Question about AMD Athlon XP 2000+, 1.67 GHz Retail Processor
Which memory can i use?
My system is AMD Athlon(tm) XP 2000+, currently I use DDR SDRAM PC-1600/2100 memory. i would like to know which memory card i can use for uppgrading. can i use kingston 512MB 184-pin sdram ddr266 (2100) memory card? i really appreciate it if you can give me some suggestion.
  • Dennis H May 11, 2010
    It would be best to know the brand of computer and model #, or if its a custom built the brand of the motherboard, and model #
    You can use most any DDR including DDR 333 (2700) or even DDR 400 Mhz, as they just scale down to the lower speed.
    the motherboard determines the amt of memory, how many slots, and max size in a slot the motherboard will support , so to max out, or give you best advice please list more info.
  • 21 Answers
I should think that will be ok but why restrict it to 512 when you can have 1024 mb
Posted on Feb 28, 2009
DOES K7SOM MOTHERBOARD UPGRADABLE?
Hello here is the homepage:
http://www.ecs.com.tw/ECSWebSite/Downloads/Downloads_Driver_Detail.aspx?MenuID=61&LanID=0&detailid=79#Download-2
And the + versions:
http://www.ecs.com.tw/ECSWebSite/ECSSearch.aspx?menuid=0&lanid=0&keyword=K7SOM+
I would say no because the cpu does not exist anymore.
The only thing you can upgrade is the harddrive and the ram module.
The mainboard uses SDram and DDR ram in there own seperate block.
Sdram is hard to find and expensive.
DDRram can still be bought.
The specifications:
PROCESSORS
462 pin Socket A supports the AMD K7 processors
Full series of Athlon XP/Athlon/Duron processors
CHIPSET
SiS 740 & SiS 961/962 Chipset
SiS 740 Host/Memory controller with high quality 3D graphic accelerator
SiS 961/961B/962 MuTIOL Media I/O
Integrated USB 2.0 host controller in SiS 962
LPC I/O -ITE8705F
LAN: MAC integrated in SiS 961/961B/962 and PHY on board
AC97 Audio Codec: Compliant with AC97 2.2 specification
SYSTEM BIOS
AMI 2MB Flash EEPROM
Supports Plug and Play 1.0A, AMP 1.2, Multi Boot, DMI
Support for ACPI revision 1.0 specification
MEMORY
2 DDR DIMM Sockets and 2 DIMM sockets support (can not be used simultaneously)
Two 184-pin 2.5V DDR SDRAM (DDR266/200) or
Two 168-pin 3.3V SDRAM (PC133/PC100)
Maximum: 2GB (DDR SDRAM or SDRAM)
I/O INTERFACE
Hope this was helpfull
Nov 29, 2012 | EliteGroup K7SOM Motherboard
I have a DFI LANPARTY UT nF4 Ultra-D and have been been unable to use all of the memory slots. I originally bought 4GB but have only been able to use 2. Is there a setting that i need to enable?
Hi, you can use up to 3 gigabytes on windows xp 32 bit with service pack 3.
You need a 64 bit operating system to use 4 gigabytes of ram.
Here is some info:
CPU
AMD Athlon 64 FX / Athlon 64 / Sempron Socket 939
Chipset
NVIDIA nForce4 Ultra
Front Side Bus
2000MT/s
HyperTransport interface
Memory
Four 184-pin
DDR SDRAM DIMM sockets
Supports dual channel (128-bit wide) memory interface
Supports up to 4GB system memory
Supports
DDR266, DDR333 and DDR400 DDR SDRAM DIMM
BIOS
Award BIOS
CMOS Reloaded
CPU/DRAM
overclocking
CPU/DRAM/Chipset overvoltage
4Mbit flash memory
Aug 30, 2011 | DFI LANPARTY UT nF4 Ultra-D Motherboard
I have the hp pavilion 524w desktop computer and I was wanting to know if it is possible to insert a newer version of the processor. 1.73 ghz is not fast enough. Is there anything faster that will go with...
The compatibility isn't with the memory, it's with the motherboard and its chipset. In your case the motherboard is a FIC AM-37 which has an VIA KM266A chipset - an extremely old chipset . The only processors accepted are AMD Athlon XP of the first generation of which you already have the fastest version
http://en.wikipedia.org/wiki/AMD_Athlon(tm)_XP_3200%2B#Athlon_XP_.22Palomino.22_.28Model_6.2C_180_nm.29
So no, it's not possible to upgrade it. You will have to buy another motherboard-processor combo.
Aug 04, 2011 | HP Pavilion 524w (DB280AR#ABA) PC Desktop
How do you know when a memory stick is single-bank? I want to upgrade my A7V8X-X with 3 Gs, but I keep getting confuse how to determent what is single-bank! Is there a specific code in the product...
This is the memory spec for your motherboard...
