Question about Intel Motherboard
No sound In properties of my computer there is a pci and a pci device that are in yellow i.e. not recognized amd there is no sound I justi installed Windows XP SP3
    Sergeant:
  • 207 Answers
You should have gotten a disc with your motherboard. If you still have that disc put it in the disc drive and the install routine should come up. Install the various drivers that it offers.
If the routine does not start automatically, right click on the device with the yellow ! on it and select update driver. Have windows search automatically for it.
If you don't have the disc. Then you should be able to find your drivers at gigabytes website at the following link
http://www.gigabyte.us/
Dave
Posted on Feb 15, 2009
We are not found my audio hardware in computer hardware list
I am glad to HELP YOU!
Go on MY COMPUTER; right-click > select PROPERTIES > select DEVICE MANAGER.
There, listed under SOUND VIDEO AND GAME CONTROLLERS it should be your AUDIO HARDWARE.
Maybe is not recognized so you need to update the driver for it.
Go again to DEVICE MANAGER > SYSTEM DEVICES and see if
MS UAA
was installed properly.
It should be a list for Microsoft UAA Bus Driver for High Definition Audio.
If not, you should have a PCI tagged with a YELLOW LABEL with a "!" sign inside it.
Right-click on it > PROPERTIES > UPDATE DRIVER [NO to Connect, NO to Search but choose INSTALL AUTOMATICALLY].
Something that might interest you can be found HERE. Scroll down the page and at that guide, at PART #2, you will see some extra-explanations about WHEN MS UAA should be installed!
GOOD LUCK!
Apr 16, 2011 | Compaq Presario 700 470024-192 Notebook
My computer does not have vga driver, my proccesor is amd sempron 2800+...
Click start control panel administrive tools computer management device manager scroll to display adapters + to expand you might see a yellow question mark ? or exclamation mark ! or a red x right click select reinstall drivers
If your computer came with a motherboard disc the drivers could be on it
Want to make sure your drivers are in place and no errors have occurred? Simply click start right click on my computer select properties then select device manager scroll to Display Adapters and click on the small "+" you should see the model of your PCI Express graphic card there. If there is a problem with it, a yellow exclamation mark should appear besides it. If you don't see it everything is OK and your card is working properly. Hope this helps don't forget to vote
Feb 25, 2011 | AMD Sempron 2800, 2.0 GHz 2800+...
AMD AUDIO DREVERS
if your computer came with a motherboard disc the sound drivers could be on it
you might have to uninstall then restart your computer then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable)
hope this helps
Feb 04, 2011 | AMD M863G (M863G15CV22ARV000) Motherboard
There is a sound problem. i installed window xp recently , after that i installed drivers everything is done but sound driver is not performing so please tell me solution right now
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make sure you have selected the right speakers or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers if you have tried this you might try
control panel,administrive tools,computer management,device manager,sound,right click select properties to either troubleshoot,uninstall,rollback driver or scroll to sytem speaker right click select properties you will see at the bottom use this device enable/disable this device
hope this helps
Nov 26, 2010 | AMD Sempron 2800+, 1.6 GHz (G54222)
Haven't DVI signal and sound
install your sound driver given with your botherboad click install if you already installed the driver right click my computer click properties then hardware then device properties you will see sound vedio and audio controlers click it to expand see wether sound driver is marked with yellow if so undintall the driver by right clicking and install the drivers correctly
Nov 14, 2010 | EliteGroup ECS A785GMAD3(V10) Socket AM3...
Pci device missing making it impossible for sound to work
hi,
1. right click on mycomputer,then properties,then hardware,then device manager
2. you will find many devices, such as computer,disk drives,display,cd,etc....
3. select system devices, double click, there will be yellow colour indication appears on the pci
device, right click and diable it,
4. Selec Action menu and Scan for hardware changes, now your pci device will be detected and
install automatically and restart it.
thanks
ehsanullah (md_ehsan_1@yahoo.co.in)
Jun 15, 2009 | Sony VAIO F540 Notebook
PCI Modem-Yellow color
It just means that the driver for that modem is not installed. You just need to install it's driver. If you have a disc for that modem you can insert it on the media drive (CD of Floppy drive) then right click the PCI modem and click update driver, and install the driver automatically.
May 03, 2008 | Computers & Internet
No sound
did you check that your pc is having sound drivers installed or not
or they are working good or currupted
here is how you can find out
go to my computer right clik it
select property
go to hardware
here in new window you can see all installed devices
find out "sound, video and game controller"
now click + mark on leftside of it
it will drop down the list of available sound/ video devices
if you dont see any sound device then you have to install sound drivers
if you see any sound device but with yellow with it then its installed but not working properly
in that case also you need to install drivers once again
find this out
Mar 28, 2008 | Computers & Internet
RELOADED XP
yes, install new drivers, ****.
Feb 21, 2008 | E-Machines W3050 PC Desktop
Intel Motherboard Logo
48 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
