Question about Kenmore 62602 Electric Dryer
Kenmore 90 Series Model 11060912990 Dryer won't start
When pressing the start switch, dryer sounds like it wants to start (as long as you hold the start button in), but it won't start, and eventually it stops even trying to start.
-Terminal block looks fine
-Start switch tested fine - contnuity only when switch pressed.
-Door switch tested fine - continuity with light when door open, continuity with the other terminal with the door closed.
-Timer Motor tested fine - meter read about 2400 ohms
-Thermostats tested fine - continuity found in both
-Centrifugal switch tested fine.
1-2 5-6 5-3
Out Continuity Continuity Resistance
In Resistance Resistance Continuity
Anyone have any thoughts?
  • twscrap Feb 16, 2009
    What should the reading for the timer motor be? Also, any other way to confirm that the morot is the problem?
  • twscrap Feb 26, 2009
    Turned out to be the actual motor. Replaced it, and all is well with the dryer!
  • 121 Answers
Check motor (you have 2.4 Kohm ) very high read
for motor must be lower.Check capacitor if hawe.
Posted on Feb 15, 2009
  • dalibor skrbin
    dalibor skrbin Feb 16, 2009
    if have circuit diagram send me to see.
Where to find fuses. My dryer is not heating up.
Does your dryer have power? If yes, then check (1) the flow of air outside the house from your dryer tube and (2) your circuit breaker panel for each circuit in the house (I've not seen fuses/breakers built into dryers -- though that could change). Then check (3) your heating element, (4) thermostat, (5) high-temp thermal cutoff switch, and (6) for debris in the air flow path to / from from the centrifugal fan.
Here are 3 resources that helped me with my Kenmore Series 90 Dryer:
No Heat? - http://chris-doityourselfrepair.blogspot.com/2011/10/kenmore-90-series-model-110-clothes.html
Looking Inside My Dryer - http://chris-doityourselfrepair.blogspot.com/search/label/Disassembling%20Kenmore%20Dryer%2090%20Series
Exterior Exhaust Duct - http://chris-doityourselfrepair.blogspot.com/2013/08/cleaning-out-and-replacing-exhaust-duct.html
Oct 10, 2014 | Kenmore Dryers
My Sears Kenmore 90 Series takes too long to dry cloths
First you need to make sure that the lint trap is completely clean. I don't mean just taking the screen off and making sure there isn't lint on that. You need to take the cover off of the back of the dryer and remove the shute the lint screen slides into. That can be backed up and it's quite common. Also when that happens it tends to blow out the fuse that is located in the same general area. It's about an inch long, white, with two wires connected by plug on terminals. Make sure you unplug the dryer if you're going to check that. Remove the two wires and with an electrical tester check for continuity across the two terminals. If there isn't continuity you'll also need a new fuse, Hope that helps.
Mar 20, 2013 | Kenmore Dryers
My Kenmore 80 series dryer won't stay on unless I
Aha!
You are going to make me guess!
I am guessing you have to hold the start button down.
So.
Try a new start button first.
If that does not fix it, replace the timer/control unit.
God bless your efforts.
Jan 05, 2018 | Kenmore Washing Machines
Kenmore 90 series dryer..motor won't turn..hear the klicking sound..kind of hums...but won't turn. changed motor..same problem
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 11, 2011 | Dryers
Dryer doesn't always start, and doesn't keep running
your have a dieing dryer motor,weak weak to turn the drum anymore,the model number is inside the dryer door if you want to try and find one cheap on ebay-mike
Feb 23, 2010 | Kenmore Dryers
Kenmore dryer replaced heting element now it does not blow any air
HI danon this dryer its common to have the blower wear out, it slides on the motor shaft, and what they do is wear out the flat in the blower. that could have caused the element to fail. check the blower thanks the appliance doc. please rate my answer. thanks
Sep 30, 2008 | Kenmore 62602 Electric Dryer
Kenmore Dryer 90 Series will start but suddenly stop...
what starts and stops? the entire dryer or maybe the drum? Do you do anything to make it restart other than pushing the start button? This initially sounds like a temperature switch is opening and resetting after it cools. If you can describe the problem a little more in detail it would help.
Jan 27, 2008 | Kenmore 659 Electric Dryer
Kenmore 62602 Electric Dryer Logo
530 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
