Hello Mike, I have a problem with friend's Mitsubishi VS-50501A with a convergence problem. I replaced the STK391-020 ICs, all 3 of them and the picture still looks like 3-d, and still has a bow tie, hour glass looking image. What do you think it might be? is there anything else I can try? Please let me know
  • g_ovalle Feb 15, 2009
    Thanks for your solution, I will try this, and see if it fixes the problem, I appreciate your help.
    Brigadier General:
  • 8,619 Answers
Hi!
Did you adjusted(callibrated) the screen after the replacement? Have you checked the solder joints of the resistors connected with the ics. Please check the resistors connected with the stk ics.
Posted on Feb 15, 2009
  • 13,433 Answers
Have you adjusted the convergence on the tv again after replaceing the parts?
  • 10,594 Answers
Please check pico fuses that might blew off and causing no power to new STK-391-020
Mitsubishi VS-50609 - Red convergence is way off, suddenly
You have a bad ground on a convergence IC. You will have to carefully pull this board out and resolder the pins. If this does not solve the problem you will have to replace the ICs. I have saved a few of these TVs with just a resolder job. Thanks for asking!
Jul 11, 2010 | Mitsubishi VS-50609 50" Rear Projection...
I turned on my TV and the screen looks like its in 3-D.Can you help?Every letter or symbol is in two's red and blue.
The Convergence Circuit has failed. It should be repaired by a professional. It will require replacement of the convergence ICs.
I hope this helps,
Skyassoc
Jul 16, 2009 | Mitsubishi VS-45609 TV
My Mitsubishi VS-50705 has an all over 3-D effect.
Yes it sounds to be convergence issue .
You have convergence problem in your tv . You need to replace convergence IC . YOu can get from the link below .
Convergence ICs
You need to replace both convergence ICs .It will cost you around $30 .
The IC number is STK392-110 .
Hope this helps .
Mar 03, 2009 | Mitsubishi VS-50705 50" Rear Projection...
Mitsubishi VS-50501A convergence problem. The image looks like a bow tie and the convergence will not align. This TV only has manual convergence. I already replace the STK391-020 ICs, it has 3 of them....
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV2_bing.gif may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 15, 2009 | Mitsubishi VS-50501 50" Rear Projection...
Mitsubishi VS50805 Serial # 102718 No red in picture
Replace the convergence ICs your model uses two STK392-040 Convergence ICs. You can get replacements at the following link with instructions.
http://servicemanuals.vstore.ca/
Dec 28, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi projection Model # VS-50501A (Power cutout)
they are fairly similar to each other, did you get a error code from the led by pressing menu and input both in together and holding for 5 seconds?
Aug 19, 2008 | Mitsubishi VS-50501 50" Rear Projection...
CONVERGENCE ic'S
They are IC8C01 and IC8C02 and they are STK392-110 convergence ICs. you can get replacement ICs at the following link and they provide free instalation instructions with pictures.
Jun 29, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Red convergence
I suspect you have a bad convergence ic bad the letters 0n the ics start with stk replace ic you will have a good shot that will fix it. you do need to be able to solder . be careful. there are 2 ics replace both .
mcm electronics for parts
thanks jay
Jun 01, 2008 | Mitsubishi VS-55609 55" Rear Projection...
Mitsubishi vs5043 convergence
Your chassis is a VZ3 that chassis should use two STK 391-020 ICs Its an easy repair Mitsubishi usually will not blow resistors when the ICs go out. You can get the replacement ICs at the following link and they provide free step by step instructions with pictures so if you have even basic soldering skills this isa job you can do in about 30 minutes . Heres the link.
May 07, 2008 | Mitsubishi VS-5043 50" Rear Projection...
Projection TV sets have several common problems listed below.
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
Example Photo:
You can see more examples and find a fix here...
May 01, 2008 | Mitsubishi VS-50501 50" Rear Projection...
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
