Question about Dell 922 All-In-One InkJet Printer
Dell 922 leaves horizontal gaps whether printing or copying
I have printed alignment pages, cleaned the cartridges, even changed cartidges, but the problem persists with both the black and color cartidges. Printer is 3 years old, has been excellent; problem began without apparent cause in the middle of color and black cartidges' life. I don't suspect communication problems with the computer because the problem is also there when just making copies. (Latest color cartiridge is Dell; black was Dell, is now generic, all have the same problem.)
  • 2 more comments
  • Anonymous Feb 16, 2009
    We are having the very same problem as evansandasso and are exasperated. We have had no problems printing until now. We have changed the cartridges, realigned and printed the test sheets. The horizontal gaps and misalignment still exists.
    teamhogan
  • HB Richard Feb 17, 2009
    my problems are the same as posted earlier.
    my french (language in the window) is not very good, but I think the message window says there is an alignment problem with the ink cartridge. Does anyone know how to adjust the alignment?
    Thx
    Brett
  • Anonymous Feb 24, 2009
    I believe we have the same problem described by previous bloggers; horizontal full line skipping, or double-line blurred printing, ours will print a couple of lines just fine, then trouble, then print fine, then trouble. we have also replaced cartridges and ran aligning pages.....no remedy
  • Rick 156 Mar 20, 2009
    Think we have the same problem? We first spotted fine horizontal white lines running through entire lines of text; mostly (not all) regular every couple of inches down the page. Over a couple of weeks these have progressively widened, now gaps of 2-3mm. No parts of printed letters are actually missing, it's just that the top half is separated from the bottom half, as though the paper was sometimes being fed down too far. Recently have also had lines being double-printed (partially overlapping). as though the paper was being fed down between passes on the same line (not sure if that is possible).
    Exactly the same occurs during copying.
    Things seem to improve if we force the print to photo setting. I assume more ink is used (and of course it is slower) so this isn't ideal.
Ajkill
  • 2035 Answers
SOURCE: white horizontal streaks in documents
I Am Experiencing Poor Print Quality With My Dell™ Printer
Table of Contents
Verify the Printer Ink Levels Using the Dell Printer Solution Center
Clean the printer contacts and print a test page
Clean the Printer Nozzles Using the Dell Printer Solution Center
Dell™ Printer Additional Information
» Verify the Printer Ink Levels Using the Dell Printer Solution Center
Poor print quality of a document or picture may be the result of low ink levels or dirty printer nozzles or contacts.
To check the printer's ink levels, perform the following steps:
1.
Click the Start button, point to All Programs, point to Dell Printers, and then point to Dell (printer model).
2.
Click Dell Printer Solution Center.
3.
Locate the printer's ink levels on the lower right corner of the Dell Printer Solution Center window.
4.
If the printer's ink levels indicate that ink cartridges are empty, click the Order Ink button to place an online order for replacement ink cartridges.
For information about ordering ink for your Dell printer, refer to article: Obtaining Ink for a Dell™ Printer
Back to Top
» Clean the printer contacts and print a test page
To manually clean the printer nozzles and contacts, perform the following steps:
1.
Turn the printer off and remove the power cord from the back of the printer.
2.
Open the printer lid.
3.
Manually move the ink-cartridge carrier to the left by gripping the top of the rubber carrier belt and gently pulling it across towards the right hand side of the printer.
4.
Take a warm, semi-damp paper towel and gently clean the wiper on the right side of the maintenance station.
5.
Lift up on the cap(s) that cover the ink cartridge(s).
6.
Remove the ink cartridge(s), and using a new warm, semi-damp paper towel, gently clean the contacts on the ink cartridge(s).
Verify that the contacts on the ink cartridge(s) is/are sufficiently dry prior to re-inserting into the printer.
7.
Re-insert the ink cartridge(s) back into the correct printer slot(s).
7.
Close the printer lid.
8.
Re-attach the printer power cord to the back of the printer unit.
9.
Press the Power button to turn the unit back on.
10.
11.
12.
Click the Maintenance tab.
13.
Click the Print a test page icon.
A test page prints.
Back to Top
» Clean the Printer Nozzles Using the Dell Printer Solution Center
To clean the printer nozzles and contacts using the Dell Printer Solution Center:
1.
2.
3.
4.
Click the Clean to fix horizontal streaks icon.
5.
Click the Print button.
Note:
The printer will make sounds when cleaning the nozzles that are not commonly heard during normal usage
Posted on Mar 21, 2008
SOURCE: Prints Blank Pages
I had a the same problems.
The Fix - Below where the cartridge ride on (side to side). There is a strip touch it is probably tacky with ink residue, it prevents the cartridges from moving freely. This causes friction and slows the printer down causing the errors.
Wipe it clean with windex. And that will clear all the issues with this printer.
