Question about HP Compaq Presario V6000T Notebook
SHIFT LOCKED ON
Can reverse to lowercase with cap lock but I can not get numbers to work or the other keys>
  • sgoodyear Feb 15, 2009
    It wasn't rebooting from the tool bar all the way. I powered off, took out the battery and then turned it back on and was fine.
  • sgoodyear Feb 16, 2009
    num lock was not on. I turned that on and off and that did not help.
    rebooting worked by taking the battery out.
    Master:
  • 474 Answers
There should be a function key that is a light blue on the lower left. Hold that down and hit the NUM lock key at the upper right.
What happened is that you turned the numlock on just like on a regular keyboard but on a laptop, its a secondary function key where the letters double as numbers when the function numlock is turned on.
give it a try and let me know.
Good luck
Posted on Feb 16, 2009
SHIFT KEY DOESNT WORK
You have two shift keys. Is the Caps lock key Locked?
Jan 03, 2014 | HP Computers & Internet
How i can unlock shift
If you are printing all CAPS then it is the Caps Locks key. It is located just above the shift key on the left side of the keyboard. There should also be a light on the laptop indicating the Caps lock is on.
Hope this helps
Jun 11, 2012 | HP Computers & Internet
How to change the uppercase and lowercase letters
Either by pressing and holding the shift key (on left and right of keyboard, looks like up arrow) while typing, or by pressing the CAPS LOCK key to put capitals on or off. The caps lock key is usually one above the left shift key.
If you cant find them just advise your make and model of computer and I could tell you exactly where the keys are.
Oct 31, 2010 | Computers & Internet
What is uppercase letter
What I am typing now is 'lowercase' letters. WHAT I AM TYPING NOW IS 'UPPERCASE' LETTERS. Use either the 'shift' or 'caps lock' keys on your computer keyboard to change between the two.
Aug 10, 2010 | Computers & Internet
I HAVE A LOCK WITH A NUMBER 1 ON AND CANNOT USE MY LOWER CASE KEYS> HOW DO I UNLOCK WHATEVER I HAVE LOCKED?
try pressing the caps lock key once, if still your caps lock key does not respond then possibly the key is stuck, try backing up your data first do a system restore when you think you can still use lower case on your keyboard then check if there will be changes, if still no changes occur, a long shot would be re imaging windows back to defaults again make sure you back up data first the then try again once windows is reinstalled if no changes then your keyboard works but the caps lock key is busted ^_^ I do not see any other option for the caps lock key to be troublshooted. ^_^
Jun 04, 2010 | Acer Computers & Internet
My gear stick is locked in park unable to push button in to get it in reverse
There is an electric lock selinoid that disengauges when you depress the brake pedel. Check fuses and switch at the brake pedel and check selenoid under the shift cover. There should also be a small oval cap you can remove with a sharp object by the shifter and slide your key into it to manually put the car in N. You can then remove your key and start the car.
Feb 07, 2010 | 2006 Hyundai Elantra
Letters are num locked. pushing num lock key does not resolve
Number lock, a situation where numbers instead of letters are typed is as a result of the digital lock being active. to deactivate pressing the Fn+Numlk or Fn + Shift +Numlk key combinatioins
Jun 18, 2009 | IBM Thinkpad 560 Series Laptop 20h4241...
CAPS LOCK PROBLEM!!! URGENT HELP NEEDED!!!!
On some keyboards, there's a hidden 'feature' where if you hit CAPS LOCK and Shift at the same time, everything works backwards, until you hit that combo again.
Try this and let me know if it pertains to you...
Dec 29, 2007 | Computers & Internet
My typing goes uppercase without hitting the caps lock
I have the HP Pavilion and cap locks does the same thing.
THIS WORKS EVERY TIME. Hit both the right and left shift lock simultaneously about 5 to 10 times. It immediately disengages the cap locks. It is a little bit of a hassle, but I'm just used to it. It may happen 3 times per week, but I LOVE the machine, so I just fix it this way!
Oct 20, 2007 | HP Pavilion dv8000z Notebook
HP Compaq Presario V6000T Notebook Logo
189 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
