Question about Vizio VX37L Television
Orange screen colors different
I just put a HDMI cable from my dvd player to my tv and the screen is mostly orange, and some blue
  • Hellboy13 May 11, 2010
    Have you tried all HDMI inputs, and if so, have you tried a different HDMI cable? It could be the DVD player, the cable or the input of the tv.
Orange on vizio is not working
Posted on Nov 09, 2010
My tv displays "format not supported"
Too many variables with what you are describing here. How old is the TV and how old is the DVD player. Did you verify that the components were all plugged in to their corresponding colors....blue to blue, red to red, green to green. Is the RGB cable verified good. Another common mistake is to plug the video jacks into ex. VID 1 while the Audio is on VID 2. Make sure they are on the same numbered input and that the TV is on the input your jacks are in. The HDMI may not work because there are three different HDMI types and not all play well with each other. The problem can be fixed with an HDMI converter but gets into more cost. Eliminate above mentioned and repost. I would be glad to troubleshoot you through this.
Mar 12, 2014 | Sony DVP-SR500H DVD Player
Dvd color mostly blue and pink, colors look weird
try connecting thru an hdmi cable from your dvd player to your tv, check the colors then.. I'd say you have crossed your component cables.. match the connector letters a/b/x? and plug them in one after each other.
Nov 05, 2007 | Konka KDL-37AT23U Television
I just bought an L G DP122 DVD player from WalMart--where I purchased my Emerson flat screen TV--and I CANNOT hook up the DVD player to my TV--the DVD will NOT play. My DVD Player has three (3)...
Make sure tv input is set for the slot you plugged the DVD
into.On the tv remote you will find inputs.Just change for the right one.
Most of the time DVD player is working when TV is on channel 2 or 3 .
Mar 02, 2017 | Emerson Televison & Video
When connected via HDMI, get picture filled with wrong colors - oranges, reds, blues; when connected via Component or Composite - works fine
You can ofter setup HDMI on your devices in different modes, for example my old tv had options that i could change RGB and other settings for hdmi. try looking in the settings of the DVD-player and see if you have hdmi options
May 03, 2011 | Philips DVP3982 DVD Player
The screen shows a green/ orange screen, even when we play a DVD... How can we make that go away?
How is the player connected to the TV? It could be S-Video, HDMI, RCA, or Component Video cables. My guess is that you're using component video cables. There will be three wires that carry the video signal to the TV, and each wire carries one color. There will be a blue, yellow, and green cables. If one of these cables is not seated properly, it can cause only one or two of the three color signals to make it to the TV, causing the image to be discolored. You should check the connections of the cables. You'll also see the sound cables, probably red and white. Do not get the red video and the red sound cable mixed up!
Jan 16, 2011 | Philips DVP3982 DVD Player
Bad image quality with HDMI connexion
Try a different HDMI cable. Check the on screen menu when this happens to see if it looks normal.
Cheers
Dec 29, 2009 | Televison & Video
Dvd's not playing in correct color
How old is the TV? It may need a firmware upgrade to support new HDMI/DVI formats
Aug 02, 2009 | Vizio SV420XV 42 in. LCD TV
Orange screen
Try a different cable other than HDMI, another HDMI cable, or another DVD player to narrow it down.
Feb 15, 2009 | Vizio VX32L Television
Plasma screen turns RED 600u panasonic 42''-- 2 yrs old.
sounds like a problem with the plug out put on the dvd player take it to a tech and have it checked or test it on another tv
Dec 21, 2007 | Nintendo Wii Console
Vizio VX37L Television Logo
207 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