Posted on May 15, 2008
  • 5 Answers
SOURCE: Printing alignment problem
First thing to try is to remove the power brick (not just the cord the whole brick) from printer for a minute then re insert and try it again. If this doesn't help try uninstalling it then re installing the printer
Posted on Oct 14, 2008
yooperbud
  • 8637 Answers
SOURCE: Color printer won't print color
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 29, 2009
  • 373 Answers
SOURCE: Dell 922 all-in-one won't print
call dell tech department
Posted on Feb 10, 2009
My computer is reading the printer,and it stating that ink cartridge is full but the page is blank after printing
The print-head part of the cartridge is probably clogged / dried up. Remove the cartridge and wipe with a link-free rag dipped in rubbing alcohol. Wipe several times until ink appears to be flowing from the print-head and reinstall. Do the alignment / and cleaning routines if needed and try to print.
May 12, 2015 | Dell 922 All-In-One InkJet Printer
X2250 won't print form pc
A technique to improve print quality is to try and clean the cartridge nozzles. You may clean the cartridge by following the steps given below:
1. Go to the "Lexmark solution center." This can be done by clicking on "Start," go to "Programs" and Lexmark printer group. Click on the "Lexmark Solution center." Next click on the "Maintenance" Tab.
2. Select "Clean and Fix Horizontal streaks." Click on "Print". This will produce a printed page.
The colors that you should see here are black, yellow, magenta (a reddish purple) and cyan (a dark sky blue). You should notice the diagonal lines above and below the solid horizontal lines. These diagonal lines should be solid from left to right with no gaps.
If there are gaps in the lines or the print diminishes across the page, you should run the "Clean Print Nozzle" page a couple more times to try and clear it up. If you still have gaps at the top and bottom, you should "wick" the cartridges by following the steps given below:
1. Please open the "Solution center" again and go to the "Maintenance" Tab.
2. Select "Install color/black cartridge" and remove the cartridge or cartridges from the printer.
3. Get a damp paper towel.
4. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds.
5. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean.
6. Next dab the cartridge on the towel to make sure that the ink is flowing.
7. Snap the cartridges back into the printer.
8. On your computer, select "Old Cartridge install."
9. Repeat the "Clean Nozzle Page" one more time. If this fails to address the problem the entire procedure may need repeating.
Good Luck!!!!
May 01, 2013 | Lexmark X2250 All-In-One InkJet Printer
Cartridge error code 1203
HI Don,
It's mean your catridges overflow even from brand new catridges after a several prints or right after you refilled the catridges. Check to see if ink are smeared on the holder where the contact panel with the catridge
Solution
Use the klennex with a few drops of water to dampen and clean off those contact on the holder and printer may work again.
The refill ink work very well if you let it sit 24 hrs. Then before you print anything, you should run aligned the catridges a couple times then run clean catridges a couple times.
Print the test page to see how it's look and way you go.
Be sure not to leave any debris of klennex on those holder contact panel.
-rate this if it helped you.
Apr 08, 2010 | Dell 962 Photo All-In-One InkJet Printer
My MP830 leaves white horizontal bands when printing black & white documents. Color printing seems fine. Pattern 'F' is missing on the print alignment page.
You need to continually clean and deep clean and realign the black until the results are acceptable. Try manual alignment if the auto does not work. Also clean around the exit hole of the black ink cartidge with a cotton bud and isoproyl alcohol.
Nov 07, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Very fine horizontal black lines superimposed over text printing.
Print at a higher resolution. Clean the print heads, check the print alignment.
May 15, 2009 | Dell 922 All-In-One InkJet Printer
Dell 922 AIO does everything except print from PC
Two things to try:
1. If it prints the alignment page, sometimes you have to put the page back on the scanner glass and hit continue or start on the printer for it to scan back in the alignment page to complete the alignment process
2. If thtat's not it, try going to add/remove programs in control panel and uninstall all dell pritner software, then reinstall using the link below:
http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=rc1057382&l=en&s=biz&ServiceTag=&SystemID=PRN_ALL_A922&os=WW1&osl=en&catid=&impid=
Mar 28, 2009 | Dell 922 All-In-One InkJet Printer
Dell 922 printer alignment problem-
try this...
Aligning Ink Cartridges Your printer automatically aligns the ink cartridges when they are installed or replaced. To verify your ink cartridges are aligned, you can print an alignment page. After you close the printer unit, press the Menu button. The alignment page begins printing. During printing, the operator panel display reads Alignment Page Printing. When complete, the message reads Auto Alignment Complete. Your ink cartridges are now aligned for optimal print quality.
You may also need to align ink cartridges when characters are not properly formed or are not aligned at the left margin, or when vertical or straight lines appear wavy.
To align the ink cartridges:
  1. Load plain paper. For more information, see Loading Paper.
  2. Click Start® Programs or All Programs® Dell Printers® Dell Photo AIO Printer 922® Dell Printer Solution Center.
  3. Click the Maintenance tab
  4. Click Align to fix blurry edges.
  5. Click Print.
The ink cartridges align when the page prints.
If this helps you plz rate this fixya. Thank you kindly. If you need more help post it & I'll be glad to do what I can.
Feb 01, 2009 | Epson Printer
HP Deskjet F380 won't print
i think the inside printer have dirt or obstacles that blocken the cartridges while printing.
try to clean manually the printer by using powerful air blower,repeatedly.
Sep 14, 2008 | HP DeskJet F380 All-In-One Printer
Dell 922 All-In-One InkJet Printer Logo
388 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
