How to get from standard TV to Cable TV?
I was watching cable TV and a friend came in to show me how to switch to VHS?DVD player. Now I can't get back to cable TV. I onlt receive 11 stations instead of 98 stations. I don't know what to press to get back all my cable stations. Please help?
  • Tim Babcock
    Tim Babcock May 11, 2010
    Does the back of your tv have av input lines colored yellow, red, and white?
    Sergeant:
  • 227 Answers
Should use remote to bring up the menu. Go to channel search and it will ask you if for ant or cable. This is where you will select for antenna or cable.
Posted on Feb 15, 2009
How to connect dvd player to tv
    1. If so you can get yourself a component cable and connect the DVD player to the TV using those plugs. Otherwise, you will need to get an RCA to HDMI converter.Nov 23, 2015
      Connecting old VHS/DVD Player to my Smart TV - Tom's ...
      www.tomsguide.com/.../id.../needed-connecting-vhs-dvd-player-smart.html
    Feedback
  1. 5 Easy Ways to Hook Up a DVD Player (with Pictures)
    www.wikihow.com/Hook-Up-a-DVD-Player
    wikiHowHooking up a DVD player to your TV will give you access to countless hours of movie-watching bliss, and most modern TVs and DVD players make the setup ...‎Setting Up your DVD Player - ‎Connecting with an HDMI Cable
    How to connect a standard DVD player to a TV - YouTube
    ? 2:57
    https://www.youtube.com/watch?v=8pARHjY8xoo
    Jul 5, 2011 - Uploaded by All About Home Electronics.com
    Lol I used my standard AV cables for the component, and I used an adapter to plug the audio into my speaker ...
Dec 30, 2015 | Televison & Video
I have a apex tv and a dvd/vhs recorder, with a cable from wall only, how do I install
If you wish to record (VHS) off cable :
First connect the co-ax cable from the wall to the input on the DVD/VHS , then connect a second from the output of the DVD/VHS to the input of the TV.
You will need to match the channel (3/4) output and input. There should be a switch on the back of the DVD/VHS.
Tune the TV to channel 3 or 4 to match, To watch DVD/VHS .
Channel selection will be with the DVD/VHS when it is powered on.
TV will tune to channel when the DVD/VHS is off.
Jul 06, 2012 | Televison & Video
Using your DVD-V4600, how do you play a vhs tape on TV? Need step by step instructions.
In order to watch either DVD or VHS on your TV ,you need to make the following connections ..
  • You need to connect "DVD Player / VCR Combo" to" TV " as (Audio/video output of DVD Player / VCR Combo -TO- Audio/Video input of TV) ..
  • use either "RCA analog (red/white +yellow ) " or "SCART "or "Optic " cable.(any standard optical cable )...if exist ,optic is the best way to connect it..Remember your DVD Player / VCR Combo 's "OUT" goes into" IN "of the TV ..
  • pls also remember,wherever you connect your DVD Player / VCR Combo on your TV ,you should switch the source selector accordingly to correspond to the connection on the back...
Hope this helps!..if more help requires pls let me know.
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to continue f
or Helping out the Community :)
Jun 30, 2011 | Samsung DVD-V4600 DVD Player/VCR
Have connected cable (white, yellow, red) from Conia DVD player to TV as component 1 and connected Sony VHS cable (white, yellow, red) to TV as component 2. What other steps need to be taken for the...
component video needs Red, Green, Blue to be connected on the DVD end and to the TV for video to display, also the Red and White audio out needs to be connected to the TV for audio to work .
VHS has Red, White an yellow for Right Audio, Left Audio and video respectively.
You need to switch the inputs on the TV to the corresponding Component and Video inputs. Most TV's have a source or Input button to switch between the inputs. simply press the button until you have the input you are looking for.
Mar 13, 2011 | Televison & Video
Can't get video on vhs sound but no picture, is it broken
I had the same problem, so I took it back to basics. Hooked cable into VCR/DVD player and another cable from player to TV. S cable too, plus red/white audio. Plays DVDs on AV1 and VHS on Channel 3 on TV setting.
Jun 30, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Can't see dvd on TV
how to hook up to watch dvds
May 25, 2009 | Sansui VRDVD4005 DVD Player/VCR
How can i connect the dmres15 to my cable box, dvd/vhs player
Yea I have the same set up and did the same thing as that your trying to do and what you have to do is run both the cable box and the VCR through your TV using the inputs. As well as a PS2 running through imput 3.
Hope I helped
Jan 30, 2009 | Panasonic DMRES15 DVD Recorder
Daewoo dvd install
  1. Be sure that your VCR is a newer one with at least one "line in" set of jacks in the back. Some have one in the back and one in front.
  2. Your DVD Player should have a video/sound cable with 3 connectors on each end. Otherwise get one or 3 single cables.
  3. Connect DVD Video Out to VHS Video In (yellow).
  4. Connect DVD Left to VHS Left (white).
  5. Connect DVD Right to VHS Right (red).
  6. Turn on your DVD and VHS.
  7. Your VHS should have a tuner setting for "L1" or "L2". Select whichever shows the DVD's video on the TV.
  8. Remember to select that input channel whenever you want to watch the DVD.
  9. When watching a DVD, if you have a blank VHS in the VCR, you may record what you are watching onto the VHS, just as if you were recording from cable.
Verify these steps and you should be good to go ;)
Apr 19, 2008 | Daewoo DVDS151 DVD Player
Hooking up a cd player
I'm assuming you mean a DVD player, not a CD player? 1. You can get an input splitter (basically an A/B switch for the cable), and connect to that, manually switching between the two sources. 2. You can replace the VCR and the DVD player with a combination DVD/VHS unit. Although it would seem logical, it is unlikely that you can hook the DVD player to the VCR, since the VCR will refuse to let the signal pass though it, as part of its MacroVision copy protection. (This is the same sytem that prevents you from recording DVDs onto VHS tapes.)
Feb 18, 2007 | Zenith B25A74R 25" TV
Televison & Video Logo
74 people viewed this question
Top Televison & Video Experts
