Question about Siemens Gigaset 2420 Cordless Phone
Siemens gigaset 2420 two line phone drops calls
My Siemens Gigaset 2420 suddenly started dropping calls. Line 2 rings once or twice; if I catch the call before the phone misbehaves, i.e., on the first ring, the call is fine; if not, the call just disappears, the system does not capture call data and the call does not go to the answering system. This also affects other non-Siemens phones in the house. It seems the Gigaset is taking the call and immediately disconnecting it. Out going calls are fine. Line 1 is fine. I have disconnected the Gigaset, and as long as the Gigaset remains disconnected, the rest of the phones in the house work fine; re-connect the gigaset, re-establish the problem. I have also disconnected the power and re-connected it -- no help. Any ideas?
  • Anonymous Mar 19, 2009
    When I am on the phone and another call comes in on the other line (we use both of the phone lines), sometimes all the lights on the phone light up and then BOTH calls are dropped (all the lights go OUT). If I wait, the phone rings again, all the lights light up, and then go out.
    I saw a response on another site that said this is a known firmware bug, and that if you clear your CALLERS log, it will fix it. I did that, powered my phone off and on, and it seems to be working (I've done about 8 tests different call-tests so far over about 20 minutes). Good luck to you.
  • 4 Answers
Dump the memory by deleting your mailbox and your call log-
Posted on Apr 22, 2009
5 Suggested Answers
spare_head_2
  • 47 Answers
SOURCE: SIEMENS GIGASET A160 TWIN CORDLESS PHONE
It's not an easy website to navigate, but if you look hard the all the information is available.
Is this the page you were looking for Graham?
Regards,
Spare head 2.
Posted on Jan 04, 2008
  • 3230 Answers
SOURCE: need a manual for siemens gigaset as185 or as185
Well you can please follow the below link to get your manul -
http://gigaset.com/medias/sys_master/A31008-M2026-L101-1-7643_en_GBR.pdf
Good Luck!!
Posted on Apr 02, 2010
fathitkf
  • 1871 Answers
SOURCE: user manual for gigaset ac180 in english
Hi :
I have found this User manual SIEMENS GIGASET AL 180 for you .. Some times a manual for a close product to yours from the same manufacturer can help .
I hope it will help you ..
Please don't forget to rate !
Posted on Jul 09, 2010
SOURCE: Siemens Gigaset AL14H - mailbox full
I know this problem was posted ages ago, and no doubt the poster has solved it, but I hope giving a solution now is useful for some poor soul who, like me, who has spent ages surfing trying to find a solution, to no avail.
Basically, the problem is NOTHING TO DO WITH YOUR PHONE. I discovered that our telephone supplier (Virgin Media in our case) gave us a free voicemail service without telling us. This service cuts in before the answerphone and takes messages which you don't know are there - apparently they are indicated by a break in dial tone but of course with Gigaset phones you don't use a dial tone!
So, people leave you messages (which you don't know are there, and so ignore) and after a while your mailbox gets full.
To access this mailbox you need to call 1571 - when you finally discover this you'll be surprised at how many important calls you've ignored.
To turn the service off you need to call the phone provider and it can take 24 hours for it to be turned off. Beware though, it took me 20 minutes to get through to the service provider. I then spoke to someone in India and was then transferred to someone in England who resolved the problem.
Finally we are back to normal. Phew!
Posted on Jun 04, 2011
Need a master PIN
To reset the Gigaset 2420 Pin
At "System Settings" in the Menu press *65# then press the Select button.
"System PIN Reset" will be displayed (if the PIN was not already the default).
The default PIN is 0000.
Goodluck..
May 14, 2008 | Siemens Gigaset 2420 Phone
Problem Siemens Gigaset 4000 and 4200
You did get spiked from the power company, and your system needs repair. Go to www.cordlessrepair.com for help.
Jun 23, 2008 | Siemens Gigaset 4000 Phone
Siemens 2520 gigaset base
You will need to customize your Call log settings to show which area code your located in so it will redial from the log properly. To do so, push Menu, then scroll to system settings, push select, then scroll to Area Codes, push select and specify the area code that you are in. If you need additional assistance, go to the link below which is the full manual on PDF, then go to page 48. Hope that helps. http://www.barclayent.com/manuals/Gigaset%202420%20Plus_guide.pdf
Mar 21, 2008 | Siemens Gigaset 2420 Cordless Phone
Hi Mike,
Its an easy fix, you need to tell the phone what area code your in. Push menu, go to system settings, enter your pin, scroll forward to "area codes" press enter twice, enter your area code and push enter to save. Now the phone knows where your located and wont add the 1 and the area code. CG
Siemens 825 Gigaset
I have the same problem with mine - a Siemens 2420 base. The calls come in, all the lights flash, then the thing clicks and resets. At this point, it can only be used for outgoing calls. i think i'm going to retire it. Too bad, cause the speakerphone was one of the best ever.
Nov 28, 2007 | Siemens Gigaset 8825 Cordless Phone
Siemens Gigaset 2420 corded unit resets when calls received
OK, here's what happened. I had the same issue of the phone resetting when a call came in, I thought it was a power issue and through some testing it was not. Here's the fix...Menu \ system settings \ enter pin (if you haven't changed it it is 0000) scroll to factory default and reset. This fixed the problem somehow for me, make sure to write down any impotant messages because it will erase everyting (silly me). I hope this helps.
Nov 14, 2007 | Siemens Gigaset 2420 Phone
Siemens 8825 gigset 2 line phone
If your system was working fine, and it all of a sudden started doing this, it sounds like your base has taken a surge of some kind. Your base needs replacing. You can try re-registering the handsets, but from my experience the problem is fatal. Now if this is a new installation and the handsets never work yet on the base, you just need to register them. You can download the manuals or get tech tips at Siemens website, gigaset FAQ pages.
Sep 04, 2007 | Siemens Gigaset 8825 Cordless Phone
Siemens Gigaset 2420 tow line phone system
Contact 888-286-9375 Siemens Repair Line. Should be able to help you.
Jul 21, 2007 | Siemens Gigaset 2420 Cordless Phone
Line cut off problem
That is a common problem with this model, normally happens after a storm passes through. Unfortunately there is no easy fix for on site, it would need to be sent in for repair or replaced. You can google Siemens Cordless Repair to find service facilities.
Dec 18, 2006 | Siemens Gigaset 2420 Cordless Phone
Siemens Gigaset 2420 Cordless Phone Logo
982 people viewed this question
Top Siemens Lands Phones Experts
Greg Cann
Greg Cann
Are you a Siemens Lands Phone Expert? Answer questions, earn points and help others
