I go to turn my selfcleaning oven on and it turns on and locks, but after a few minutes it starts beeping and FSEO comes up and I have to cancel the cleaning.
Seems
like you found out the hard way what I wrote about in this
tip...
Check it out it also contains some thing to try on how
to unlock that oven..
Self
Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I
never would have used the self cleaning option. Thanks for the info!!
" - amymrocks
My oven is at least 10 years old and is exibiting the exact same problem as carebears594. This is a new problem for us, so it wouldn't be an installation issue, but maybe a worn out mechanism? Is it better solved by calling a repairman?
F5E0 Is a door switch error, and is best solved by checking that the door safety switch is securely installed and the associated wiring has not been compromised in any way. After that, replace the safety switch in the top of the oven.
You should be able to see an exploded view of the oven, and identify the switch, at SearsPartsDirdct.com.
Reply back with any additional questions.
