.
For that access your router with following link
http://192.168.1.1 or
http://192.168.0.1
if you have belkin router
http://192.168.2.1
type user name as "admin" and password is "admin" or blank or "password"
then go to wi fi ->advanced setup chang channel type 4 ,6 ,11
change chanel type 1 by 1 and check signal strength.
everyt time save settings and restart both computer and router after save settings.
Thanks for using fixya.
Please rate this solution if it helps.
Jul 23, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
I have to setup the MTU to 1386 on a router Linksys WRT54GL in order to amke it work with my XBOX
Get the manual here and at chapter 3 on advanced settings it says how to change MTU values.
http://downloads.linksysbycisco.com/downloads/WRT54GL_V11_UG_C-Web.pdf
Jul 05, 2009 | Gateway Wireless-B Router (wbr-100)
How to set up vonage my wbr-2310 router and 2wire ATnT modem
2wire routers will only work with another device (router) if you will set it up to bridge mode. you need to go to the ip address of 2wire and check the box to enable routing.
Mar 25, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
I forgot the username of dlink wbr-1310 wireless router
As an initial info try to do a hard reset on the unit, this process will restore the system into a original settings. you can find the reset switch on either on the left of right sight of your router.
or
you may visit this SITE to recover again your current password without erasing or removing the current settings made.
Reset Password.
Hope this idea helps you.
Thank you for using fixya.
Nov 20, 2008 | D-Link 802.11g Wireless Router WBR-1310...
IMac to host WBR-2310
I have the same problem with my dlink router MacBook Pro... I've tried everything to set up a secure wireless network and nothing works.
Jun 20, 2008 | D-Link RangeBooster G WBR-2310 Wireless...
D-Link 802.11g Wireless Router WBR-1310 (WBR1310) Logo
109 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
