Question about Poulan Pro Pp125 25cc Gas Straight Shaft Attachment Capable String Trimmer
Poluan string trimmer stops running when attempting edge lawn.
Model PPB32SST starts but fails to continue run when edging my lawn. After its stops it is difficult to restart.
#1 Taper
  • 1040 Answers
SOURCE: yard man ym-25 lawn trimmer quits running.
Check the fuel lines for cracks/breaks. If they are o.k., then:
You will need to disassemble the carburetor and spray with carb.cleaner. Make sure the small screen is free of debris. (Should be able to see daylight through it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
Jim
Posted on Jul 03, 2009
Testimonial: "You were 100% correct. The screen was plugged. Thank you."
  • 173 Answers
SOURCE: poulan lawn trimmer cuts out when it runs for
Coil going bad.
Posted on Jul 08, 2009
bbreton
  • 437 Answers
SOURCE: will not idle
May be time to get the carburetor rebuilt. Sounds like the diaphragms are not working properly to pump fuel. You may need some lubrication on the throttle cable too. A little lubrication on the throttle arm would not hurt.
Good Day.
Posted on Oct 14, 2009
SOURCE: i have a weed eater twist & edge rte115 cant
how to string a weedeater/rtc115c
Posted on Jun 06, 2010
  • 12 Answers
SOURCE: I need a twist n Edge weedeater manual to find out
You can find the Poulan and Weed Eater instructions and manuals at InstructionSheets.com.
Here is a link to the page where you can download the Weed Eater RTE 115 Trimmer Manual.
Posted on Dec 29, 2010
Why is my ryobi 18 volt trimmer smoking? I have had this 2.5 years and using it on lawn edges only.
The motor is failing. Most likely the brushes have failed, but this is all sealed and they cannot be replaced alone.
Jun 10, 2014 | Ryobi 18 Volt 18v Cordless String Trimmer...
I have Homelite trimmer/edger for 3 years. It has been working great until recently, after a cold start and edging for 7 - 8 minutes it stops all of sudden until it gets cold and runs for 6 -7...
You need to check the ignition coil, by running until it quits and then remove the spark plug, reattach the plug wire and then ground the plug threads to the block and then try to start it. If you get no spark or very weak spark, the coil is bad and needs to be replaced.
I hope this helps get you going again.
Aug 17, 2011 | Homelite Mighty Lite Lawn Trimmer
Just got a Worx GT151 trimmer. For trimming grass has worked fine. Problem is in edging the sidewalk. I start edging and it takes littleraly 2 seconds to wear the string to half it's length, needing to...
Hi Dave.
When you are using a strimmer against stone or concrete you have to just barely allow the tip of the line to touch the ground. If too much of the line slaps off the concrete, any sharp edges or roughness on the concrete will tend to snap it. What you could try is heavier gauge strimmer line which might last longer. I used to use petrol strimmer line on my Black and Decker strimmer which was 350 watt rated. I'm not sure what effect it would have in the long term though and may wear the bearings due to the extra weight.
Jul 04, 2011 | Worx GT WG150 10 in. 18 Volt Cordless...
Hard to start but when i do get it started and turn the choke off it will not run
Check your fuel filter. It could be clogged. If not, it will be a problem that will require removing the carburetor and cleaning the mesh fuel strainer. It will most likely be clogged with a fine sedement. The strainer can be removed using a very sharp pointed large needle. Place the needle against the edge of the strainer and lift out. Sometimes they can be difficult but persistance is the key.That and patience.
Aug 29, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
I need a twist n Edge weedeater manual to find out how to put more string on the spindle
Jun 26, 2010 | Poulan Weed Eater Rte115 4.5 Amp Electric...
Broken Edge Guide
The diameter of the Black&Decker GH400 edge guide is 1/8". I know because I have the same problem and a small piece left from the original. Trying to find a new one is quite the quest.
Apr 22, 2010 | Black & Decker Garden
I need information on how to re thread a homelite string trimmer 155 i have not got a manual can you help
When you pull off the spool, look at the end of it. You will see an arrow pointing in the direction you wind the string. If you have two strings, they both wind in the same direction. Look on the body of the spool between the edges, on the barrel. You will see a hole or holes to start the string in. Good luck...Lee
Oct 20, 2009 | Garden
Poulan Pro Pp125 25cc Gas Straight Shaft Attachment Capable String Trimmer Logo
371 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