3 x DDR DIMM Sockets
Max. 3 GB unbuffered PC2100 / PC1600 non-ECC SDRAM Memory (PC3200 Max. to 2 banks only / PC2700 Max to 4 banks only)
Part of the memory spec will tell you if it is single sided (memory chips only on one side of board)
Double sided is memory chips on both sides of the board....Some systems will not work with double sided memory...
Feb 10, 2011 | ASUS A7V8X- X VIA KT400 ATX AMD AUDIO LAN...
I want to know which memory to buy for my pc. I checked it on crucial.com and it said I could upgrade to 1gb. When I looked inside the cover I saw a 256mb memory chip but could not see how many slots it...
hello, here's a part of the spec from the hp website. It looks like you've got 256mb on board memory and one expansion memory slot in which you can fit a 1024mb card, giving you a max memory of 1280mb (1024+256).
Hope this helps!
nicam49
Hardware
Product Name zv5410US US Product Number PR465UA#ABA Microprocessor 1.8GHz AMD™ Athlon™ 64 Processor 3000+ with PowerNow!™ Microprocessor Cache 1MB L2 Cache Memory 512MB DDR SDRAM (2 x 256MB) at 333MHz Memory Max 1280MB DDR SDRAM (1 x 256MB, 1 x 1024MB) Video Graphics NVIDIA GeForce 4 440 Go Video Memory 64MB DDR (dedicated) Hard Drive 60GB (4200RPM) Hard Drive Diskette Drive External USB Floppy Drive available for customers via hpshopping.com or local retailers
Jan 11, 2011 | HP Pavilion zv5410US Notebook
Ga3400 reports 384 meg of ram
hello, that sounds right because the system you are reffering to is an "Everex IMPACT GA3400" by default this 512mb of RAM but 128mb of it is shared for your video card hence leaving you with 384mb.
below are specs for your sysem:
Processor
  • 1 x AMD Athlon 64 3400+ 2.2GHz
    Bus Speed
  • 1600MHz
    Cache
  • 1MB L2
  • Memory
    Standard Memory
  • 512MB
    Maximum Memory
  • 2GB
    Memory Technology
  • DDR SDRAM
  • Storage
    Hard Drive
  • 120GB Ultra ATA 7200 rpm
    Optical Drive
  • DVD-Writer (Double-layer) - DVD?R/?RW
  • Controllers
    Controller
  • Ultra ATA
  • Display & Graphics
  • Graphics Controller
  • nVIDIA GeForce 6100
  • Audio
    Sound Card
  • Included
    Speakers
  • Included
  • Network & Communication
    Network
  • 10/100Mbps IEEE 802.3u Fast Ethernet
    Modem
  • 56Kbps Data/Fax Modem Integrated
  • I/O Expansions
    Expansion Slots
  • Flash Memory Card (1 Total)
  • Input Devices
    Keyboard
  • Included
    Pointing Device
  • Included
  • Interfaces/Ports
    Ports
  • 1 x Audio Line Out
  • 1 x Microphone/Line-in
  • 6 x 4-pin Type A USB 2.0 - USB
  • RJ-45 Network
  • 1 x RJ-11 Modem
  • 1 x VGA
  • 1 x 6-pin mini-DIN (PS/2) Mouse
  • 1 x 6-pin mini-DIN (PS/2) Keyboard
  • 1 x IEEE 1284 Parallel
  • Software
    Operating System
  • Windows XP Home with SP2
    Software Included
  • CyberLink Power DVD
  • CyberLink Power2Go
  • Norton Internet Security
  • i would recommend that you visit crucial.com or newegg.com for memory upgrade which will improve your new PC's experince.
    hope this helps,
    good luck,
    regards,
    Amar Sondhi
    Dec 06, 2009 | Everex GA3400 Refurbished AMD Desktop...
    Memory upgarade
    Yes, it will work. Remember that all memory will operate at the speed of the slowest memory though so unless you're completely replacing the memory it won't increase the speed of the memory.
    Jul 21, 2009 | ASUS A7V400-MX Motherboard
    Compatible ddr memory for K7AMA Motherboard
    Two 184-pin 2.5V DDR SDRAM (DDR266/DDR200) or
    Maximum: 2GB
    Jan 03, 2009 | EliteGroup K7AMA Motherboard
    EliteGroup K7S5A (does not say pro on the board)
    According to their website, the board can take:
    AMD Athlon XP (Throughbred up to XP2600+)
    AMD Athlon (including Thunderbird)
    AMD Duron (including Morgan)
    You can then overclock the processor with a BIOS upgrade available at http://www.ocworkbench.com/2002/ecs/k7s5abios/cheepobios.htm.
    It has one 4X AGP slot so it can take any AGP video card, assuming the card is backwards compatible (8x -> 4x).
    Jan 13, 2008 | EliteGroup K7S5A Pro Motherboard
    AMD Athlon XP 2000+, 1.67 GHz Retail Processor Logo
    173 people viewed this question
    Top AMD Computers & Internet Experts
    Alun Cox
    Robert Monigold
    Robert Monigold
    Are you an AMD Computer and Internet Expert? Answer questions, earn points and help others
