Question about Mitsubishi MS-A09WA Split System Air Conditioner
Split HVAC does not achieve requested temperature
This newly installed Mitsubishi air conditioner/heater fails to supply the requested temperature. It has run, at best 11 degrees lower than what is being called for.
Also, this unit is installed inside an apartment, with 2 windows acting as the air exchange sources. On a very cold evening the unit leaked so much water that there was ice built up all over the floor and part of the wall (a reasonably substantial amount, like 2 inches thick). My installer is getting no where with these problems.
Thanks for reading this.
  • 121 Answers
If is heating on outside temp must bee max 5 degree
Celsius.If leak inside unit then check drain hose.
Posted on Feb 15, 2009
Preset heat stuck at 63. I want to lower the temperature for a vacation
[PDF]PAR-30MAA - Mitsubishi Electric Australia
https://www.mitsubishielectric.com.au/.../IB_PAR-30...
Mitsubishi Electricand Mitsubishi Mr. Slim Air Conditioners. MA Remote Controller ..... Heat. 17 ~ 28 ?C (63 ~ 83 ?F). Auto. 19 ~ 28 ?C (67 ~ 83 ?F). Fan/Ventilation. Not settable. 13 ...
[PDF]PAR-31MAA - Mitsubishi Electric Australia
www.mitsubishielectric.com.au/.../par-31maa_ib_en.p...
Mitsubishi Electricand Mitsubishi Mr. Slim Air Conditioners. MA Remote ..... Heat. 17 ~ 28 ?C (63 ~ 83 ?F) .... Preset cooling temperature is higher than preset heating temperature.
My air recycle button just blinks. Also when i turn on the - Fixya
www.fixya.com/support/t26081705-air_recycle_button_just_blinks_also
6 hours ago - Not sure the heat pump is producing enough heat. Nov 04 ... Preset heat stuck at 63. ... Feb 05, 2016 ' Mitsubishi Electric Mr Slim E12C26426.
[PDF]MA Remote Controller Mitsubishi Electric PAR-21MAA ...
planetaklimata.com.ua/.../Mitsubishi_Electric/Mitsubishi_Electric_PAR-2...
Easy Maintenance Function (Only for Mr. SLIM PUHZ series) . .... 4.4.3 Automatic Cooling/Heating Display Setting . ... Monitoring the Operation Data by the remote Controller (for Mr. SLIM) .......... ..............48 . How to .... 63. 4.2 How to set rotation function(back-up function, 2nd stage cut-in function) . ... Preset temperature (. °C. ).
Feb 05, 2016 | Mitsubishi Electric Mr Slim E12C26426...
My panasonic air conditioner does not turn off when cooling
At what temperature is the thermostat?
The temperature should never be lower than 70?F (21?C) for the unit to operate properly. If your temperature setting is above 70?F, then your unit might have a problem with the temperature sensor that controls the "on/off" cycle on your unit. For that you will need a professional certified HVAC tech to inspect it.
Most people think that lowering the temperature to the minimum will cool the room faster, but that is not the case. Since HVAC units move the air at a specific rate, it can only transfer the temperature, thus cooling/heating the air, within those parameters. That's what the calculation for the BTU is for. Normally cooling/heating the room to the desired temperature should take about 1 hour, but some new inverter units can do it in only 30 minutes or so. Lowering the temperature constantly or even keeping it at the lowest setting may cause premature failure of the unit.
Aug 04, 2014 | Panasonic 36PEF1U6 31,200 BTU Single Zone...
Outside Ruud Achiever series fan not running. Furnace and thermometer are working but air conditioner will not come on. Please help- I'm hot :)
Hello Hottie,
start by verifying that the outdoor A/C breaker is in the on position. If it is then there is a problem inside the unit (most likely a split capacitor failure) and you should have an HVAC company help you out because that is HIGH voltage.
Sep 01, 2013 | Ruud UBHC Air Conditioner
Unit will heat only will not cool and how to repair
we have a split type gree aircon, with one (1) horsepower. it was just newly installed, around 6 months ago. we are just surprised that one when my wife turned it on, thru the use of its remote control, the indicator box on the aircon reads or flashes "F2". I detached the batteries of the remote control for severa hours and I also detached the power cord from the wall socket, but it was to no avail. it did not work. with "F2" on the indicator box, the aircon won't give cool air, it is just working like an ordinary fan. please help us.
May 17, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
HOW WE CAN SET THE SPLIT UNIT TO BE WITH POWER SUPPLY RECOVERY FUNCTION? I MEAN WHEN POWER SUPPLY TRIP AND RESET AGAIN WE WANT THE UNIT TO START AUTOMATICLY WITHOUT PRESS ON SWITCH
Here is a tip about Mitsubishi Air Conditioners and how to get the manuals forall of the Mitsubishi line. The manual include both troubleshooting andinstallation.
Mitsubishi Air Conditioner Troubleshooting and Repair
heatman101
Sep 15, 2010 | Mitsubishi Heating & Cooling
My daughter has Mitsubishi split type air conditioner, model MXZ-2A20NA. The problem is that one of the unit puts out more cold air than in called for on the remote resulting in a room temperature that...
Here is a tip about Mitsubishi Air Conditioners and how to get the manuals for all of the mitsubishi line. The manual include both troubleshooting and installation.
http://www.fixya.com/support/r5643983-mitsubishi_air_conditioner
heatman101
Aug 24, 2010 | Mitsubishi MS09TW Air Conditioner
My fan outside will not turn off. I have a Ruud Achiever 10 unit. I cleaned the coils on the unit outside and the filter for the furnace. The unit does cool.
Is the compressor also running or just the fan? If both are running, you've probably got a freon leak and the system isn't cooling properly so it runs continuously trying to reach the thermostat set-point.
If only the fan is stuck on, you've most likely got a stuck fan relay. Replacements are available at HVAC supply stores and most will sell to the public. Not a real difficult fix but BE SURE to pull the electical disconnect AND flip the breaker OFF before you attempt any repairs.
Jun 11, 2009 | Ruud Matching Split Air Conditioner
Odour from ac
There is a problem with heat pumps known as "Dirty Sock Snydrome". Research this on the web as this may be your situation. It is a smell produced by micro bacterial growth on indoor coil. Contact a local HVAC company for solutions if you determine this is the cause of odor.
May 22, 2009 | Hitachi RAS-09UH Air Conditioner
Installing a sump heater or cold weather use.
air conditioner can work at 0 deg C outside temp and you do not need a heater for compressor if is split system.
Feb 17, 2009 | LG LB1200ER Air Conditioner
Mitsubishi MS-A09WA Split System Air Conditioner Logo
339 people viewed this question
Top Mitsubishi Heating & Cooling Experts
andrew petersimes
ray gallant
Michael Youngman
Michael Youngman
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
