Question about Kenmore 52632 / 52634 / 52639 Side by Side Refrigerator
Beeps when you open door it beeps
  • 121 Answers
Read the manual.Too long open door or near is heating device.
Posted on Feb 15, 2009
Frigidaire refrigerator beeps every 20 seconds or so. three beeps.
try opening the door.leave it open.unplug the fridge for at least 5 minutes, no less,with the door still open.after that,plug it back in.wait for it to beep.then close the door.
this would reset the door alarm,which beepes when the door isn't properly closed.
also you should wait 24 hours between changing the temperature or it can mess up your fridge.!
Oct 13, 2016 | Frigidaire Refrigerators
Beeping sound
these are the things that cause beeping ... trunk open, door open any one of your 4 doors not closed properly will cause the beeping, seatbelt chime, lights on or key in ignition when door is openbut check all your doors
Sep 16, 2013 | 2007 Ford Crown Victoria
When I open the driver's door and take out the key from ignition, there is a constant beep different from the one I know and the dash board always flashing. What could be the solution.
The beeping sound is a warning sound that lets the driver know that a door is open and he shouldn't drive off. It is normal and nothing to worry about. Good Luck. george
Mar 30, 2013 | 2006 Mazda 3
I have a samsung side by side fridge freezer model SRS539HW, the alarm keeps beeping every minute to say the doors are open however they are closed. If I manually pust the door closer button it will...
Solved beeping problem.........Samsung SRS539HW . Have one of these and it is 6 years old. I had to replace the bottom hinge on the fridge side(right). Easy job but now constant beeping as if door is open, and light is intermittent. Found that there is considerable wear on the cable through top hinge of door and one of the wires from a magnetic reed switch in door had broken. I discovered this by shorting the two fine wires (white and pink/white) going to internals of fridge.No more beeping due to door opening and light now working correctly. Of course I no longer get a beep for a valid door open to long but cheaper than getting a refridgerator expert in.
Jan 13, 2012 | Refrigerators
Key in ignition, door open beep beep beep beep beep get the point very annoying
Take the key out of the ignition before you open the door. Thats to keep you from locking the keys
in the car.
Sep 07, 2011 | Toyota 4Runner Cars & Trucks
Kenmore elite beeps all the time
1 Beep/E10--Error: Water doesn't enter Cause: Water supply problem, Check kinks and faucets
1 Beep/E10--Error: Water leaks Cause: Water connections loose,household drain clog,oversudsing. Correct problems.
1 Beep/E10--Error: Dispenser drawer is open Cause: Washer will not operate if drawer is open.
2 Beeps/E20--Error: Water dosen't drain. Cause: Drain is kinked or household clog. Correct.
3 Beeps/E30--Error: Drum overfilled. Cause: Inlet valve,pressure switch or control board failure.Select drain/spin to remove water. Restart.
4 Beeps/E40--Error: Door is open. Cause: Washer will not operate if door is open. Close door.
5 Beeps/E50--Error: Motor is overheated. Cause: Wait 30 minutes to cool down. Restart.
7 Beeps/E70--Error: Cold water doesn't enter. Cause: Hoses crossed,faucet problem.
15 Beeps/EF0--Error: Oversudsing. Cause: Too much detergent,or improper detergent for machine.
15 Beeps/EF0--Error: Hot water doesn't enter. Cause: Hoses crossed,faucet problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Oct 05, 2009 | Kenmore Elite 45986 Front Load Washer
Fridge/freezer beeping
There is a lever switch usually above the door (when door is in open position) on the fridge cabinet. Not on the actual door. The beeping should stop if this lever is pressed. If the door is positioned correctly it would depress this lever when closed. It may be that the door adjustment is slightly out. If the beeping does not stop when depressed, then your printed circuit board (located usually above the door) is faulty and needs to be replaced.
Mar 04, 2009 | Refrigerators
Kenmore front load washer just beeps doesn't start error code says "lol"
Jan 04, 2009 | Washing Machines
Kenmore 52632 / 52634 / 52639 Side by Side Refrigerator Logo
56 people viewed this question
Top Kenmore Refrigerators Experts
Sal De GO PATS
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
