Question about Kenmore Washing Machines
A cleaner to get black film off of agitator
How do I get this black oil film off of the agitator?
  • krusiensk186 Feb 16, 2009
    This oily film is from my sons work clothes..He has a very greasy job in a factory. Thanks for trying anyway...
  • krusiensk186 Feb 17, 2009
    Thanks, I'll try that..I was just worried that maybe this oil was also getting into the motor, and I thought there was something I could put in and run the machine on full.. I appreciate your help.
    President:
  • Kenmore Master
  • 2,651 Answers
Scrub with some elbow grease! and a fine toothbrush, everyones machine has it
Posted on Feb 16, 2009
  • Ron Coons
    Ron Coons Feb 16, 2009
    ok so you can try a quality "degreaser" and elbow gease, wasnt intended to be sarcastic,
How to replace belt instructions
Disconnect cleaner from electrical outlet.
1. Place handle in operating position and turn cleaner over so bottom side is up.
2. To remove bottom plate, insert end of flat screwdriver into wide area of right-hand slot and push handle of screwdriver to the rear. Repeat in left-hand slot.
3. Lift extension of bottom plate, rotate plate and remove from cleaner body.
4. Remove agitator and broken agitator belt.
5. Slip agitator through new belt. (With lettering toward outside of cleaner) and position belt in belt guide. Push end of belt into opening in cleaner body. Reposition agitator making sure to align flat sides of projection on belt end of agitator with flat sides of slot in cleaner body.
6. Place the three tabs on bottom plate into slots in front of cleaner body. Snap bottom plate into place over agitator.
7. Remove hood by turning cleaner over and removing nozzle control knob on front of hood -- grasp knob and pull up.
8. Place handle in operating position and turn cleaner over. Insert end of flat screwdriver into one of the four slots beside an arrow on bottom of cleaner.
9. For slots nearest the rear wheels, push handle of screwdriver toward cleaner handle; for remaining two slots, pry outward to release latches.
I0. Turn cleaner over and lift off hood.
Il. Stretch new belt onto motor pulley.
Extra effort may be required to stretch new belt onto pulley.
Turn agitator, making sure the belt is not pinched between agitator and cleaner body. The belt must rotate freely inside the belt guide. If agitator does not turn, remove bottom plate and reposition belt in belt guide.
Aug 08, 2014 | Hoover Vacuums
How to belt replace instructions
Hi! Below are instructions to replacing the belt on a Hoover U5064-930.
2. To remove bottom plate, insert end of flat screwdriver into wide area of right-hand slot and push handle of screwdriver to the rear.Repeat in left-hand slot.
Hope this helps!
Aug 05, 2014 | Hoover Platinum Lightweight Upright Vaccum...
How to change belt on hoover runabout 44258-930?
Jun 28, 2014 | Hoover Runabout U50-940 Bagged Upright...
How to change a belt on a hoover u 4266-940?
Hello! Below are instructions for replacing the belt on your U4266940.
Hope this was helpful!
Jun 20, 2014 | Hoover Soft Light U4266-940 Bagged Upright...
My 04 nissan xterra oil pressure comes on when turning sharp or braking hard. Light only stays on for 1-2 seconds. The oil was black when I bought it recently. Changed and still dark/dirty. Is this...
the engine may be slugged up from lack of maintenance/oil changes, since the oil was black when you purchased the truck. was the light coming on before you changed the oil?? if not, try changing the oil filter for nissan one. if that doesnt do it than you can dump some internal engine cleaner into it if you want, but it may develop external oil leaks. the oil builds up a film after a while inside of you engine. if you wash it off, the engine may start leaking oil. to really diagnose this, you should take oil pressure reading at the oil pressure sending unit. you will ofcourse need some specialty tools to do this job such as pressure gauge and oil pressure sending unit socket to remove it so you can screw the gauge into it.good luck.
Dec 26, 2010 | 2000 Nissan Xterra
1990 ford bronco 2 2.9 liter its leaking oil between the block and the oil filter bracket
The gasket must have let go you'll to remove the oil filter bracket and replace the gasket. Make sure you get all the old gasket off and clean both surfaces with brake parts cleaner or carburator cleaner, you want the parts clean and dry. If you use gasket sealer to put the new one on, use it sparingly, just a film is pleanty.
Jan 03, 2010 | 1990 Ford Bronco II
Have black oily film appearing thru out the
I have had a similar problem on a Bosch. Don't know where it comes from, except to say the bottom door gasket appeared to be melting for some reason. I replaced it with a new one, and no signs of melting after about 3 months.
I was able to clean the black smudge from various parts of the dishwasher using Berryman's Chemtool, a carburetor cleaner available at the auto parts store. Use in a well ventilated area. Am certain naptha or other cleaner would work as well, but again, use sparingly and with plenty of ventilation. Rubbing alcohol would not cut the stuff.
Let me know what you find.
Dec 16, 2009 | LG 24 in. LDS 5811ST Stainless Steel...
Sludge build up in the agitator caused by the water softener
I use ammonia and hot, hot water to clean the film or sludge from my washing machine.
Add (2) cups of ammonia, set the washer water temp to hot and fill it to high or large/extra large load. Agitate for (5) minutes and let soak over night.
Skim off any sludge that is floating then allow the washer to run through the rinse cycle. Re-rinse a couple of times to clear the system.
Good luck and let me know.
Regards,
Oct 12, 2009 | Speed Queen Washing Machines
I had a 2inch by 2 inch black grease stain from a cast iron pot on my ceramic cook top. I used whirlpool cooktop cleaner and a razor blade to try to remove the black gunk. The more I used the cleaner and...
You could try a little oven cleaner on it. That should take care of the mark. After that, if it did not work, clean off the oven cleaner well and then try a bleach solution.
Post a comment with your progress.
Tim
May 03, 2009 | Kitchen Ranges
Maytag Atlantis black oil like residue and can't remove agitator
Hello
Welcome to fixya.
I'm Huuum and happy to assist you,
this is a very common happening and it means
This usually means that a seal is degrading or dissolving.
This washer is a top loader, Right!
I believe it calls for HE ( High Efficient) laundry detergent.
If we use to much of either it will cause this !
This usually happens due to using to much detergent or bleach.
You said, Black oil like residue discharged from washer during use. Stain clothes, almost impossible to remove. Loosened nut on agitator but it will not budge, and am afraid of damage if I try to pry between agitator and bottom of drum.
Please remember to leave a rating before you go!
Thank you
Sep 20, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Washing Machines Logo
43 people viewed this question
Sal De
fordexpert
Robert Rankin
