Question about GE Security Simon 3 Wireless Home Security System
Repair parts for simon 3
I need a new panal door switch mine is missing. Where can I buy one?
  • 4 Answers
Try eBay. Look for any of the following keywords:
"GE Simon"
"ITI" (that's eye-tee-eye, for Interactive Technologies, Inc. original developer of Simon, now a subsidiary of GE Security)
"319.5" (the frequency on which simon sensors operate).
You'll find almost any sensor you can imagine there.
Posted on Jul 29, 2009
  • 423 Answers
Type simon 3 accessories into google and you will find a billion places to buy accessories at.
Posted on Feb 15, 2009
How to remove ford taurus window switch
Door Panels
Print
REMOVAL & INSTALLATION
See Figures 1 through 8
This procedure applies to both the front and rear door panels.
Fig. Fig. 1: Remove the cover from behind the inside door handle by gently pulling it out to release the retaining tabs
Fig. Fig. 2: Remove the pull cup retaining screw cover and...
Fig. Fig. 3: ... remove the retaining screw from the cup and lift the cup straight up out of the door panel
Fig. Fig. 4: Remove the two sail panel/speaker grille retaining screws and...
Fig. Fig. 5: ... remove the panel/grille from the door
Fig. Fig. 6: The door panel is retained to the door by 11 retaining clips
Fig. Fig. 7: Carefully lift the door panel off of the door and...
Fig. Fig. 8: ... detach the electrical connectors from the switches and remove the panel from the vehicle
  1. Remove the cover behind the inside door handle.
  2. Remove the screw from the bottom of the pull cup retaining the front door trim panel to the front door.
  3. Remove the two screws retaining the sail panel/speaker grille assembly and remove the panel/grille from the door.
  4. Remove the three screws retaining the front door trim panel to the front door.
Do not attempt to remove more than one pushpin at a time.
  1. Use a suitable tool to remove the pushpins from the door.
  2. Carefully lift the door panel away from the door.
  3. Detach the electrical connectors as necessary and remove the panel from the door.
To install:
  1. Installation is the reverse of removal.
Aug 15, 2012 | 1998 Ford Taurus
I have a GE Simon Security System and I recently moved a door that had a sensor on it. Now that sensor shows as 'Open' and I can't get the system to reset. Any suggestions?
Take the small part (the magnet) off of the dr or dr framemove it around the large part (the contact) and see if it clears. If you cant see the control panel/keypad from the dr you may need help. As you move the maget around the contact slowly you want to see if the zone clears. My guess is the magnet is is not in they right place. if you open the cover on the contact the magnet should be parallel to the reed switch(a glass tube about 3/4"long).GL.
Apr 14, 2011 | GE Security Simon 3 Wireless Home Security...
Can any wireless door or window sensor be used with the ge simon
Sad to say but other brands of wireless door and window sensors will not work with the ge simon. Other sensors has different command patterns that it will not recognize the command coming from the GE Security Simon 3.
Nov 02, 2010 | GE Security Simon 3 Wireless Home Security...
I have a brand new GE Simon 3 system and am getting a low battery warning. Does it need to charge for a few days out of the box, or was i given a bad part?
No it does not need a few days 12 hrs should have been enough. you will need a multi meter to check this. pull battery off panel after confirming leed where connected properly. meter battery. I believe its a 6v battery should read 6.25-6.5v approx. if so check volts on the leads should also read 6.25-6.5v appox. if so try running sensor test. open panel door look for red numbers enter your code then select sensor (test) then "done" wait 5 min then close panel door. Then press status button. if this does not solve problem. time for service call.
Feb 10, 2010 | GE Security Simon 3 Wireless Home Security...
Sparp R 930 not heating, turntable not turning
I just repaired mine with the same symptoms. I found that the bottom microswitch on the door (there are 3 switches) was faulty. It started as open, when the door closed, the switch closed (good), but when the door was fully closed the switch was open again. I went to Electronic City with the switch in hand, they found me a duplicate that cost me $2.50. BTW - you must take out the door switch assembly, 3 screws plus wires, in order to work on the switch. Also, put the assembly back in so that the door latches close/open the switches correctly. -jk
Jan 14, 2010 | Sharp R-930AK Convection/Microwave Oven
How do i access the system battery in a simon 3?
If you know how to open the panel door by pressing the release on the top. open the panel door look where the release on the part that is still on the wall, not the part that hust swung down. You will need a screw driver. to release the the latch. then the part with all the buttons will swing down leaving the back plate still on the wall. remove the 2 screws on the box that is in the middle. battery is inside. good luck.
Dec 12, 2009 | GE Security Simon 3 Wireless Home Security...
Unresponsive door sensor--Simon 3
If it is a newer model there are several setting as to which reed switch you are using or if you are using the wired option. Contact the professor.
AlarmProfessor.net
Sep 04, 2009 | GE Security Simon 3 Wireless Home Security...
Sensor failure Simon 3 wireless home alarm
the sensor is going out, i would switch it out with another one in your house and see if the problem follows it there.
Sep 02, 2009 | GE Security Simon 3 Wireless Home Security...
GE Security Simon 3 Wireless Home Security System Logo
680 people viewed this question
Top GE Home Security Experts
Michael Galve
Michael Galve
Are you a GE Home Security Expert? Answer questions, earn points and help others
