Question about Sharp UX B700 Plain Paper Inkjet Fax
Occasional use of copier-fax leads to dried, useless ink cartridg
And at $35 bucks a pop, It's about $3.50 a copy. Does anyone have a suggestion for desolving the dried ink in the cartridge? The water wipe suggested in the manual does not work, even after an addition three rounds of cleaning the jets.
    Genius:
  • 2,120 Answers
No
Posted on Feb 15, 2009
What do the symbols on the glass mean
yours ink cartridge printing head blocked due to ink dry in side so u have to replace inks it will be print
Jul 26, 2014 | HP J4680 Office Jet All-In-One Printer
U162 error on black ink cannon printer
This error occurs when printer fails detecting ink level or printer assume that no ink in the cartridge. We cannot use print, copy,scan, and fax function before the problem fixed. It's recommended for you to replace ink cartridge. To continue using the printer without replacing the cartridge we must deactivate ink level detection function. Be aware that printing in this condition can damage the printer while sending fax or scan is not problem.
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Original source: http://ij-forum.blogspot.com/2008/12/error-message-check-ink-u162u163.html#ixzz2Cpr4Be1K
Nov 20, 2012 | Canon PIXMA MX340 Wireless Office...
Ink cartrige problem i replaced both cartriges keeps saying right cartrige is incorrect wont let me print
Wiping the nozzles with a moistened soft cloth or removing and reinserting the cartridges usually helps. The cartridges for the Lexmark X7170 are black: 32/34 and color: 33/35. If these are the cartridges that you purchased and even tried your old and new cartridges yet the problem persists, please don't hesitate to contact Lexmark technical support.
Mar 23, 2011 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
My i850 printer has not been used for several years. I just tried to use it on a MacPro running OSX 10.5. It will not print black text but does print black test patterns (though often with vertical lines)....
The issue is your heads are dried up. Did you store the printer with ink cartridges installed? What tends to happen from prolonged periods of no use is the ink dries and hardens just under where the cartridge is seated.
You can try taking a Q-Tip with some rubbing Alcohol and clean the heads. You need to be very careful not to push down to hard or let the cotton get pulled into the head area.
Another option is to get a new printer - I've seen them as low as 35 bucks at Target
Feb 01, 2010 | Canon i850 InkJet Photo Printer
My fax won't print, neither faxes nor copies. The paper goes through & it makes sounds like it is printing but nothing on the paper. The machine says the ink level is 6/8. I "aligned" and...
Though the ink level it said was "6 / 8", when I removed the cartridge to examine it looked bone dry empty to me. I replaced the ink cartridge. It works fine, and reports the ink level as "8 / 8".
Sep 09, 2009 | HP 1040 Plain Paper Inkjet Fax
I Need to Print
Sadly in a word, 'No'.
Here is the exact answer from Brother:
Your Brother machine is designed to stop ALL printing operations
(printing from the pc, printing received faxes and printing copies or reports) when any of the ink cartridges are empty. This is to ensure the life of the print head and maintain premium print quality. If the unit were to continue printing, print jobs and cleaning cycles would suction air from the dry cartridge and damage the printhead. Even if you print in black only or change the print settings to MONO or GRAYSCALE to avoid printing in color, the programmed cleaning cycles would still suction the dry cartridge, because they are programmed to clean ALL the ink nozzles.
The only way to continue printing is to replace the empty ink cartridge or cartridges.
While memory is available, black and white faxes will continue to be received into memory. If a color fax is being received, the Brother machines HANDSHAKE will request the fax be sent as black and white fax.
All faxes received into memory will automatically print once the ink cartridge is replaced.
NOTE: Brother strongly recommends that customers do not use generic ink or refill their Brother ink cartridges. Using non-Brother supplies may affect the hardware performance, print quality and machine reliability since the ink formulation in genuine Brother ink cartridges prevent smearing and clogging of the print head. The Brother limited warranty does not apply to any problem that was caused by the use of unauthorized third party ink and/or cartridges.
Nov 26, 2008 | Brother Multi-Function Center MFC-240C...
How can I get the fax and copy to print clearly?
Still sounds like a bad ink cartridge, try cleaning the bottom of the cartridge with a Kleenex and soapy water. Dry it off real good.
Look where the cartridge sits and clean the same way.
Ink jets are dead technology.
Nov 11, 2008 | HP 640 Inkjet Fax Machine
X5470 Lexmark printer
Lexmark and Dell use a sensor in the cartridge to sense a low ink level. Once the sensor has been activated, you cannot reset it. The printer should work fine except for the fact that you'll have to override the "low ink" message on your computer.
Manufacurers don't make money on printer hardware. All the money is made from ink replacement, so they make it as difficult as possible to use anything other than the stuff you buy from them. Some (HP) put in chips for an "expiration" of the ink/toner. Go beyond the expiration date, the thing won't work.
May 13, 2008 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Oxc18a0307 error
software for ink system failure photosmart d7300
Dec 12, 2007 | HP Photosmart 3310 Printer
Error code
well I have had the same thing happen.on the left only use 31[photo]; 32; 34....on the right33; 35..left takes black or 31 photo....right color cartridge only
Dec 12, 2007 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Sharp UX B700 Plain Paper Inkjet Fax Logo
57 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
