Question about HP Compaq Presario V2403NR Notebook
Changed cooling fan in compaq v2403nr laptop. Now it won't bootup
It gives me a PXE-E61: MEDIA TEST FAILURE CHECK CABLE
PXE-MOF: Exiting PXE ROM
All I did was remove battery, and cover. Had to disconnect 2 wires from a small board in front to remove cover and hard drive also came out. Doesn't sound like a major problem though. I did check boot order and it was OK. Wire were reconnected in correct order.
  • Bassman58 Feb 19, 2009
    Thanks, It was a loose connection. I think the hard drive wasn't
    back in place good. Everything works fine now.
  • Anonymous Mar 20, 2009
    I have NEC VERSA S3500 laptop.-That day turn on laptop it take long time for starting. so i press function key and same time insert sony MP3 player.Now laptop not show display on screen.It display PXE-E61-media testing failure,check cable and PXE-MOF-Existing PXE ROM.
    Pls give idea to me solve this problem.
  • 77 Answers
Was your cd drive detected in the BIOS? Take the laptop back apart and double check your connections.
Posted on Feb 16, 2009
R780 pxe-e61 media test failure
It is not recognizing the hard drive, Open it up reseat it. Then check BIOS by pressing F key noted on startup. It must be noted there in order for it to boot correctly.
Jan 19, 2013 | Samsung R780 Red Intel I5-460m...
Laptop won't start up
The error PXE-E61: Media test failure usually means the hard disk has failed or the hard disk needs re-seating or the disk controller is faulty. First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Aug 12, 2012 | Toshiba Computers & Internet
PXE-E61 Media test fail, PXE-MOF Exiting Broadcom PXE ROM
Disable PXE in the Boot Sequence in the BIOS setup [F2]
Aug 10, 2012 | Dell Computers & Internet
Keeps saying boot failure along with Ethernet controller v1.06 and media failure, check cable
What you are describing is a hard drive issue, remove hardware and reseat it back in place sometimes this will restart the hard drive. If this fails have it tested.
Jun 04, 2012 | MSI Computers & Internet
ACER 5315 IS DEAD ON BOOT UP IT DISLAYS PXE-E61:media test failure,chk cable PXE-MOF:EXITING BROADCOM PXE ROM
Sounds like it is trying to boot from network drive. Have you changed the bios boot order. If so, change it back to boot from hard drive first.
Jun 10, 2009 | HP Pavilion ze2000 Notebook
How do i repair my pc it gives a message that says Intel UNDI, PXE-2.0 (build 082) Copy Right (1997,1998,1999)Intel Corporation VIA Rhine II Fast Ethernet Adapter V2.43 (2005/12/15) PXE - E61: Media test...
Dear,
If you are using PC then make sure that Boot from PXE Rom is disable and boot from hard disk drive is enabled. Check your BIOS setting for configure it.
Regards,
Rakesh Kumar
Network Support Engineer
Apr 07, 2009 | Compaq Computers & Internet
Wont bootup
try to run cmos and set it to factroy default.
Aug 11, 2008 | Toshiba Satellite M35X-S111 Notebook
Error Message: PXE-E61 Media Test Failure Check Cable
Not always the Hard drive, boot into the bios setup utility and de-select network bootfrom the boot options. If it tries to network boot first you will always get that failure.
Apr 12, 2008 | Compaq Armada E500 Notebook
HP Compaq Presario V2403NR Notebook Logo
153 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
