It stopped doing anything. I plug into pc it lights up but thats it. Just got fot xmas. Help!!
It wont play my music it turns on but no music
I once had a similar issue and found that the switch had to be on. If yours has a switch as well as a button to power on you should check it. If it won't even turn on to play stuff or anything you might try checking the battery. Lithium ion batteries have several built in safety features that disable the battery if it gets too hot or gets overcharged, or even if it runs completely dead. It has a built in power monitor that can run the last bit of power out and that can also disable the battery. Ideally li-ion batteries should be stored with 40 to 60 percent charge and kept refrigerated to maximize their life span. At room temperature they lose about 20 percent capacity per year. If all else fails you could try running a virus scan, unlikely though.
It just stopped working. Will not turn on. When I hook it up to the computer nothing happens. Was working fine yesterday, today nothing at all.
It just stopped working. Will not even turn on. Hook it up to the computer, nothing. Will reseting it make it work? Can not find a reset button
SAme thing, just stopped working backlight comes on when you press power or hook to a charger nothing else
