Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Whirlpool duet sport washing machile leeks out of dtergent area!!
The model # is wfw8300sw00 or thats a 5w00 not sure but it leeks as soon as it is turned on out of the detergent area! not sure wht the problem is so if there have been any know leaks with whirlpool duet sport please let me know and it u have this problem please lt me know if u got it fixed or found a site that helps u!
  • Whirlpool Master
  • 2,651 Answers
The water is leaking out from the dispensor area??? sounds as if perhaps something has gotten down there blockig the waterwway, try removing the soap dispensor entirely and lookin towards the rear for a possibel obstruction
Posted on Feb 21, 2009
Whirlpool doesnt empty drum after washing
Remove the bottom kick plate and clean the filter. Have some towels handy! There will be some water that will come out when you open the filter. Keep me posted.
Nov 28, 2012 | Whirlpool Washing Machines
We have a Whirlpool Duet Sport Front-Loading Automatic Washer and it makes a pretty loud noise when in the spin cycle. The volume is directly proportional as to how fast the washer is spinning. It's a...
The symptoms that you describe are caused by bearing failure. The water seal in the wash tub has failed, allowing water to leak into the bearing causing the bearings to rust. As the bearings start to rust, they will not roll properly and start to make a rumbling sound. The sound get louder the faster the bearing turns.
It a major job to repair since the washer has to be taken apart and the wash drum needs to be removed to replace the seal and bearings. Get a few estimates before deciding whether the washer is worth the cost to repair or replace. Sorry.
Oct 04, 2010 | Washing Machines
I have a whirlpool duet front load mod#wfw8300sw00 washer and it makes a horrible sound when spinning almost a grinding sound is it done? or could it be something minor?
i have wfw8300sw00 whirlpool duet sport, i start de machine it's turn ons side (right to left) and abour 3 minutes it stop off no message.
Apr 29, 2010 | Whirlpool WFW8300SW
Whirlpool front load leaking water from the detergent dispenser
Could be pressure too high reduce feed to machine only ....Slightly...Also try cleaning just in case its blocked
Sep 28, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
F20 CODE Whirlpool Duet Sport Washer wfw8300sw00
“F20” on display
(Water Inlet Problem—no water or insufficient
water supply) Select PAUSE/CANCEL twice to cancel the cycle
Unplug washer or disconnect power. Check the following: Are water faucets completely turned on?
Are screens at inlet hose connection to washer
clogged? Are water inlet hoses kinked? Are water inlet hoses frozen?
Do rate the solution.
Feb 08, 2009 | Whirlpool WFW8300SW
F21 error code Model# WFW8300SW00 Duet Sport Washer
unfortunately there are no other pumps that you can put on the washer. You have to use the pump that is for the washer. A couple of tips though that you can go by with it is after every wash make sure to check the bellow boot for anything that may be stuck in it. That is the black rubber boot that goes around the drum and door. Socks and coins and under ware get in there and eventually get sucked down into the pump causing these problems. Let me know if you have any other questions and let me know if this was helpful. Good luck and glad I could help.
Jan 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
The motor does not engage in at all
The F 11 code is a water fill code. Check the water to make sure both lines are on. If their on then turn off take hoses off the water inlet valves in the back and check the screens. If your screens are clean then you probably have a water inlet valve problem. Are you able to open the door to get your clothes out? If not I can tell you how to get it open.
Jan 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Need a part number
The part number is W10160252. You can order the part at . The price is 131.10
Nov 13, 2008 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
179 people viewed this question
Dan Webster
Dan Webster
Sal De
