Question about Jensen LXA300 Car Audio Amplifier
Fli Sub not working
I have a Fli Sub 12" 1000W. Power lights on however no sound apart from a very quiet distorted bass line coming through when stereo is on. However, when i disconnect it (I have easy plug/unplug connection for quick removal from the boot), it suddenly booms out momentarily for a second or two, as it drains the last bit of power in the amp. Therefore, I know the feed from the head unit is fine, and that there is power. Im not technically minded, but any ideas what the problem could be? Could it be an earthing problem, and if so, how do i resolve it? Thanks!
  • dac297 Feb 16, 2009
    Hi, thanks for your response - it is an active, self-contained speaker and amp, all in one. I know that it has an overload circuit as a red LED comes on after it is in use a long while (presumably if it gets too hot). The Red LED is not lit, and the normal green power LED is on as normal. As regards the earthing, I can check later when i collect the car from the garage.
  • Jimmy Hall
    Jimmy Hall May 11, 2010
    need more input such as; is this a passive (powered with a separate amp) or an active (self-contained speaker & amp) set-up, how is the amp connected to ground (earth). from what you posted @ 1st glance it appears there is an overload condition. fortunately most sub amps are constructed with short-circuit & overload protection, so the amp is probably OK. we need to verify the connections as it is presently configured.
  • 5 Answers
SOURCE: Jensen LXA400
I have this same amplifier. I have noticed several ways it will "not work" during my ownership of it. I have it connected to a seperate battery to save my alternator, battery, etc as it is a power hungry beast for how low the output wattage is. Test the input voltage to see if you have enough, one way to see this is to check the "jensen" emblem that lights up. If you dont have enough power it will appear dim and only the right side lights up. Also the amplifier will not work if your speakers are "blown" even a little bit. Ive taken speakers that wont work on my lxa400 and connected them to a higher power amp and they will work (although they will sound horrible) If youre smart you will keep the gain under 3/4 on this amp, I see some people have found out the hard way that full gain fries the amplifier circuitry. Not an expert on electronics but it smells somewhat like melting glue or plastic. Ive noticed a lot of people have problems with the RCA jacks as well. There are 8 jacks, in two clusters. The first one is A+B and the second is C+D. Note: You do not NEED Y connectors on this amp! Connect your output rcas from the deck to top left and bottom left jacks of the left cluster. This will give you left and right (a+b) output from the first set of speaker outs. Then connect an rca patch cord from the top right and bottom right jacks of the first cluster and connect the other end to the top left and bottom left of the second cluster. This will give you output from the second set of speaker outs. Remember that this is in 4 channel mode. I dont remember the set ups for 3 channel but two channel I believe is the left deck rca goes to top left of the first cluster and the right deck rca goes to the top left of the second cluster. Then you just wire the speaker outs according to the picture on the amplifier. something like this: _________________________ |(+) - (-) +| ~~~~~~~~~~~~~~~~~~~~~~~~~ Speaker + goes to (+) and speaker - goes to (-) Also addressing another issue if you want to increase the wattage to your speakers you just use a lower resistance speaker (2ohm instead of 4) I would not recommend using anything over 4 ohms. As for the high level inputs, I dont recommend using them unless you have the plugs that go with them, its a lot easier to wire your deck rears to a line converter (changes straight speaker wire to RCA jacks) or to just buy a new deck with RCA outs. Last item, common knowledge: 400 watts does NOT mean 400 watts!!! This amplifier puts out very little actual wattage (50 or 83 per channel depending on the load) Hope all this helps someone out there.. Anyone who knows the 3 channel setups I would appreciate it.
Posted on Jul 15, 2007
  • 1139 Answers
SOURCE: Amp Stopped working.
I would suggest checking the unit for cold solder joints or bad solder joints. The onlt hope after that is a bad component. You will need a schematic and multimeter to do this with. Open the unit and measuer the main rail voltage this will provide the data you need to troubleshoot the unit with the use of the schematic.
Posted on Sep 16, 2007
  • 52 Answers
SOURCE: Distorted Bass
Check the specs on the required ohms for the speakers. If it calls for 8 ohms and your speaker is 4, then you are pulling twice the normal current and this has blown an output transistor.
Posted on Mar 02, 2008
  • 631 Answers
SOURCE: whenever i wire 2 4 ohm svc subs the system just starts to pound real hard and its not like bass moving to music but just bass just moving up and down
It sounds like you have an open shield ground. To check the shield in your head unit, read through the following page.
Temporary Shield Ground Repair
Let me know if you have any other questions.
Posted on Aug 26, 2008
  • 655 Answers
SOURCE: PINs for high level input
Hello gmb_66,
You did not specify exactly which Jensen amp you have. None of the Jensen PowerPlus series I found had high-level inputs. You can go here and select your amp to download the manual. They should also have the connector for speaker inputs.
