Question about Craftsman 4 Cycle Blower/Vac
Craftsman leaf blower backpack fan blade #PA66+GF50
Where can I get a replacement blade for a Craftsman backpack leafblower ? #PA66+GF50?
  • Anonymous Feb 17, 2009
    Where to get a blade for a craftsman backpack leaf blower. Hello , The model #3164991 and serial #002706 , The # PA66+GF50 is on the blade itself. Thank you
boscia
  • 163 Answers
SOURCE: gas blower craftsman leaf older modle
check the fuek lines for hole and leaks, check the fuel filter and clean if necessary. remove the carbuerator and inspect the gasket; it should be soft and flexible, if it seems hard or brittle replace it. clean the carb with carb cleaner sray (available at any local auto parts store) and compressed air. make sure you get inside the small fuel rail holes. check the primer bulb for pin holes and seating/sealed properly. if that doesn't work have the carb repaired at a service center or replaced.
Posted on Nov 30, 2008
  • 211 Answers
SOURCE: craftsman leaf blower
Hi
Check the fuel lines,fuel filter and clean the fuel tank.Disassembly the carb and clean it carefully.Diafragm type carb has a fuelpump,pay attention to it ,has to be tighten not folded.When the engine gets warm ,the fuelpump cannot keep the right proportion of fuel and the air/fuel mixture is changing.It has to be changed.
regards savumihai71
Posted on Dec 05, 2008
  • 211 Answers
SOURCE: leaf blower will not continue running unless primer bulb is pushed intermittently
Hi
Priming the engine(put some gas in the sparkplug hole)..If.Start the engine.If only the gas from the cilinder is burned change the lines prom primer bulb.
best regards savumihai71
SOURCE: craftsman leaf blower/vacuum
There is a round grille on the bottom of the unit. Insert a flat blade screwdriver into the latch to release it and reveal the vacuum opening. You should have a two-piece intake pipe that will attach to the opening.
The collection bag attaches to the smaller outlet where the blower pipe used to be (unscrew the wing nut to release the blower pipe). The bag clips onto the hooks at the base of the opening.
Posted on Apr 24, 2009
SOURCE: craftsman leaf blower, primer bulb will not return, won't start
primer bulb on weedeater will not return to normal or **** gas into it. new primer bulb. lines to tank have been repalce and can blow through them but primer bulb will not push air into tank
Posted on Aug 21, 2009
Craftsman 32 cc 4-Cycle Backpack Blower won't throttle
I wouldn't try too hard to fix ANYTHING that's brand new! This is what a warranty is for!
May 31, 2012 | Craftsman 32 cc 4-Cycle Backpack Blower
I need a gastank for my homelite-backpack leafblower, model#uto8580a.It leakes around the screw that holds it own. This is the second time i've had to replace it. There must be a defect in these.
There is a recall for leaking fuel tanks on your unit.
The Homelite #UT08580/UT08580A Backpack blower service recall and all related questions and issues, are being handled through the Homelite customer service phone staff at 1-800-242-4672, for records purposes.
Aug 22, 2011 | Homelite Consumer Products Backpack...
Leafblower shuts off
Yes. Your gas cap is clogged.Try this: The next time you run the blower, and it starts to die, loosen the gas cap. It should start to run again, then you know that it is the gas cap.
Jim
Jun 08, 2009 | Homelite 'Yard Broom' Leaf Blower
CRAFTSMAN LEAFBLOWER TROUBLE
After you do the above, try to clean out the fuel line. It may only be letting in a small amount no matter the throttle control.
Dec 30, 2008 | Craftsman 4 Cycle Blower/Vac
Craftsman leafblower running worse
Check the exahust screen (if fitted) for blockage. or exahust port...If it is clean port and or screen and use correct type/ ratio mix.
Dec 14, 2008 | Craftsman 4 Cycle Blower/Vac
Craftsman gas leafblower
Hey Karl,
To me this sounds like its getting too much fuel after it has been warmed up so either there is too much gas flow to the unit or there is not enough. check your primer bulb once this happens if there is a full bulb when it shuts down chances are its getting too much gas, if its empty then its not getting enough and your fuel filter could be starting to plug up or is not in the tank properly.
Nov 16, 2008 | Garden
String caught in fan of Craftsman 79474 garden leaf blower
That srew is most likely a Torx style size T 25 or a T 27
Nov 13, 2008 | Craftsman 4 Cycle Blower/Vac
Leafblower
Oct 18, 2008 | Husqvarna Backpack Blower 25cc, 140 Mph,...
Craftsman 4 Cycle Blower/Vac Logo
239 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
