Question about Ovens
Can't find the model number of my Electrolux electric oven
My oven has freaked up and is turning itself up to it's max of 350C instead of doing what I attempt to do (bake a cake at 180C).
I suspect there's a problem with the settings, but I can't find the model number anywhere.
Does anyone know where they might hide it (hopefully not on the back), or is the problem familiar?
Cheers,
Norway
  • royzee May 11, 2010
    Normally, if you open the door or pull out the drawer, if there is one, its hiding in a recess
    Scholar:
  • 87 Answers
Model number should be down on the bottom where you pull out the storage drawer either the left or right side. If it's not there it'll probably be right behind the controls on the back panel of the oven. There also should be a tech sheet in a plastic bag on the back of the oven when you pull it out. That might tell you how to convert it back to ferehite. Good luck.
Posted on Feb 15, 2009
Electrolux oven (model#EW30IS6CJSB, serial#NF21223301) top element won't turn off.
It would not be element bc it only works when supplied voltage. And obviously it works when supplied voltage. Whatever is sending voltage to the top element that shouldn't be is the issue. Such as control board
Sep 25, 2016 | Electrolux Ovens
Oven Switching Off
I have a few questions. Does the oven reach the set temperature? How do you get it to go back on? and if you do not set the time do you have the same problem?
Dec 06, 2007 | Electrolux EOB6632 Electric Single Oven
Why my ew30ew55gs5 have no heat and all the light and function work.
Electrolux Customer Phone Number Shortest Wait Best Support
  • Talk to a Human Press 2 then 1. For kitchen and laundry appliances
  • Call Time
    Average Wait: 37 mins - Monday-Saturday, 8AM-9PM (EST)
Electrolux Calls You Instead Electrolux Calls You Instead
I would contact them first before you waste any money.
Jan 21, 2015 | Electrolux 30" Built-In Single Electric...
Electrolux oven racks how do they go in oven?
Hi Friend, that's a great question!
I see that your post is listed under Electrolux Wall-Oven. May I have your model number please? You can normally find the serial tag (which lists your model number) on the front of the oven, on the left side, as you open the door. With this material I can provide you the correct instructions on how to place the racks in your Electrolux wall-oven. Thank you! - Z
Jul 20, 2014 | Electrolux 30" Built-In Double Electric...
My oven takes a very long time to warm up. Any tips.
Mine does too ...in bake mode (45min to reach 350c) ...although broil (which I hardly use) reaches max temp in 3min ...I'm assuming the lower element has worn out and needs to be change.
Jan 29, 2010 | Maytag 30 in. Electric Single Wall Oven...
I have an electrolux double oven eou 6330 the bottom oven element has broken.Can I buy and fit it myself as single female with very little spare cash?
Yes. You can do it. Part should be $40 or less.
Turn off the power to the oven. Remove the oven racks.Unscrew the element screws from the back wall of the oven. Carefully pull the element out. The wires may be short. Remove the wires from the element. Do not let the wires pull back into the oven cavity. Take the element to the appliance parts store and have them match it to the existing element. Attach the wires to the new element,insert the terminals into the opening,replace the mounting screws. Turn on the oven and bake away.
P.S. Your model number is not correct.
Nov 05, 2009 | Electrolux EOU6330 Electric Double Oven
Electrolux oven won't come on
It appears that the "return to manual" button has to be reset
Aug 25, 2009 | Electrolux EW30EW65SS Stainless Steel...
Electrolux cooler fan
absolutely, Never registers when the oven is below a certain temp to shut the fan off. It always thinks it's too hot and the fan will continue to run
Nov 21, 2007 | Electrolux EOB5630 Ultrafan Electric...
Oven heats up then switches off
there is an overheat stat in the oven which turns it off if overheating. the causes are several. 1 - oven thermostat is faulty and oven is reachingf too high a temp. 2 - there is a second fan in the casing to keep the casing cool. 3 - this second fan is turned on by a fan start stat which may be faulty and is not starting the cooling fan 4 - the overheat stat itself is faulty. it is a bit difficult to narrow it down from afar. get back to me if you want
May 19, 2007 | Electrolux EOB6636X Ultrafan Electric...
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you an Oven Expert? Answer questions, earn points and help others
