Question about Dell Inspiron 6400 Notebook
Laptop dell 6400 black screen
After i Power on my laptop i get a black screen...no post etc,,,just fan noise and LCD for cap num etc light up for a moment...sometime it also will intermitly deplays for moment and then goes off. . . Tried reseating all connecting on LCD side, plus motherboard side. Tried replaced DIMM to verify memory issue, still same problem.does not look like the back light is not comming on. Tried externel monitor and switching to it from function key...but no joy! ...Does this mean that the video board is gone bad and need to replay?
understand it could be the invertor, LCD, cable, motherboard....but because the external monitor is not waking...am i right in saying this? or is the external swithed of in the BIOS somehow!! Please help!
  • muller1974 Feb 16, 2009
    As i said....tried a monitor and it does not display....will cost to much to send to repair...so trying to pin point failure and replace with correct part....so my question was... is it my video board as the VGA connected monitor is not working?
    Novelist:
    Champion:
  • 256 Answers
Pause on the 'Power' button
Hold on the 'Power' button for at least 30 seconds, after taking out your system's battery and removing its AC adapter cord.
Reconnect your laptop
Once you hold on the 'Power' button for 30 seconds, reconnect your laptop to the wall power as pausing on the power button drains any static electricity causing the black screen.
Replace the battery
Mostly, a worn out battery causes the black screen of your laptop. You should replace it with a newer one.
Posted on Aug 10, 2011
Try plugging the laptop into a computer monitor and see if that works... if it does, then you'll have to send in your computer for repair
Posted on Feb 16, 2009
Press power button nothing comes up on screen, however, the num lock icon lights up and flashes, the caps lock icon also lights up. Dell Vostro 1510.
Copy and paste this link into your internet browser for the service manual for your laptop.
http://support.dell.com/support/edocs/systems/vos1510/en/SM/html/trouble.htm#wp1092170
The star icon (*) means flashing LED, the bold circle means on, the circle within a circle means off.
The LED's that they are referring to are the NUM, CAPS and SCROLL.
It appears that you have a problem with your LCD. Try connecting an external monitor to your laptop. If you get a display then your LCD display panel needs to be replaced. If no display then your motherboard needs to be replaced.
Apr 19, 2011 | Dell Vostro 1510 Laptop
Hi, i have a problem with my Dell Inspirion 6400, after replacing Motherboard laptop won't boot up, after pressing power button, all 3 lights comes up (caps, num and scrl lock) and than back off, power...
I would hook up an external monitor to see if the laptop is working. If it is working fine then you must have a connection problem where the LCD plugs into the motherboard. I am willing to bet it is the LCD cable mot seated correctly. If it does not work on an external monitor try switching the memory chips one at a time if you have 2. Everything you mention indicates it is booting but no video. Good Luck Phil
Feb 21, 2010 | Dell Inspiron 6400 Notebook
Monitor does not come on (screen is black) Wife turned off everything was fine now can't get back on. Is there some sort of lock on these units?
dear friend,
please do some activity to conform the problem in your laptop, veryfy while you are pressing the power button after some time, press the num lock or cap luck switch is it working means the light is blowing or not? are able to listen the windows start sound? then connect a external monitor and try to swict the vdo on it? if yes then it is the LCD problem and you need to change the LCD assembly. if no then try the following steps:
1: veryfy your adoptor light is glowing or not? if yes then go to next step, if no then replace the adoptor.
2: remove all the external connection, remove the battery from backsite. remove the power adoptor. press the power button for 2min. then connect the battery, adoptor and try... if no then follow below
3. then try to on the laptop by pressing fn+power on botton. try to refix the ram. is there any LED is glowing or not..........?if no then you need to change the mother board
Jan 19, 2010 | Dell Inspiron 6400 Notebook
Static noise and black screen
hi..
Based on what you are stating, could be power supply problem. Try replacing power supply adapter that Dell supplies. Go on Dell support page using your computer number and you can see if there are any manufacturers recall on the computer or the power supply...
Aug 18, 2009 | Dell Inspiron 6400 Notebook
Dell Inspiro 6400 not starting up
If the Num lock is lit constant, and the Caps Lock and Scroll Lock keys are flashing, the system is reporting a memory error. Power off the system, remove the battery, and follow the user manual from support.dell.com to reseat the memory module(s). If the error persists, you may need to replace the memory and/or the system board of the portable.
Mar 12, 2009 | Dell Latitude D600 Notebook
Dell inspiron 6400 screen problem
I had the same problem. You need a new graphics card.
Jan 08, 2009 | Dell Inspiron 6000 Notebook
Dell Inspiron 6400 Black Screen Problem
Flashing - ON -Flashing indicates a problem with the LCD. Reseat the LCD cable connection to the motherboard, then see if the problem is resolved. If not, disconnect the LCD from the motherboard, and connect and external monitor, see if the system posts normally (You may need to toggle Fn +F8 for external video) if it posts, the LCD/LCD inverter is bad. If it doesn't, the motherboard is bad.
May 10, 2008 | Dell Inspiron 6400 Notebook
Dell Inspiron 6400 Notebook Logo
229 people viewed this question
Alun Cox
