Question about Honeywell Programmable Thermostat Heater
Thermostat does not follow the setting
Despite the temperature being set to a desirable degree, the furnace keeps running non stop; thermostat should be manually turned off in order to stop the furnace. Temperature is running up as well, making it sweltering hot inside. The reading seems to be accurate. Batteries are fresh.
  • 5 more comments
  • marianna88 Feb 15, 2009
    Thank you for trying to help. The thermostat is about three y.o., and it is the first winter when we have the problem I described. Heating is hot water baseboard/oil furnace. I hope it helps. And one more thing:heating in the house is zoned ( we have three identical thermostats. Problem with only one of them. I will try to switch boxes and see what will happen.) Thanks!
    Sorry, I wasn't clear. The second.
    You're right, baseboards should be checked, I'll see to it. My stat's behavior is a bit mysterious. Will keep you posted. Thanks!!
  • edgek44 Feb 16, 2009
    I just attached the thermostat wires to the new terminal (Honeywell RTH221B) this evening and the furnace (nat gas forced water) runs continuously -temp keeps climbing well past set temp. The only thing that seems to shut the furnace down is to disconnect the wires. Reconnecting the wires immediately turns on the furnace.
  • Mark Egan May 11, 2010
    It would surprise me that the thermostat is constantly calling for heat. Thermostats designed to shut-down once the temperature exceeds an excessive temperature as anything more than that is not good for humans.
    But check it out to be sure, and, make sure the baseboard heat is operating properly.
    Your suggestion to swap with other stats is a good one though. See if the problem travels with the stat, or stay with the unit.
    Does this thermostat control both the baseboard heat, and the oil furnace
    I assume the oil furnace is a forced air type of heat? Or, are you calling the oil furnace the oil fired water heater, where the water is used in the baseboard heat coils?
    Please clarify -
    Is this a newly installed thermostat?
    Has the system ever worked correctly?
    Is the heating electric, gas, or heat pump/heat pump with electric heat backup?
  • 56 Answers
If the thermostat is a digital /programmable you may want to recheck program to see if it has changed or been changed. If thermostat is not digital then it is prbably warn out and need replaced.
Posted on Feb 16, 2009
How do I stop the heating coming on during the night?
Set automatic day and night temperatures. Forget about manual setting. Your furnace will start at night only to maintain the temperature you set. However, there is a minimum threshold where your furnace will start regardless of the temperature you set if there is a sharp drop in temperature.
Jan 31, 2017 | Heating & Cooling
My furnace runs to operating temp on thermostat shuts down then within 30 seconds try's to cycle back on three to four times. What would cause this.
Some thermostats have a swing setting that can be adjusted. A swing is the setting when you want the furnace to stop or start from the desired set point. For example, you set your thermostat at 70 and the swing is set at 10 degrees. Then the furnace will turn on 5 degrees below 70 and shut off 5 degrees above 70. Check you thermostats manual if it has this option.
Mar 15, 2016 | Heating & Cooling
Am I able to adjust the 'hysteresis' of my digital thermostat?
Some thermostats allow you to change the differential value - that is how far below the heating (or above the cooling) set point before calling for heat (or cooling in the case of air conditioning). The built in 1 degree differential setting provides the most even temperature in the space at the expense of more frequent furnace firing and stopping. Many people prefer this mode as opposed to allowing wider swings in temperature for less frequent furnace firing and stopping. If you wish to change this setting, you'll need to replace the thermostat as it is not user adjustable in this model.
Nov 02, 2015 | Honeywell RTH6350D1000 5/2Day Prog...
I have a Braeburn 3200 and when the the temperature reaches the desired heat setting. The furnaces heat will shut off, but the fan will continue to run indefinetly. eventually blowing very cold air up
The fan relay is stuck in the on position. When the temperature drops the heater does not ignite because the fan is already running and ignition is locked out after the heat cycle starts an the fan turns on
Nov 16, 2014 | Heating & Cooling
My round non-programmable digital thermostat doesn't seem to be communicating with the heater very well. I set it to 70 degrees and it clicks off before reaching that temperature. Any ideas?
It sounds like you may have a round Honeywell thermostat. It could be that the temperature pointer you see on the face of the thermostat just needs to be adjusted. The next time your furnace or AC finishes running, remove the face off the thermostat and use a small screwdriver to set the dial so the pointer temp matches the other temperature indicator.
Oct 29, 2013 | Honeywell Heating & Cooling
Fasdfas
Does the furnace stays off?.
Furnace are ment to cycle on and off because of limits .If you set to 70 furnace would cycle several times before reaching that temperature.
Just make sure your filters are clean and you got proper return air flow because lack of air flow will cause furnace to shut off sooner than normal
Jun 08, 2017 | Heating & Cooling
Hi. I am just wanting to control the heat the manual way. I had someone come in to service my furnace and they set it for the week. How do I cancel that, and just have it so I can turn it up when I want,...
From the Operating Manual: _______________Manual Operation for Non-Programmable Thermostats Press the SYSTEM button to select Heat or Cool and use the [Up] or [Down] buttons to adjust the temperature to your desired setting. After selecting your desired settings you can also press the SYSTEM button to select AUTO to allow the thermostat to automatically change between Heat and Cool. _______________________Manual Operation (Bypassing the Program) Programmable Thermostats Press the [Up] or [Down] buttons and adjust the temperature wherever you like. Then press HOLD. This will override the program. The HOLD feature bypasses the program and allows you to adjust the temperature manually, as needed. Whatever temperature you set in HOLD will be maintained 24 hours a day, until you manually change the temperature or press RUN to cancel HOLD and resume the programmed schedule. ____________________________________________________ *Disclaimer: I am not a lawyer, despite the handle. Words to live by: "Every creative act results from a sudden cessation of stupidity." -Edwin H. Land, inventor of the Polaroid Land Camera "The problem can always be solved with the materials in the room." -My college Physics Lab Professor
Jan 19, 2011 | White Rodgers White-Rodgers 1F85RF-275...
I have a comfort zone furnace. If it's 50 degrees in the house, and i set my thermostat to 70 or so,it takes at least 24 hours to reach 70 degrees. The furnace starts up and runs normally for about five...
When the thermostat calls for heat it should run until the room reaches the temperature setting then shut off. Is the blower motor running and can you feel air coming out of the vents? It sounds like the blower is either not running or putting out enough air to keep the furnace heating. The blower moves the heat from the heat exchanger to the room, if it can't remove enough heat from the heat exchanger there is a limit switch that will shut the burner off if it gets to hot and that's what it sounds like is happening.
Apr 25, 2009 | Heating & Cooling
The furnace won't stop at the programmed temperature set ponts
this is called a swing tempature it is desined to improve the eficincey of the frnace because it take less energy to run an hour in a three hours then 3 bursts of 25 min in a three hour period
HOWEVER if you do not like this you can usualy set the swing temp
Jan 16, 2009 | Hunter Fan Company 5/1/1 Programmable...
Heating & Cooling Logo
579 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
