Question about Lakewood Oil-Filled Electric Radiator Heater
Put heater on a shutoff timer
I would like to put the lakewood heater on some sort of timing device so it shuts off after, say an hour. My wife keeps forgetting to turn it off. Do you have any recommendations? It is a model 7101, has two switches, one for 900 one for 600. Thanks.
  • 34 Answers
Visit this page to contact a service center http://www.lakewoodeng.com/html/parts.html
Posted on Apr 18, 2009
I have a Paragon model 4004-20 Water Heater Timer and I moved the TIME arrow. Now the water heater is not working at all. I am thinking of just restoring full time power to the water heater. I did not...
You are not supposed to move the time arrow.
http://waterheatertimer.org/Paragon-timers-and-manuals.html
4000 series time arrow is pointed at 8:00.
To set current time, lift and rotate dial clockwise until current time lines up with pointer.
Put X2772 trippers on dial at times you want water heater to turn on.
Minimum on-off with Paragon 4000 is 1-1/2 hours because trippers are so fat.
You can replace 4000 timer with electronic timer and control exact on-off down to the minute:
http://waterheatertimer.org/Boxtype.html
Electric water heater heats about 21 gallons of water per hour.
Shower uses 6-9 gallons hot water.
Bath uses 10-12 gallons hot water.
Average water heater that is not connected to timer, runs about 3 hours a day. You can make timer pay off by keeping time schedule lower than 3 hours.
Following link shows how to figure cost for electric water heater:
http://waterheatertimer.org/Figure-Volts-Amps-Watts-for-water-heater.html
Following link shows several ways to save with water heater, plus general information to save money long-term:
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html
Nov 21, 2010 | Heating & Cooling
Get a electric water heater or not?
I'd stay with the boiler, electricity to heat water is very expensive. I would not bother with a timed shutoff for the reasons you said. The water will stay hot for some time.
Jun 15, 2010 | Water Heaters
How to clean the coffee maker & set warmer
In order:
1 and 2) Clean the coffeemaker by puring in 1/3 caraffe vinegar, and 2/3 caraffe water. Either use the self-clean light or brew it as if it were regular coffee - just press the on button and then press the self-clean button, and it will begin.
3)
The Automatic Shutoff Time can be programmed
anywhere from immediate shutoff
after completion of the brew cycle up to four
hours. When the coffeemaker shuts itself off,
two tones will sound. Four hours is the default
time. The 0:00 setting shuts the unit off immediately
after brewing is complete. To check the
current setting, press the “On/Off” button and
the Automatic Shutoff Time will be displayed.
To change the preset time, press and hold the
“On/Off” button until the red “power” light
begins to flash. This signals that you have
entered the “Set Automatic Shutoff” mode.
Press the “Hours” and “Minutes” buttons
to scroll forward through the digits until
desired time appears. The first setting which
appears is preset at “4:00” and the next
display will be “0:00”, since four hours is the
maximum Automatic Shutoff setting. Pressing
and holding either button will allow you to
scroll continuously, slowly at first, and then to
accelerate to the rate of about three digits per
second. As the desired time setting approaches,
release the button and then press repeatedly
to advance one digit at a time.
The Automatic Shutoff Time (ASO) may be
programmed either before or during coffee
brewing. You may also re-program the ASO
time when brewing has been completed. If you
do so, the Automatic Grind & Brew™ will automatically
account for any time that has already
elapsed after brewing. For example, if you set
the ASO for 40 minutes and 25 minutes have
already elapsed, the Grind & Brew™ will shut
off automatically after 15 minutes (40 minutes
minus the 25 elapsed equals 15 minutes).
-Tha Mp3 Doctor
Mar 27, 2009 | Cuisinart Coffee Makers & Espresso...
WARMING PLATE DGB 300
Feb 01, 2009 | Cuisinart Grind and Brew DGB-300BK 10-Cup...
SHUTS OFF AFTER 1 HOUR
Here ya go!
Setting Auto Off (units with timer only)
On models with a glass carafe, the auto off can be set to shut the coffee machine off from 1 - 5
hours after the brew cycle is complete. The factory setting is 2 hours. On models with a thermal
carafe, the coffee machine shuts off after 20 minutes.
Note : On models without a timer the coffee machine must be turned off manually. It
will not automatically shut off.
• Press the prog button (o), immediately followed by the h/min button (n).
• The display will show the time setting.
• Press the h/min button in steps to set the auto off time.
• Press the prog button to confirm the setting.
Dec 30, 2008 | Krups FME2 Coffee Maker
How to set Cannon NP6050 to shut off at 5
those daily timers are for shutoff
Nov 18, 2008 | Canon NP 6050 Copier
Time Saving Question
A timer on a conventional electric water heater can save 5-12% on your hot water bill. The water in the tank remains hot for up to eight hours or more while the water heater is not in operation, depending on the insulation and age of the unit. However, the hot water is still available for household use until it is completely consumed. Thus, if a household has a fifty-gallon water heater, it will have fifty-gallons of hot water available while the water heater is not in operation. Most households won't notice the interruption unless they have high hot water use patterns in relation to tank size. It is best to set the timer during hours when hot water use is lowest, typically during the work day or at night. Adjusting the timer may be necessary if households experience a shortage of hot water.
Aug 27, 2008 | Intermatic EI210 Electronic Auto Shutoff...
Auto shutoff
Go to "Settings" -> "Auto Shut-Off" - there i set a time like 5 or 10 minutes, and press the "enter"
The auto shut off is if the device is left idle for that amount of time.
It does not function as a sleep timer, per say.
I hope this helps
Please rate accordingly
Thank you
Computerrep
Jun 16, 2008 | SanDisk Sansa m240 MP3 Player
Lakewood oil filled heater model 5500
Follow up to my post of 13 January. Out of desperation, I took the heater apart and determined that an electrical fuse-like thermal overload device had opened on the neutral side of the feed to the heating element thus rendering the unit non-working. This device is wrapped in a sheath around the underside of the heating element's electrical connections where the element enters the radiator's core. If the element exceeds the rated temperature it apparently "blows" or electrically opens much like a fuse. The lights still come on but no electricity is getting to the element. When I removed this from the circuit, the the unit began making heat. Apparently, when the heater is on full (both switches on for the full 1,500 watts) the core temperature gets too high. So, I now use my heater on only the 900 watt setting and it's putting out plenty of heat. Today's high is 2F and the room is comfortable. I've no doubt the manufacturer would not condone this modification and I have no intention of turning my modified heater back on "HIGH." Therefore I do not recommend doing this yourself unless you are competent in electrical and soldering work and are sure you won't overheat the unit. Having said that Lakewood clearly has either a design flaw or a bad batch of heater elements or overload protectors out there. When I have time, I'm planning to send my defective protector back to them with a letter. But given that they never responded to my e-mail to their customer service don't expect much in the way of a reply. As they say on TV, don't try this at home.
Dec 08, 2007 | Lakewood (5500) Oil Filled Radiator Heater
Lakewood Oil-Filled Electric Radiator Heater Logo
93 people viewed this question
Top Lakewood Heating & Cooling Experts
Mack Baxter
paulcarew
Jay Finke
Jay Finke
Are you a Lakewood Heating and Cooling Expert? Answer questions, earn points and help others
