Question about Samsung HLS4676S Television
Keeps switching itsself off
Changed all batteries in remotes and tv keeps switching off more and more. After an increasing amount of time will stay on ... is there a fix?
    Novelist:
  • 184 Answers
Check the lamp first. Observe the light where the lamp door is on the back of the set. If the light is going out, its likely the lamp, especially if its 2 or more years old. If the lamp has been recently repalced, make sure the lamp door is properly aligned so the interlock switch is engaged.
michtech
Posted on Feb 16, 2009
Volume does not stay level it increases by it stself
This is not a fault with its remote control. The main board to your TV should be checked. Contact any service technician. If you wish to get more details, check the site linked here.
Oct 19, 2014 | Vizio xrt112 smart tv Remote control for...
TV volume increases by itself and doesn't decrease or respond to the remote control
Connect all A / V sources to the Home Theater Receiver then Video-Out from the receiver and totally mute) the TV.
Sep 30, 2008 | Soyo DYLT032D 32 in. LCD Television
Tip
How to increase battery life in LG GT505
Feeling tired that after surfing the web or playing a few games, the battery is halfway through to being dead?
So this Tip is for you!
What we're going to do, is put every setting on the minimum so that it doesn't waste battery life that much when you're just typing a SMS.
1 - Open the Menu and click on the last icon (on the right bar) on the bottom. - Settings
2-Open Phone Settings, and slide the Power Save button to turn it ON.
3- Now go back to Settings and go to Screen Settings and choose Brightness. Set it to 0% and Save it (click Yes even if it tells you that you are changing the Power Save Settings)
4 - (Optional) If you don't mind your phone turning off the backlight real quick, you can change the amount of time it stays on, but if you send or read a lot of messages, it can become a bit annoying, so it's really up to you! Anyway, in Settings, choose Screen Settings, then Backlight, and choose whatever time suits you. Keep in mind, that the lower the time stays on, the more it saves up battery life.
Imagine you just made a phone call, then put the phone on your pocket. For some time, it's backlight is on for a long time, maximum brightness and you're not even looking at the phone. That's a waste of battery power!
Using those new settings, you can get up to 3 days battery while playing a fair amount of games!
on May 16, 2010 | LG GT505 Cell Phone
I have a toshiba 32a32 32" tv, the problem im having is all of a sudden the channels started switching by itself and the volume keeps going up to 100. when i set a channel it stays there for a minute then...
The problem is either from the remote or the television, there has been so much heat on the control panel of the television, so it has melted some lead off a part of the control panel and bridging it to another part, so it is increasing both the volume and changing the channel in an upward direction.
The solution is to change the control panel of the television or correct it by using a soldering iron to melt off the lead from where leads meet.
If you remove the battery from the remote and it still does the same, then it is confirmed that it is the televisions control panel. But if after removing the battery it stops scrolling up, then the problem is from the remote and the solution is for you to replace the remote with a new one.
Take care and good luck
Oct 23, 2010 | Toshiba 32A32 32" TV
Remote control doesn't work. Small red light stays lit.
First check the remote control with a similar TV.
By keeping a MW radio receiver you can check the functioning of the remote by pressing the keys. Radio will give garble sound!
If remote is OK , TV has to be checked.
Apr 05, 2010 | Casablanca Fan Versa Touch2 W-72 Remote...
TV turns itself on, keeps changing it's own channel
the problem is with the control panel of your tv...make sure your remote doesnt have any part in this...just remove and the batteries and check if the channels still are changing.....see if the onboard switch for channel changing is stuck ?..if stuck u can use homemade tools to pull it back......if your tv is within your gurantee period...just giv a call to customer care....if not u can take it to a local repair shop...there is nothin that u can urself do to make it right ...sorry....for further info contact at
Jul 06, 2008 | Televison & Video
Channel keeps changing
It sounds like a stuck button or switch. What happens when you hit the channel DOWN, does it still keep scrolling down?
Is this with or without the remote?
Have you tried it with the remote and or the TV?
Let me know whether you are changing the channels with the remote or the buttons on the tv and I can try to give you a couple more suggestions.
Mac =)
Feb 12, 2008 | Televison & Video
Set will not stay powered up
Look for bad capacitors on the power supply board.
Nov 21, 2017 | Toshiba MD20P1 20 in. TV/DVD Combo
Channels keep changing
ok, let's try the simplest things first.... unplug the tv from the wall, and remove the batteries from the remote. wait about 5 or 10 minutes. reinstall the batteries and plug the tv back in. try it again. actually since you said you tried another remote, you can skip removing the batteries from the remote. if it still does it, try unplugging the tv overnight. if it still doesn't work right then, you have a processor problem, and need to have it looked at by a service tech.
Jul 07, 2006 | Toshiba 36A40 36" TV
Open Questions:
Samsung HLS4676S Television Logo
131 people viewed this question
Henry  Thomas
Henry Thomas
