Question about GE 29450D Corded Phone
GE 2 9450D
NEED TO RESET MY GE 2 9450D TELEPHONE SYSTEM PLS HELP NOTHING IS WORKING ONLY THE INTERCOM FLASHING RED AND GREEN TKS
  • ianlin Feb 24, 2009
    Same problem here! How to reset the phone?
  • Anonymous Mar 23, 2009
    same here
2 Suggested Answers
SOURCE: 2-9450c telephone will not setup
With the handset down (hung up) press the intercom/speed dial number 1 then 2 quickly. I believe this assigns the phone intercom number 1. After a few seconds the phone should work normally. I just figured this out for my self.
Posted on Dec 31, 2007
SOURCE: intercom flashing
I didn't fix it myself. We had a phone technician come out to fix the line outside and that must have solved my problem. Thanks
Posted on May 28, 2008
I can't reset my nokia e66. I even tried hard reset *#7370# but nothings happen. Is any other way to solve this?
I can't hard reset E66 with *+3+Green+power. The flash works then E66 keeps silently( Doesn't turn on). Pls help to solve. Tks
Sep 07, 2010 | Nokia E66 Smartphone
Uniden powermax 5.8 GHz not working
have you tried a hard reset. please leave the phone plugged off from wall power for one night and then try starting.
this may start the phone normally and problem will get solved many times.
thank you
Aug 12, 2008 | Uniden Cordless phone EXS9950
Line 1 disconnects people on hold
Try these first and let me know
Intercom does not function correctly
• Make sure line 1 is connected properly and common to all phones on the system.
• Make sure all phone ID’s (station numbers) involved have been assigned.
Transfer does not function correctly
• Make sure receiver phones (stations) have same line connected.
Intercom indicator turns red and green alternately
• The station address needs to be re-assigned due to a duplicate station address in the system. See “Changing the Phone ID (Station Address)”.
Good luck,
Lee
Jun 17, 2008 | GE RCA 4-Line Speakerphone
The intercom light on my GE 2-9451 phone is flashing between green and red
This is what is in the user manual about the ligth means
Red Someone else is using the line.
Flashing red fast Incoming call.
Green You’re using the line.
Flashing green Line on hold.
Flashing red Line on hold by other stations.
Flashing yellow Incoming call transfer
Dec 18, 2009 | Video Game Consoles & Games
GE 2-9451
You need to have the phone join the network that you are in by assigning a station address to the phone. If this the only phone that you have like this, simply remove the plastic cover where the station addresses are to be printed. Beneath this cover there is a small button labled "PROGRAM BUTTON". Use a pen, press this button, then press "INTERCOM" and then label your station (01-16) followed by pressing the # key. This will make the intercom button flash on and off red and then it will stop flashing.
I hope this helps!
Aug 27, 2008 | GE RCA 4-Line Speakerphone
Phone not working. I left it unpluged all night to reboot. Same proplen. No service in or out. Badse keeps flashing "Welcome Please wait"
Pls check if the intercom function works. If yes, then the base is simply waiting for the presence of a dialtone on the telephone line. It would be required to check your telephone wire connections. Further, if you have an extension telephone, pls verify that indeed you have dialtone along the same line. In most instances, you may need to contact your phone provider to verify service.
If no intercom function, it may simply need pairing again or redo the initial install setup.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
credits: Benimur
Intercom flashing
May 27, 2008 | GE Lands Phones
Each telephone must be connected to line 1 and line 2 for
proper operation. The remaining lines 3 and 4 may — or may not —
be connected to each station as you desire. First plug in the battery, then the phone lines (1 & 2 are mandatory), and third the power cord. If your intercome LED is blinking red and green, then press: STORE IN, followed by "INTERCOM" followed by a free intercom# (i.e., any of the memory buttons 1 through 16 not already assigned to another telephone set. Then wait for the phone to go through its initiation sequence during which it searches each of the four possible lines. After that concludes, you should get dial tone on your active lines. :-) Marco
Sep 26, 2007 | GE 2-9450C Corded Phone
My intercom button flashed red to green. When I push a line button, I get a two-tone beep but no dial tone. I changed the internal 9 v battery. I unplugged the phone and waited, then plugged it back in....
be connected to each station as you desire. First plug in the battery, then the phone lines (1 & 2 are mandatory), and third the power cord. If your intercome LED is blinking red and green, then press: STORE IN, followed by "INTERCOM" followed by a free intercom# (i.e., any of the memory buttons 1 through 16 not already assigned to another telephone set). Then wait for the phone to go through its initiation sequence during which it searches each of the four possible lines. After that concludes, you should get dial tone on your active lines. :-) Marco
Aug 29, 2007 | GE 2-9450C Corded Phone
Remove power cord with no backup battery
be connected to each station as you desire. First plug in the battery, then the phone lines (1 & 2 are mandatory), and third the power cord. If your intercome LED is blinking red and green, then press: STORE IN, followed by "INTERCOM" followed by a free intercom# (i.e., any of the memory buttons 1 through 16 not already assigned to another telephone set.) Then wait for the phone to go through its initiation sequence during which it searches each of the four possible lines. After that concludes, you should get dial tone on your active lines. :-) Marco
May 17, 2007 | GE 2-9450C Corded Phone
Lands Phones Logo
127 people viewed this question
Top GE Lands Phones Experts
Dudeman321
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