Most amps that have both high-level and RCA inputs allow you to use one or the other, but not both at the same time. If your head unit has RCA ourputs, those would be the ones to use, because they generally provide a cleaner signal to the amp with less noise.
Hope this helps.
Posted on May 24, 2009
The sub woofer had a distorted sound.
the distorted sound coming out of your sub-w is actually originating from your audio unit, Have your audio unit check for possible repair
Oct 31, 2015 | Audio Players & Recorders
I have 2 12in kenwoods and a 1200 watt pyrimade amp, how can i hook these up to be the loudest
1st have your subs facing inwards towards the front of the car, not facing out the boot, This creates a better bass.
Wire 1 sub to one channel and the other sub to the other channel.
Turn down your gain as low as possible and then power everything up.
turn volume to desired loudness and then start turning up the gain slowly, if distorts a little turn in back down a notch.
avoid using bass boost, I agree it sounds great but it puts more strain on your amp and shortens its life.
after sorting out your gain, tweak all others until sound is bassy and clear with no distortion.
If you would like to use bass boost, turn on bass boost first, then up your gain etc.
Jan 16, 2013 | Pyramid PB915X 1200 Watts 2 Channel...
My SONY Home Theater Model HT-6600DP unit was working fine and then about tow years after...present, my sub woofer is sounding distorted. Why is this happening? Please help me as I often watch my home...
Is it so even at lower volumes?
Are you sure it's the sub distorting and not the front or center speakers?
If you designate them incorrectly as Large (which tells the receiver they CAN effectively produce bass frequencies) they will probably distort in the presence of low frequencies.
See Page 17, 19
Register and download the manual for free at
Mar 13, 2011 | Sony HT-6600DP System
Can i use my jensen jxp340 amp with my one 800watt 12" 4 ohm subwoofer?
Yes, technically you can, however you will be putting both your sub and your amp at risk. One of the worst things you can do to a sub is underpower it. The easiest way to explain it is n ot giving enough power to the sub leaves it starving for power. The motor structure ends up working too hard to try and move the cone properly and what happens is the sub will usually seize up rather than blowing out in the term you usually hear (ie, I had my system cranked up and I blew my subwoofer).
Secondly, in an attempt to get any real sound out of the under powered sub, you'll probably end up cranking the gain and bass boost on the amp which ends up overworking the amplifier quite a bit and can in turn lead to fried out amp chips, burnt up circuit boards etc.
Thirdly, by maxing the gain bass boost you're going to end sending a lot of distortion through your subwoofer in an attempt to get some decent bass. Distortion kills both subwoofers and speakers alike.
So to answer your question, yes you can hook up your subwoofer to that amp and yes, it will probably play for a while but I wouldn't recommend it. Look for a class d or mono block amp to push your sub as these will give you the most power and best heat dissipation. They are designed to push subwoofers specifically and you will get better sound and longer life out of your equipment. A good rule of thumb is look for an amp within 100-150 watts of both your RMS power handling and your Peak power. Remember, when it doubt, always go a little bigger on the amp side of the spectrum. It's easy to "tune down" an amp by having the gain and bass boost at a lower level (50%, 25% etc), than to turn 'em all the way up just to get some bass and end up prematurely blowing out your sub, amp or even worse, both.
Dec 01, 2010 | Jensen JXP340 Car Audio Amplifier
Amp sends power to sub at low volume. but when volume is increased speaker loses bass and distorts REALLY BAD. Still has power but clear bass disperses. just sounds terrible at even lower volumes
are the sub speakers ok? if ok then u have a problem with the Amp and the output IC's will have to be checked there cud be a problem with the input card in the amp.
Aug 26, 2009 | Jl Audio 500/5 Car Audio Amplifier
Have installed correctly, but only distorted bass sounds. will not actually work. not sure if the sub is faulty. I have a corsa sxi with a halfords Vibe SLR amp & sub. my head unit is a Kenwood DPX303
Hi there. you need to check that the signal going into you amplifier is not over driven. If it is, you will have the same effect of distorted bass. Turn volume on your radio down to see if that helps. If you have a Line driver and Crossover, then check them aswell. Remeber that your gains are not actually volume controls like people think, but rather level matching adjustments. Shout if you need more info.
Aug 17, 2009 | Car Audio & Video
Music is coming through my sub as well as bass
your amp might have a low pass filter and a high pass filter make sure it is switched to low pass and that should prevent music from coming out of the subs and just alow the bass too
Jun 11, 2009 | Car Audio & Video
Sound is pulsing.
You probably have the power bar thing too close to the sub woofer, this will cause a pulsing sound! :D
Apr 04, 2009 | Creative Labs I-Trigue 2.1 3300 Computer...
JL 300/2 v2 Power Light Blinks, No sound out of Sub. Works in friends Car HELP
Are you sure you don't have any shorted wiring or defective speakers?
Sep 30, 2008 | Jl Audio 300/2 Car Audio Amplifier
Jensen LXA300 Car Audio Amplifier Logo
604 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
