Question about Denon AVR-2803 Receiver
Problem when switching on Denon AVR 2803
Have owned amp for 5 years. When switching on using remote control I now hear a very slight 'ber dum' sound. This is a very intermittant problem that occurs about 1 in every 8 switch ons.
Have recently added a Blu Ray player to my set up which is connected by way of an optical cable. My previous DVD player was connected in the same way. My DVD recorder is connected by coaxial cable.
Any advice would be much appreciated.
    Problem Solver:
  • 11 Answers
The sound you describe is usually a mechanical noise from the transformer/case work. Home theater amps tend to have quite large transformer in what is, due mainly to its size, a rattly cabinet.
Over time, the lamination inside the transformer can loosen which could explain why it has only just started doing.
Alternatively, one assumes you moved the amp when connecting the new kit? This may have let the case work rest in a new way which is proving susceptible to relaying the vibration caused by the transformer as an audible noise on switch on.
Posted on Feb 16, 2009
I can't seem to get the tuner to work on my Denon AVR 2803 receiver.
It can't hurt.
You will lose all your settings though. So you'll have to set the amp up again from scratch.
Before you do initialise, let's just check.... You plugged in a FM or AM aerial, right?
Sep 13, 2014 | Denon AVR-2803 Receiver
After a power outage my denon 2803 receiver will not turn on.
Hello. First unplug and replug in your receivers. When you push the power button, you should hear 1 click. Within 5 seconds, you should hear a second click. Can you please tell me the results?
Thank you.
Sep 15, 2012 | Denon AVR-2803 Receiver
I can't get a menu screen up on my Denon AVR 2803.
Did someone turn the OSD off on the menu? You might try a reset of the receiver. This would be in your manual.
Aug 23, 2012 | Denon Avr 2803 7.1 Channel 875 Watt...
Using Denon AVR 2803 as an FM receiver
• Insure that the speaker system is working.
try it on other receiver.
• Check to see if there are headphones connected.
• Check if tuned is lit
Aug 12, 2012 | Audio Players & Recorders
AVR-2803/983: Had recent 24hr Power Outage. When power restored, I receive no video/sound from TV thru COMCAST HD box, no video from CD but do get sound, lost partial use of Zone 2. Zone 2 works if I...
Extended power loss might lose memorized settings. Pretend the unit is brand new and verify all of them. No video from CD??? Really? Good luck with that.
Jul 16, 2011 | Denon AVR-2803 Receiver
Denon AVR-2803 Zone 2 sound source
You have to switch your remote into Zone 2 Mode. It will be an option on your remote. Once you put it in that mode, you can change the source just as you would Zone one.
Jan 25, 2009 | Denon AVR-2803 Receiver
Sound cuts out
This sounds to me as an issue not with your AVR but with your cable unit. I have seen this where there is a sample rate issue with the cable boxes. I would try to get another cable box, and see if the issue persists.
Gary
Aug 28, 2008 | Denon AVR-2803 Receiver
Audio Problems with AVR-2803
Hmmmmm Sounds like one of 2 things....
1 Your DSP board is toast. ( not much hope, it must be sent to Denon as they do not have anymore entire circuit boards for swap-out replacement.
2. Heres the hope part......Inside your denon is like a computer.....there is a main board, separated by the big silver heatsink, and then there another main board. On the main board closest to the volume control, the DSP boards and Video boards plug into the main board . The DSP and video boards are up and down ( when the receiver is laying flat, like normally ), and they plug into the main board from the top.
Denon is NOTORIOUS for bad solder joints and the little white connectors that connect the "motherboard" to the DSP and Video boards are of suspect quality ( the rest of the unit is great )....So it COULD be that you have a bad solder joint on one of the connectors or the connector itself. There is also another set of connectors that joins the front panel display to this "motherboard".....these colder connections are also suspect.
I would have a denon repair shop look at it as I GUARANTEE they have seen this before.......best of luck...Rob
Mar 13, 2008 | Denon AVR-2803 Receiver
Unresponsive remote
Had same problem with this reciever over the weekend. I had to hook up a TV to the COMPOSITE monitor jack and then I could see the menus. I could never get it to show the menu over the component outputs, however a DVD player hooked up played perfectly. Anyone have a solution?
Jan 21, 2008 | Denon AVR-2803 Receiver
Denon Avr 2803
Could be bad connection. Try to tight connection cables on receiver and TV.
Oct 15, 2007 | Denon AVR-2803 Receiver
Denon AVR-2803 Receiver Logo
211 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
