Question about Pioneer AVIC-F90BT GPS Receiver
IRREGULAR FUNCTION THE BACK UP CAMERA KEEPS TURNING ON THE SCHREEN BUT I DONT HAVE IT HOOKED UP. WHEN I TURN ON MY TRUCK IT SAYS "CAUTION: THINGS IN SCREEN MAY APPEAR REVERSED", THENK I HAVE PRESS THE MAP BUTTON TO GET TO THE MENU SCREEN. WHAT DO I DO? I ALREADY TRIED RESETTING IT.
    Problem Solver:
  • 11 Answers
I had the same problem. Go to menu and then to av settings. click on the camera options and then make sure its not on the ground option. worked for me. good luck
Posted on Apr 07, 2009
My truck wont always start bought a new battery so thats not it auto zone said not getting enough air when it starts
Is the battery turning over the engine properly or is it barely cranking over? The main function of a battery is to provide the power to turn the engine over until the engine starts, then it's only function is to help regulate the voltage in your system along with the alternator. Will the truck start when you hook it up to jumper cables? If the engine is turning over properly and the truck not starting, the battery is not the problem. You then need check out other things. For a gasoline engine to run, it requires three things; fuel to burn, compression in the engine and a spark at the right time to ignite the fuel. You must have all three for it to work.
Aug 09, 2014 | 2005 GMC Canyon
My douchter have a kodak Easyshare C1013, and when i turn it on, i wil see a white lcd screen, making pictures is not a problem, but i can't see anything on the lcd screen (only white light).Camera is more...
this i a faulty lcd. if the camera have guarantee send the camera to the center. if the camera is falling down or you have make a pressure on the schreen., you must replace the schree. the lcd replacement is not so dificult if you have a eletronic knowledge.
if you go on the ebay international seller and isert your exact model you can find the lcd schreen to a low cost. the cost for a lcd is from 20 to 35 euro.to the china seller the cost is lower but the schreen comes in one month from china to uk.
if you buy the schreen to a european seller you have the lcd soon..but the cost is higher.
to rplace your schreen. go on you tube. and write exactly this.
you can find any videos..and you can find any of my videos.
write exactly this.
(lcd umtausch) so you can see very mutch videos of replacement of lcd. if you are lucky you can find the replacement of your specific camera model. so you can look and make the fixing alone. if you dont find the exact model..look more video possible. and you can see that the fixing is similar. if you have understand how you have to do.. buy the schreen on ebay and replace it. if you want help write me and i help you.
regards. please if i have helped you dont forgith to release your opinion. paolo italia.. sorry for my english.
Aug 10, 2010 | Cameras
It worked fine yesterday and now when i try to turn it on it will not power up, and it turned on one time and i turned it off thinking it was ok and now wont go back on
to thirst. control the batterie. if its good. why if the batterie is old its possible that have problems-
if you have new batterie ore 2 or 3 batterie prove with the other.
control that the camera when turned off...dont write on the schreen lens problem, or example the write on the schreen turn camera out and another one up. if the camera dont have received pressure or dropp,
if the camera says lens error this is a problem with the lenns bloc... but to first, prove with a new batterie and clean the internal contact of the camera with alcohol and one cotton fiocc. pull the batterie out clean the internal contact wayth that the alcohol are completly evaporated, and reprove. good luck
Jun 01, 2010 | Polaroid i1237 Digital Camera
Dark screen
have you prove to pic fotos. if the camera make fotos,and memorize on the card, but you cant see the foto in the camera schreen this is only a lcd defekt, you must prove if the lcd flat is right connected. if the camera dont pics foto, the problem is in the ccd. you must change the ccd. allor. memorize fotos and you can see trhe foto on your pc...lcd problem contact failure ore lcd faul to change. if the camera dont pics foto...ccd failure to change the ccd.
May 30, 2010 | Canon PowerShot A95 Digital Camera
When I try to turn on my tv it just keeps turning back off
It may be the problem of your transformer. It can get damaged due to irregular voltage supplies or lightnings etc. Try replacing it. It will be cheap. Have the product of the best company available as it can cause trouble later otherwise.
Apr 07, 2010 | LG 32LG30 32 in. LCD HDTV
Pioneer DEH-P3100UB car stereo keeps turning off and on again
broken wire, or dirty connection....oh check your ground wire for radio...
Jan 04, 2010 | Pioneer DEH P3100UB Car CD/ MP3 Player
Can't remember how to turn off the power save function
The auto shutdown is designed to protect the tape and heads. If you want to use it as a web cam, just remove the tape.
Apr 03, 2009 | Canon ZR60 Mini DV Digital Camcorder
No interior lights or power mirror working.
The fuse for the interior lights has a yellow plastic holder
covering it. Full the holder all the way out, fuse and all, with a needle nose pliers.
Replace the fuse. Disconnect the power to the radio you put in before you do this. Replace with new fuse. Check lights. If light work, plug in radio. If fuse blows, radio connection is bad (grounded hot wire). Fix wiring, replace fuse, and try again.
You could also have messed up the multi-function switch
(turn signal switch). EVERYTHING go's through this piece of crapo switch, and it costs a fortune to replace. Do the wiggle test on the switch, wiggle it while trying the things that do not work, front to back of truck, NOT up and down like your turning the switch on, the opposite way, front to back of truck. If things flassh off & on that stopped working, yopu found the problem. DONT pusy too hard, push gently on end of stalk, there is a lot of leverage there!
Sep 16, 2008 | 1998 Dodge Ram
When a camera is inoperable or fails to function, or an error code appears in the liquid crystal display (LCD)
Follow the steps below in the order presented: Perform a power reset on the camera. Performing a power reset on the digital camera will normally correct issues such as the camera locking up or not turning off. When the power reset is performed properly, the camera will prompt you to update the camera’s date and time. This is an indication that the memory has been cleared and no further reset time is required. The power reset procedure must only be performed on a camera that has been running on battery power. If an AC power adapter is being used, the power reset procedure does not apply. This is due to the fact that the internal capacitor is fully charged. To execute a camera power reset, perform the following steps: Turn off the Digital Camera. Remove the Compact Flash Card or Secure Digital Card, if one is being used. Turn on the Digital Camera. CAUTION: To avoid damaging the camera, ensure the shutter button is not pressed during the following steps. Turn on Live View on the rear LCD. CAUTION: Care should be used when performing Step 5 to ensure that the camera is not dropped. Open the battery door and remove the batteries with the camera turned on. Re-insert the batteries after five minutes have elapsed. Turn on the camera. The camera should request an update for date and time (with the exception of the HP Photosmart 120 and 912 series cameras). Format the memory card. Navigate to the delete menu which varies with each camera, and format the internal memory and/or the memory card. CAUTION: Reformatting the memory card erases all of the files that are stored in the card. All photos, scripts, and miscellaneous files are deleted permanently. To preserve the existing images, use a spare card or a card that is already formatted.
Aug 30, 2005 | HP Photosmart 120 Digital Camera
Pioneer AVIC-F90BT GPS Receiver Logo
225 people viewed this question
Top Pioneer GPS Experts
David Burbee
David Burbee
Are you a Pioneer GPS Expert? Answer questions, earn points and help others
